Jim
The issue is more about using the system with the stancor relay.
Its not a plug and play install.
"We can throw a couple diodes in there (center stud to sensing wires ) which will give each side a 0.70 volt drop to try and fool PCM.
Resistors.
It can be done but you have to access the wiring at another location due to the excessive heat at
the GPR. I would spend my time on a correct install. Its less work.
Bill
__________________
97 4X4 PSD Quigley
