Go Back   Ford Truck Enthusiasts Forums > Performance, Engines and Troubleshooting > Modular V8 (4.6L, 5.4L)
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
Is F-150 Still King?
  #1 (permalink)
Old 11-05-2009, 02:29 PM
verne56 verne56 is offline
verne56 is starting off with a positive reputation.
I keep trying
I have 97 4.6 that starts hard when outside temps under 40degrees.No codes.Plenty of power otherwise.Replaced IAC @ MAF sensor. It takes 4-5 starts to get it going when cold and I have to jiggle the accelerator to get it going.Vehicle has 40K on it.
What's next?
  #2 (permalink)
Old 11-06-2009, 08:57 AM
l-m tech l-m tech is offline
l-m tech is gaining momentum as a positive member of FTE.
try cycling the key 2 or 3 times to see if it helps.could be a leaking fuel pup bleeding of pressure.
__________________
ASE MASTER TECH FORD SENIOR MASTER TECH
  #3 (permalink)
Old 11-06-2009, 11:29 AM
Fuel pump pressure was checked and filter replaced by garage I took it to. They said that they didn't have the time to chase down the problem after I told them they hadn't fixed it.
Just checked the seal where MAF sensor goes to air filter housing and found gasket sticking out into air flow a little bit so I fixed that. But I still won't know if I fixed it until tomorrows cold start. I'd clean the EGR but I would have to have very small hands to get at it as its under everything.
Thanks for suggestion.
  #4 (permalink)
Old 11-17-2009, 03:09 AM
55 f350's Avatar
55 f350 55 f350 is offline
1953 Ford F-100
55 f350 is starting off with a positive reputation.
i'll opt for the fuel pump going away myself . had another brand vehicle i bought really cheap , a 1/2 ton , to beat on for awhile that had that same issue . a new pump assembly and a lot cussing later and walla . no more hard starts or starting fluid to get it to fire .by the way to those of you with one of the late 80's through 97 gm trucks for whatever reason , heres a tip . cut a hole in the bed above where the pump is , neatly of course . put some hinges on it and a zsus fastener or ???? and you got an easy instant access trap door to change the pump assembly in about 20 minutes ............ wanna know how i figured that one out ??????? let's just say da-- junk gm's ..... if it hadn't been cheap i'da spared myself the grief !!!!!!!!!!!!!!!!!!!! p.s the sensor for the maf in my 95 bird had gone away in mine and made my 4.6 a little cranky and rough running . maybe check it . after some investigating / research / cross referencing i found the sensor in my 91 bird parts donor for my 53 { 5.0 equipped } was the same thing and walla a free fix ....................
__________________
thats because were all opinionated bullcrap artists looking for somewhere to espout our views and show the world how much we { dont } know especially to newcomers. were on a mission to impress you and make you beleive we are all knowing !
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
