Go Back   Ford Truck Enthusiasts Forums > Newer Light Duty Trucks > Expedition & Navigator
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
Expedition & Navigator 1997 - 2002 and 2003 - 2006 Ford Expedition and Lincoln Navigator SPONSORED BY:
Is F-150 Still King?
  #1 (permalink)
Old 11-05-2009, 12:35 PM
ExpyCanuck ExpyCanuck is offline
ExpyCanuck is starting off with a positive reputation.
Cruise control issue
Hi, I have a 2004 EB. A year ago my cruise stopped working. I've had it in the shop but the tech couldn't find the issue. The brake lights work fine but I do have an issue with the trailer harness wiring which I bypassed but I don't think that is the culprit. I recently pulled the servo out and discovered it was seized...full of rust/water.dirt you name it. I got a new (used) servo and put it in two days ago thinking it would work but nothing. The cable take-up and spring moves freely, cable to throttle is free. I have gone through a procedure I found regarding the KOEO diagnostics but it fails after the "resume" button press. I am not fully sure the diag is correct as it states it is for a servo with a 10-pin connector. My servo is only a 6-pin. Does anyone know where I can find a schematic for the cruise? Btw, when driving, if I engage the cruise system, it functions normally in regards to the indicator coming on and off with the associated buttons/brake pedal---the only thing it doesn't do is engage the pedal/throttle. Thanks 4 any ideas.
  #2 (permalink)
Old 11-05-2009, 02:29 PM
alloro alloro is offline
alloro is gaining momentum as a positive member of FTE. alloro is gaining momentum as a positive member of FTE.
I can't remember off the top of my head if these servos have a vacuum line. But if they do, your's could be clogged.
__________________
If you like the advice you get, be sure and click the left red "Add to Reputation" button
to the right of the word "permalink" at the top right of the poster's message window.
  #3 (permalink)
Old 11-06-2009, 08:56 AM
No, no vacuum line- fully electronic. I keep reading that it's either the switches, speed sensor, or brake switch. I would think that if it were the speed sensor the speedo would malfunction. And, the brake does disengage the cruise (as far as the display is concerned) so I'm leaning towards the switches. The KOEO routine indicates that the switches are at fault but like I said, the procedure states it is for a 10-pin servo w/o SCP. Mine is a 6-pin so I assume I do have SCP so I don't know for sure if the procedure is applicable. I'm tempted to take it back to the dealer but I know they'll troubleshoot for 8 hrs with no resolution again. Why is it so hard to get drawings online???
  #4 (permalink)
Old 11-07-2009, 08:23 AM
projectSHO89 projectSHO89 is offline
projectSHO89 has a good reputation on FTE. projectSHO89 has a good reputation on FTE. projectSHO89 has a good reputation on FTE.
Try these but make certain your pop-up blocker is turned on.
http://www.mediafire.com/file/iqzedj1ed44/2004 Expedition VSC Schematic.pdf
http://www.mediafire.com/file/lzyagdoodwy/2004 Expedition VSC Diagnostic.pdf
__________________
If your original owner's manual is missing, download a soft copy from www.fleet.ford.com under the MAINTENANCE tab.
Think about it: Ignorance can be addressed through education but you can't fix stupid! ...apologies to Ron White
  #5 (permalink)
Old 11-09-2009, 08:28 AM
Thanks alot. This is exactly what I was looking for. Wish I could send you a beer.
  #6 (permalink)
Old 11-09-2009, 10:04 AM
You can.
You Have Received A Virtual Beer! - A free virtual gift ecard from Dobhran's Greetings
__________________
  #7 (permalink)
Old 11-10-2009, 09:14 AM
04markIII's Avatar
04markIII 04markIII is online now
04markIII is starting off with a positive reputation.
fyi, mine had a cc problem when i bought it. replaced just about everything. there is a brakelight switch, and a cc turn off switch. it was the latter. pita.
__________________
2003 Ford Expedition: 5.4L, harley supercharger, 6lb lower pully, c&l plenum, k&n cai awaiting install, LFP SBTB, FTSP, Magnaflow 3" catback, 2006 F150 20's, 2800 stall converter, Hawk brake pads, Drilled rotors, Eclipse AVN-5510, white face gauges, cobalt c2 boost gauge, 339 rwhp, 440 rwtq(dynoed with oem 17's)
Tags
02 , 6pin , control , cruise , expedition , ford , wont , work
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
