Go Back   Ford Truck Enthusiasts Forums > Diesel > 1999 - 2003 7.3L Power Stroke Diesel
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
1999 - 2003 7.3L Power Stroke Diesel SPONSORED BY:
Is F-150 Still King?
  #1 (permalink)
Old 11-05-2009, 10:13 AM
rtazz17's Avatar
rtazz17 rtazz17 is offline
2002 Ford F-350
rtazz17 is starting off with a positive reputation.
Brake line fluid flush
Any brand fluid? Whats a good fluid to go with?Theres nothing special to do to flush the fluid in these trucks right? Same as any other vehicle right?And any idea what size hose to fit over the bleeder valve on caliper?
__________________
Rob-2002 f350 crew cab w/82000 miles..4 inch mbrp xl series stainless steel exhaust,S & B cold air intake,bilstein shocks,skyjacker dual stabilizer,285/75/16 firestone destination a/t,2.5 inch hanger/shackle leveling kit,disellite a/c cold mod.,back up camera,Pillar isspro guages pyro,tranny,boost,OBA, DP Tuner(80E no codes,no start,drive thru),foil delete,CCV mod,JW valve body,wicked wheel,08 aluminum rear diff cover coming soon and then who knows but something!!!
  #2 (permalink)
Old 11-05-2009, 10:22 AM
miller_feed's Avatar
miller_feed miller_feed is offline
Hook it, I'll pull it.
miller_feed has much to be proud of miller_feed has much to be proud of miller_feed has much to be proud of miller_feed has much to be proud of miller_feed has much to be proud of miller_feed has much to be proud of miller_feed has much to be proud of miller_feed has much to be proud of miller_feed has much to be proud of
I used a DOT-3 brake fluid and put a hose on the bleeder, don't remember the size, then opened the bleeder at the rear passenger and let it gravitate out while keeping the bowl full. Then went to the other calipers and did the same.
__________________
RICK, PAA MEMBER #4
2001, F-350, DRW. CC. LWB, 4X4, LARIAT,
MODS: 6637 W/Pete's cover, BTS-VB, DP-TUNER LIVE- stock, HI. 40t, 60t, decel, 80t, 80e, 140s, OBA, 203*, billet housing, MBRP 4" SS, Isspro 3 gauge kit, Zoodad, Foil delete, TN-BB turbo, Bellowed up pipes, HPX, TRU-COOL cooler, SS Stage II injectors, and the Chris-fifty.
  #3 (permalink)
Old 11-05-2009, 10:30 AM
rtazz17's Avatar
2002 Ford F-350
Quote:
So No need to pump brake pedal? Gravity will do it?
__________________
  #4 (permalink)
Old 11-05-2009, 10:31 AM
PaysonPSD's Avatar
PaysonPSD PaysonPSD is offline
Support FTE
PaysonPSD has much to be proud of PaysonPSD has much to be proud of PaysonPSD has much to be proud of PaysonPSD has much to be proud of PaysonPSD has much to be proud of PaysonPSD has much to be proud of PaysonPSD has much to be proud of PaysonPSD has much to be proud of
Brake Fluid Flush Made Easy BY Fat Diesel. Great write-up. Thanks Andy.
Edit: I did mine this way but used compressed air at about 10 psi attached to a schrader valve I mounted on an old brake reservoir cap. I didn't have access to a speed bleeder. Couldn't get it to seal very well but it was faster then gravity. Had my neighbor pump the brake after fluid flush just to be sure I got all the air out at each caliper.
  #5 (permalink)
Old 11-05-2009, 10:36 AM
Quote:
Yes, gravity will do it. It may take a little longer then the link Robin has but it worked great for me. I just let it drain and drain, with beer between filling the bowl.
__________________
RICK, PAA MEMBER #4
  #6 (permalink)
Old 11-05-2009, 10:59 AM
Izzy351's Avatar
Izzy351 Izzy351 is online now
Getting Faster...
Izzy351 has much to be proud of Izzy351 has much to be proud of Izzy351 has much to be proud of Izzy351 has much to be proud of Izzy351 has much to be proud of Izzy351 has much to be proud of Izzy351 has much to be proud of Izzy351 has much to be proud of
Home made version of the brake bleeder:
About to do mine too. I'm using Valvoline syn DOT 3 & 4 rated fluid though.
__________________
  #7 (permalink)
Old 11-05-2009, 11:37 AM
Ponyboychris's Avatar
Ponyboychris Ponyboychris is offline
Be Thankful...
2002 Ford F-350
Ponyboychris is a name known to all Ponyboychris is a name known to all Ponyboychris is a name known to all Ponyboychris is a name known to all Ponyboychris is a name known to all Ponyboychris is a name known to all
The wife and I did mine. i didn't have the power bleeder deal. She pumped the pedal, I opened and closed the valves.
__________________
Chris
2002 F350 XLT, 7.3L CC 4x4, LWB, SRW, Autometer Ultralites, DP TUNER, BTS Trans, 6.0 tranny cooler, AIS w/zoodad, Warn Hubs, 4" MBRP exhaust, '08 rear end cover, Foil Delete, Heated Tow Mirrors, AIH Delete, Homemade CCV mod., Bilsteins.
The Silver Bullitt PAA# 24
  #8 (permalink)
Old 11-05-2009, 11:42 AM
PaysonPSD's Avatar
Support FTE
Quote:
Very nice Joe. Gives me some ideas I can use to get my compressed air method to work without leaking. Thanks for sharing.
  #9 (permalink)
Old 11-05-2009, 12:46 PM
Izzy351's Avatar
Getting Faster...
Quote:
You just don't want to use more than about 5 or 10 psi...
__________________
  #10 (permalink)
Old 11-05-2009, 03:09 PM
aldridgec's Avatar
aldridgec aldridgec is online now
aldridgec has a very good reputation on FTE. aldridgec has a very good reputation on FTE. aldridgec has a very good reputation on FTE.
Most brake fluid is synthetic now. Gravity bleeding can occasionally cause a problem if an air bubble gets sucked in and works it's way up the line.
__________________
Chris
ASE Certified Master Automotive Technician
Current Vehicles:
2002 F-250 7.3L PSD 4x4 XLT
2002 Sunset Orange Mettalic WS6 Trans Am Convertible
"Maybe is for those who lack skill"
  #11 (permalink)
Old 11-05-2009, 03:29 PM
PaysonPSD's Avatar
Support FTE
Gotcha Joe. I usually try to dial it it at about 7 PSI.
  #12 (permalink)
Old 11-05-2009, 05:44 PM
BadDogPSD's Avatar
BadDogPSD BadDogPSD is offline
BadDogPSD is starting off with a positive reputation.
Anyone ever use a vacuum bleeder? My old neighbor was a retired Porsche mechanic and swore by them. He offered to let me use his once, but the fittings didn't work with the fittings I had on my compressor/air hose.
__________________
Craig
1997 F250 4x4 Crew Cab PSD, Dana 60 conversion with SD 'V' Code front springs & SKY RSK. SD 'B' Code rear springs adding other goodies as time and money permits
  #13 (permalink)
Old 11-07-2009, 07:34 PM
Fat Diesel's Avatar
Fat Diesel Fat Diesel is offline
Fat Diesel is gaining momentum as a positive member of FTE. Fat Diesel is gaining momentum as a positive member of FTE.
No problem! Just flushed again for the 5th time as I approach 250K.
Joe- Nice homemade one!
__________________
Andy
Early 99 F250 PSD 4x4 CC 6spd ----- CCV Mod, 6637 Filter, DP Tuner Chip, ITP Fuel Sys, Dahl Filter, Cat Delete, BD 4" Cat Back, 203* 230,000+ Miles
  #14 (permalink)
Old 11-07-2009, 07:39 PM
Izzy351's Avatar
Getting Faster...
It's good to have friends with metal working tools...
__________________
  #15 (permalink)
Old 11-07-2009, 08:44 PM
rtazz17's Avatar
2002 Ford F-350
Got it done last night. Tried the gravity bleeding but unless i was willing to wait 4 hours it wasnt gonna work. Wife pumped while I turned the bleeders. Brakes really needed a bleed too. My truck stops soooo much quicker.... Thanks
__________________
Tags
2004 , 73 , automotive , brake , company , dot , f250 , f350 , fluid , flush , ford , fords , lines , motor , psd
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
