Im posting this thread as I dont want to hijack another about a similar issue. As I stated in the other thread, I have swapped ignition modules cuz the old Duraspark unit finally gave out. So I pull out my spare NAPA (Echelin) brand that I've had for quite awhile and plug it in. Boom bada bing........problem solved, right??
Well....almost. Yes it runs and starts, doesn't shut itself off, but it doesn't feel the same. Just doesn't seem to have the extra oomph it had and I've also noticed its abit more cold blooded in the morning as it seems to take a little more throttle-age to keep it running. So....is it possible there is an internal difference between the two brands??
IIRC.....I found the Duraspark box at the local Pull-A-Part some years ago. I had the NAPA box from when I was having my ignition problems on a road trip up in the mounains on a cold wet November weekend looking for a %#$@
X-mas tree, I remember shelling out $60 for the module. So maybe a more up-to-date Ignition mod. is in my future?????
__________________
Edelbrock Intake, Carter 625 carb, Comp Cams 268 bumpstick, Crane BBC roller tip rockers, Dynomax headers, Summit Turbo mufflers, 2 1/2in Rancho lift, 33x12.50 BFG All Terrain TA KO's, TFI coil, Taylor wires, Hayden fan clutch, and no "M" in 400.
I just priced a module at Napa for $26, then they had another brand for $64. I never heard of anyone noticing a performance difference in the modules before as you mention, but I guess it is possible(?). I know my spare is going behind the seat so I don't get stranded.
__________________
Harold
Molly Hatchet: No guts, No Glory
Thanks. My local NAPA sold me one for $26 plus tax. I finally got the new one plugged in last Sunday and I'm happy to report all is better. No weird starting issues, so there was some sort of internal difference. I'm throwing the old one in the trash and getting a new one to keep as a spare.
__________________
I bought an aftermarket unit from CarQuest and the plug locking fingers broke off the first time it was plugged intl the wiring harness. It otherwise worked fine. The plastic connectors were too Brittle.
Bullitt390,Thanks for the info on Rock Auto. I know better than to go to the dealer unless I absolutely have to. I've seen other members refer to it as the
"stealer" haha Nice pic of your inner fender and module.
__________________
1U2Z12199AA replaced D9VZ12A199A & D6AZ12A199A / Marked: D6AE-12A199-A1A or -AIB, or -A2A, or -A2B / Marked: D8VE-12A199-A1B, or -A1C, or -A2B, or -A2C.
This module was used from 1976 into the 1990's, except on some 1977/79 vehicles sold new in CA.
----------------------------------------------------------------------------------------------- CA vehicles only
D7AZ12A199A .. DuraSpark Ignition Module - RED (Motorcraft DY204) / Obsolete / Used on some 1977/79 CA vehicles only.
D9AZ12A199B .. DuraSpark Ignition Module - BROWN (Motorcraft DY249A) / Obsolete / Used on some 1979 CA vehicles only.
__________________ Bill / Retired Ford Partsman (1962/97) / SoCal Chapter Member.
Part Number Research: Trucks: 1928/2000 // Cars: 1928/79.
1934 Packard V12 Convertible Victoria // 2008 Fusion S // 2008 Edge SEL.
Thanks for the info Bill, when mine dies, I'll throw my freebie on and make sure I get a good one because I know me and aggravation dont get along very well!!
__________________
Harold
I don't know why you guys don't get rid of the box and just use a normal distributer problem solved forever.
What is a NORMAL distributor? I had more problems running a Mallory Unilite than I ever had with the Durspark. At the very least, if a module or pick-up goes out and you're in the middle of tin-buck-too it shouldn't be a big deal to pick up something, even a Chinese made unit, to get from point A to point B.
Try that with a Mallory, MSD or Accell. I see just as many horror stories on those techno-wonders as I do with the Duraspark.
On top of all that, most of the problems are attributed to TWO things: An ORIGINAL module or pick-up gives up the ghost (which were to known to be defective) or an aftermarket POS quits.
You don't hear too many problems once the defective junk is replaced with quality Motorcraft parts.
before i rebuilt my motor i used a points distributer, back in the day that was the norm and never had problem. when i rebuilt the motor i used a unilite never touched it again.
