Go Back   Ford Truck Enthusiasts Forums > Newer Light Duty Trucks > Expedition & Navigator
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
Expedition & Navigator 1997 - 2002 and 2003 - 2006 Ford Expedition and Lincoln Navigator SPONSORED BY:
Is F-150 Still King?
  #1 (permalink)
Old 11-05-2009, 05:20 PM
mikecox1 mikecox1 is offline
mikecox1 is starting off with a positive reputation.
Axle strength
Is the rear axle housing on a 2000 exp strong enough be used as a location to put my floor jack when jacking up my exp? Many times when I have done work that require the removal of the rear wheels I have wished that I didn't have to raise the frame of the truck high enough to get the tires off the ground. My driveway is on a slant so raising my Exp as little as possibe when doing a rear brake job would be an advantage. If I could jack it up using the axle there would be little elevation change to the body of the truck.
  #2 (permalink)
Old 11-05-2009, 06:36 PM
alloro alloro is online now
alloro is gaining momentum as a positive member of FTE. alloro is gaining momentum as a positive member of FTE.
I've done it without any issues. or problems.
__________________
If you like the advice you get, be sure and click the left red "Add to Reputation" button
to the right of the word "permalink" at the top right of the poster's message window.
  #3 (permalink)
Old 11-05-2009, 08:16 PM
powerram50 powerram50 is offline
powerram50 is starting off with a positive reputation.
i have done it plenty of times at work,never had a problem.
__________________
99 expedition xlt,5.4,3.55 lsd,leather,17's,ect...
  #4 (permalink)
Old 11-06-2009, 08:06 AM
Big Greenie Big Greenie is offline
Big Greenie is starting off with a positive reputation.
Isnt the axle tube the factory jacking point? I use the axle or the bolt boss area of the control arm. It is MUCH safer to lift the axle to remove a wheel than jacking the body up. This is definately the way it should be done. The axle tube is plenty strong enough for this.
__________________
1999 Expedition XLT, big and green, 5.4, 4x4, 285/70-17 Dunlop MT's, factory skid plates, magnaflow muffler.
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
