Go Back   Ford Truck Enthusiasts Forums > Older, Classic & Antique Trucks > 1987 - 1996 F150 & Larger F-Series Trucks
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
1987 - 1996 F150 & Larger F-Series Trucks 1987 - 1996 Ford F-150, F-250, F-350 and larger pickups - including the 1997 heavy-duty F250/F350+ trucksSPONSORED BY:
  #1 (permalink)
Old 11-05-2009, 04:57 PM
PonchoV8 PonchoV8 is offline
Garage is empty, add now
PonchoV8 is starting off with a positive reputation.
Fuel pump wiring?
My pump (one inside the frame) is hard wired hot to the fuse panel--88 F350 dual tank 4x4 351, 5 spd. I got under it today to find two wires that are cut and hanging out of the trucks wire harness. One is RED w/ BLK stripe, one is BLK only.
The RED w BLK has momentary 12+V power when key is turned on with multimeter's black term touched to the frame. It seems to be about one second and then goes dead. No longer than that. The BLK sees no voltage potential. If I connect the multimeter's terms to the RED/BLK and BLK wires, I see the same 12+V power on for a moment.
This appears to be the original fuel pump wiring. Can someone verify the colors for me and that it powers down after the initial pressure up at KEY ON?
Thanks,
  #2 (permalink)
Old 11-05-2009, 05:11 PM
WhiteZombie's Avatar
WhiteZombie WhiteZombie is offline
WhiteZombie is starting off with a positive reputation.
the reason your power could be shutting down after a second is because the wire is cutt and the computer is not telling the power to the pump to stay on. i recently had a similar problem when i went from efi to carburated in my truck. my stock pump would turn on then turn rite off because i was not running a computer to tell it to stay on. i hope this helps and you get your truck running rite
  #3 (permalink)
Old 11-05-2009, 05:14 PM
Thanks. Can you tell me if yours had the same colored wires? Red with BLK stripe and BLK only.
  #4 (permalink)
Old 11-05-2009, 05:34 PM
subford's Avatar
subford subford is offline
subford is a splendid one to beholdsubford is a splendid one to beholdsubford is a splendid one to beholdsubford is a splendid one to beholdsubford is a splendid one to beholdsubford is a splendid one to beholdsubford is a splendid one to behold
It sounds like the Black/Red stripe wire is working right for an 88 E-series but it should be a BR/W on an 88 F-series.
It should have power on it for one second when the key turned on.
The black wire is a ground.
Here is a diagram if you have two tanks.
Click the image to open in full size.
__________________
95 F150 302 4R70W EB EX-CAB
94 F53 460 E4OD COACHMEN SANTARA RV
83 F150 Flare Side 351W AOD
77 F250 351M-2V NP 435/4 Speed 4X4
subford@gmail.com
Bill K, Kansas Chapter
  #5 (permalink)
Old 11-05-2009, 05:41 PM
F150xlt F150xlt is offline
F150xlt has a good reputation on FTE.F150xlt has a good reputation on FTE.F150xlt has a good reputation on FTE.
Subford beat me to it.
Manual shows the wire is Pink/Black which is 12 volts for the frame rail mounted pump and the same wire turns into a Red/white wire at the Fuel tank slector switch which then feeds the front intank pump by a Red wire and the rear intank pump by a Brown/White wire..
Black is ground.
If you only have a single tank. The Pink/Black wire is 12 volts for both the frame rail and intank pump.
The reason you only see 12 volts for 1 second is the computer doesn't see any reference pulses coming from the distributor. This indicate the engine is not running or being cranked by the starter so it disables the fuel pump relay.
  #6 (permalink)
Old 11-05-2009, 06:08 PM
Thanks guys. Yep, it is PINK/blk after looking again. Those are very helpful schematics. I need to get a service manual for this thing I guess.
Awesome, now I can wire it as it should be. One more item off the list I hope.
  #7 (permalink)
Old 11-05-2009, 06:46 PM
if you still have problems you can hard wire your fuel pumps to a switch then you just gotta turn it on and off manually this eliminates any guessing with wires and i still have my notes from when i did mine if this becomes your only option.
  #8 (permalink)
Old 11-05-2009, 09:07 PM
RobertWetherbee RobertWetherbee is offline
RobertWetherbee is starting off with a positive reputation.
inertia cut off switch
Can anyone tell me where this inertia fuel switch is located on a 2000 F250, 7.3 diesel, extended cab 4x4?
  #9 (permalink)
Old 11-06-2009, 05:54 AM
subford's Avatar
Quote:
It is located Behind RH cowl panel in the cab.
__________________
subford@gmail.com
  #10 (permalink)
Old 11-06-2009, 03:50 PM
Well, the wiring is still good it appears. I used the cut wires and it powered the pump for a second and quit. I started it and it runs. It's idling like it should right now to be sure it doesn't shut down. Now I'm on to the issue of the wrong transfer case that's in place.
  #11 (permalink)
Old 06-23-2012, 05:24 PM
scorpios_lace scorpios_lace is offline
scorpios_lace is starting off with a positive reputation.
i need help with the i think its the fuel sending unit wiring i have 4 wires black, orange,red, and blue the connector is flat black and square and fits over an oblong opening on the top of the fuel pump can neone help thanks i have a 1993 f-150 300-6 2wd 2 tanks i am working on the front tank and the fuel guage not working
  #12 (permalink)
Old 06-23-2012, 05:56 PM
subford's Avatar
Here is a diagram of your FDM.
__________________
subford@gmail.com
  #13 (permalink)
Old 12-03-2012, 10:25 PM
brettcp brettcp is offline
brettcp is starting off with a positive reputation.
Does any one have the wiring giagram for a 2000 f250 v10,I need to know in and out colors for testing before i remove the tank
  #14 (permalink)
Old 12-03-2012, 10:43 PM
rla2005's Avatar
rla2005 rla2005 is online now
2004 Ford Excursion
rla2005 is a name known to allrla2005 is a name known to allrla2005 is a name known to allrla2005 is a name known to allrla2005 is a name known to allrla2005 is a name known to all
Quote:
You might have better luck in the 1999 and up Super Duty forum: Super Duty & Heavy Duty - Ford Truck Enthusiasts Forums
  #15 (permalink)
Old 12-04-2012, 07:46 AM
subford's Avatar
In case you do not find it over there.
__________________
subford@gmail.com
Tags
460, 87, colors, direct, dual, f150, f250, ford, fuel, pump, relay, series, tank, volts, wire, wiring
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
