Go Back   Ford Truck Enthusiasts Forums > Diesel > 1999 - 2003 7.3L Power Stroke Diesel
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
1999 - 2003 7.3L Power Stroke Diesel SPONSORED BY:
Is F-150 Still King?
  #1 (permalink)
Old 11-05-2009, 06:20 PM
airassaultinfantry1 airassaultinfantry1 is offline
airassaultinfantry1 is starting off with a positive reputation.
6 leaker intercooler into a 7.3
greetings ,
is there a "trick" to getting a 7.3 intercooler out ? it seems like it wants to go but I dont want to force it . I saw on some auto show were they just pushed the radi foward and slipped it out and dropped the new one in ? But let me guess - only in tv world
Thanks
John
I had a zip tie to secure my block heater cord that i missed in the darkness with limited lighting
  #2 (permalink)
Old 11-05-2009, 06:30 PM
guzzle92's Avatar
guzzle92 guzzle92 is offline
no leaks here...
guzzle92 has a great reputation on FTE. guzzle92 has a great reputation on FTE. guzzle92 has a great reputation on FTE. guzzle92 has a great reputation on FTE. guzzle92 has a great reputation on FTE.
That's about all I had to do to get mine to slip in - The real PIA was having to relocate the tranny cooler in my 02.
__________________
guzzle
02 F350 4x4 SRW EC LB Lariat
guzzle's Mods & Maintenance Website
If you own a 99-03 7.3 PSD, this is the place to be:
Roadside Help Network
  #3 (permalink)
Old 11-05-2009, 07:38 PM
7.3 Rocket's Avatar
7.3 Rocket 7.3 Rocket is offline
of RiffRaff
7.3 Rocket has a great reputation on FTE. 7.3 Rocket has a great reputation on FTE. 7.3 Rocket has a great reputation on FTE. 7.3 Rocket has a great reputation on FTE. 7.3 Rocket has a great reputation on FTE.
You will need different boots to mate up to the 6.0 IC. And I didn't have to touch my radiator in order to remove my 7.3 IC. Took off the bar that goes over top the IC and took off the hood latch and all that then took off the IC boots and it popped right out.
The RDP boots are nice. I've got a set of red ones on mine and I love them.
Riffraff Diesel: Intercooler Boots
__________________
-Pete, PAA member #84
99.5 F350 XLT 4x4 regular cab longbed 7.3L PowerStroke 4" MBRP turbo-back, Isspros, 6637 w/ cover, CCV, AIH delete, foil delete, 6.0 IC, Van turbo, RDP IC boots, DP Tuner
Smoke Responsibly
  #4 (permalink)
Old 11-05-2009, 07:44 PM
good lookin out . I bought my from Brenden today . I do want to talk to about injectors . as for now I just got the 7.3 ic out .
thanks
John
  #5 (permalink)
Old 11-05-2009, 07:56 PM
7.3 rocket
I'm soory . I was in a hurry and only saw riffraff @ the bottom , hence the injector comment . However what did you do trans or oil cooler ?
  #6 (permalink)
Old 11-05-2009, 08:05 PM
7.3 Rocket's Avatar
of RiffRaff
I've only got the 6.0 intercooler installed right now. I've got a 6.0 trans cooler but I haven't gotten around to installing it yet.
I assumed since the title of the thread is "6 leaker intercooler into a 7.3" we were talking about intercoolers which is why I suggested the boots.
Riffraff is a great organization to deal with. I've gotten pretty much all my parts through him except for my Intercooler which I bought from an FTE member, my DP which I bought from Jody himself, and my trans cooler. Everything else is Riffraff stuff. At least as far as modifications.
When I do injectors I'll be getting Casserlys though Riffraff.
By the way I'm Pete.
__________________
Smoke Responsibly
  #7 (permalink)
Old 11-05-2009, 08:11 PM
Pete,
you are correct , I'm installing the 6.0 ic in a 7.3 . I need to slow down and think of my words better . as a matter of fact I was under the truck when you posted . can you recall what you did with the oil cooler ?
thanks
  #8 (permalink)
Old 11-05-2009, 08:17 PM
7.3 Rocket's Avatar
of RiffRaff
Quote:
Originally Posted by airassaultinfantry1 View Post
Pete,
thanks
For my 6.0 IC install I actually had help from another FTE member. My trans cooler lines were in the way so we just snapped the bracket that held them in place and pushed them down a bit and it slipped right in place. I assume you're talking about transmission cooler when you say oil cooler? That's the only thing I can think of that would be in the way of your IC.
__________________
Smoke Responsibly
  #9 (permalink)
Old 11-05-2009, 08:20 PM
Pocket's Avatar
Pocket Pocket is offline
Pocket is a splendid one to behold Pocket is a splendid one to behold Pocket is a splendid one to behold Pocket is a splendid one to behold Pocket is a splendid one to behold Pocket is a splendid one to behold Pocket is a splendid one to behold
Yep, that tiny little cooler is the trans cooler.
__________________
Curtis
2002 F-250 PSD
Best time: 15.3 @ 86.8 MPH at Bandimere - 9/10/08
Truck Pics
Quote:
The phrase "It'll make a turd" is not considered a compliment when referring to the quality of dinner.
  #10 (permalink)
Old 11-05-2009, 08:21 PM
yes trans cooler . This is my first time ever in part of the truck . you would know more than me . do recall where you or you remounted it ?
  #11 (permalink)
Old 11-05-2009, 08:24 PM
7.3 Rocket's Avatar
of RiffRaff
All I had to do on my late 99 was push the lines going from the trans to the trans cooler and back to the trans down a bit and it all slid into place without any other modification.
I don't know if it's different on other years as I've only done it on mine and I've never seen a 6.0 IC done without a 6.0 trans cooler on any other years.
__________________
Smoke Responsibly
  #12 (permalink)
Old 11-05-2009, 08:25 PM
Pocket's Avatar
I had to push mine down to make the intercooler fit. The 6.0L I/C is taller, so it hits the lines on the top of the trans cooler. You can unbolt it and drill new mounting holes for it to make it fit.
But it does fit so much better if you upgrade the trans cooler from a 6.0L truck as well. It bolts right up, but it doesn't interfere at all with the intercooler. Plus the 6.0L trans cooler is massive compared to the 7.3L one. Much nicer for keeping trans temps in check.
__________________
Curtis
2002 F-250 PSD
Truck Pics
  #13 (permalink)
Old 11-05-2009, 08:26 PM
thanks to all
  #14 (permalink)
Old 11-05-2009, 08:42 PM
makomaker's Avatar
makomaker makomaker is offline
makomaker is gaining momentum as a positive member of FTE. makomaker is gaining momentum as a positive member of FTE.
to those that have upgraded to 6.0 IC, is there a noticeable difference in EGT's and is it a worthy mod?
__________________
Jay
'02 F350 DRW 4x4. 6637. THE DP Tuner. Isspro gauges. MBRP 4". HPX. AIH.
LSU National Champs 1958 2003 2007
[SIGPIC][/SIGPIC]
We contend that for a nation to tax itself into prosperity is like a man standing in a bucket and trying to lift himself up by the handle.-Sir Winston Churchill
  #15 (permalink)
Old 11-05-2009, 08:46 PM
Riffraff Performance's Avatar
Riffraff Performance Riffraff Performance is online now
Platinum Sponsor
Riffraff Performance has a great reputation on FTE. Riffraff Performance has a great reputation on FTE. Riffraff Performance has a great reputation on FTE. Riffraff Performance has a great reputation on FTE. Riffraff Performance has a great reputation on FTE.
Quote:
IMO, it is worth it if you get one cheap, but I wouldn't pay more than about $150 for it though.
__________________
Clay
Riffraff Diesel: Contact Us
Diesel O-Rings by Guzzle
Riffraff Facebook Page
Parts Guy Ed - The one and only choice for OEM Parts
Tags
2001 , 60 , 73 , 73l , boot , diesel , ford , instal , intercoler , intercooler , remove , turbo , van
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
