Go Back   Ford Truck Enthusiasts Forums > Older, Classic and Antique Trucks > 1973 - 1979 F-100 And Larger F-Series Trucks
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
1973 - 1979 F-100 And Larger F-Series Trucks Discuss the Dentsides Ford Truck SPONSORED BY:
Is F-150 Still King?
  #1 (permalink)
Old 11-05-2009, 05:30 PM
BlueOval390's Avatar
BlueOval390 BlueOval390 is offline
BlueOval390 is starting off with a positive reputation.
Carb/Timing Issues
I'm working on my '73 Ford F-100 with a 390 and have had the carburetor recently rebuild by a buddy and while he was putting it back on the truck he also noticed that the points on the distributor were worn and told me to replace them before he could do the final adjustments. Well did that, and now I can't keep the truck running for more that a minute or two it cuts out. The timing is all the way advanced, it's the only way it starts. Any help woudl be greatly appreciated! Carb is a Holley 4160
  #2 (permalink)
Old 11-05-2009, 08:31 PM
TriumphTune's Avatar
TriumphTune TriumphTune is offline
1978 Ford F-150
TriumphTune is starting off with a positive reputation.
Did you set the point gap? Have you put a light on it to see where the timing is?
Just a few quick thoughts.
Josh
  #3 (permalink)
Old 11-05-2009, 09:39 PM
restoringmy46 restoringmy46 is offline
restoringmy46 is starting off with a positive reputation.
I did the same thing. Make sure your # 1 piston is up anf the rotor button is pointed to the # 1 on the distributor cap. If it still does this rotate the motor again till number one piston is up and see where the rotor button is at. You might have to take your distributor out and make it point torwards #1 on the distributor. Dp check your points to. I had a 302 that did the same thing and it drove me crazy.
Tags
carb , ford , set , timing
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
