Go Back   Ford Truck Enthusiasts Forums > Performance, Engines and Troubleshooting > Ford Inline Six, 200, 250, 4.9L / 300
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
Is F-150 Still King?
  #1 (permalink)
Old 11-05-2009, 10:47 AM
F-250 restorer's Avatar
F-250 restorer F-250 restorer is offline
F-250 restorer is starting off with a positive reputation.
dip stick location
I recently pulled a core engine from a '75 van. The dip stick came from the oil pan. The hole just above the drivers motor mount has been plugged. Since the pan dip stick is broken off, I don't want to have to buy a new one. The engine I am currently using has the dip stick in the block, and I thought I would covert the core/new rebuilt to that location.
Has anyone tapped out the plug? Is it possible, or must it be drilled?
  #2 (permalink)
Old 11-06-2009, 09:11 PM
300 Buster's Avatar
300 Buster 300 Buster is offline
300 Buster is starting off with a positive reputation.
I have an '83 300 six that I pulled from a F150 and it has the dipstick in the block.At the base of the tube it looks like there is a nut,like maybe a threaded collar.Maybe you could get one like that.Does the plug look like it screws out?
__________________
'96 F150 4.9IL 5 Speed Stick
  #3 (permalink)
Old 11-06-2009, 09:20 PM
The hole at the motor mount looks at first like it is still there. I had to take a wire and poke in it to know it was plugged. The wire went in about 1/2". It was covered with oil so I couldn't examin it closely. I'm hoping it is a simple insert popped in there at the factory that can be tapped out from up inside the block. When it is clean from the hot tank I'll know more.
I found two like it at the junk yard, so it's not some backyard plug job.
Tags
300 , dip , dtick , ford
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
