Go Back   Ford Truck Enthusiasts Forums > Older, Classic and Antique Trucks > 1961 - 1966 F-100 And Larger F-Series Trucks
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
1961 - 1966 F-100 And Larger F-Series Trucks Discuss the Slick Sixties Ford Truck SPONSORED BY:
Is F-150 Still King?
  #1 (permalink)
Old 11-05-2009, 10:02 AM
89ford73's Avatar
89ford73 89ford73 is offline
89ford73 is starting off with a positive reputation.
65 ford f-100 diesel??? owner manual says
i was wondering if anyone has ever looked in their owners manual and seen the part about "priming the fuel system"? and has anyone here ever actually seen a factory diesel in one of these fords? was it only for sale in foreign countries? military? what kind of diesel would it actually have been? ford?
__________________
94 ford 4x4 with a 5.9 12v cummins propane inject, de-fuel plate and governor springs thrown in the trash can. 3.55 rears 12.5-35 bfg mudders. top speed "faster than you wanna drive it"
89 f-150 recently swapped in 95' 12v 5.9 cummins-np4500 5 speed, 2.73 rear top speed 111 at 3,000 rpms. 97 f250 powerstroke automatic 2wd new daily driver. for sale 89-97 ford 3/4 ton rear ends parts or whole 3.55 or 4.10 ratios. my 97 ford psd
  #2 (permalink)
Old 11-05-2009, 07:40 PM
banjopicker66's Avatar
banjopicker66 banjopicker66 is offline
In Occupied CSA
banjopicker66 is gaining momentum as a positive member of FTE. banjopicker66 is gaining momentum as a positive member of FTE.
That would have been a Ford 220 diesel, available in the P-series trucks.
Ford would probably have let you special order it in a F-100.
The 330 Ford was used in the larger C and N series trucks.
Several Cummins and 2cycle Detroit diesels were offered, but only in the larger trucks.
__________________
1966 F-100 460, C6, power disc brakes, power steering
2000 F-250 SuperDuty 7.3L Diesel 150K, pillar gauges, oil drain valve - Infected with PMS.
He is no fool who gives up what he cannot keep to gain what he cannot lose! (cf Mt 16: 25, 26)
Deo Vindice!
  #3 (permalink)
Old 11-05-2009, 10:10 PM
89ford73's Avatar
ok, i remember the manual saying something about the p-series trucks. i rebuilt a 330 ford once. i thought it was a 352 but it wasn't. 460 in a 66 ford f-100?? wow. thats about all i got to say bout that. how far can you smoke the tires before it gets traction?
__________________
  #4 (permalink)
Old 11-06-2009, 07:02 AM
In Occupied CSA
Actually, I have a 2.75 geared ratio for better mileage, so it doesn't lay rubber well. Besides, with 28 spline axles, any attempts launch it could break the axles shafts. Since Ford isn't making those anymore, I figure I better keep the ones I have!
__________________
Deo Vindice!
  #5 (permalink)
Old 11-06-2009, 07:12 AM
In Occupied CSA
By the way, did you rebuild a 330 diesel or a 330 otto?
The 330 gas engine is an FT design.
But Ford also produced a 330 diesel.
I know little about the 330 diesel, maybe NumberDummy can chime in with more details.
__________________
Deo Vindice!
  #6 (permalink)
Old 11-07-2009, 08:09 AM
NumberDummy's Avatar
NumberDummy NumberDummy is offline
Ford Parts Guru
NumberDummy has a superb reputation NumberDummy has a superb reputation NumberDummy has a superb reputation NumberDummy has a superb reputation NumberDummy has a superb reputation NumberDummy has a superb reputation NumberDummy has a superb reputation NumberDummy has a superb reputation NumberDummy has a superb reputation NumberDummy has a superb reputation NumberDummy has a superb reputation
There is no such thing as an F100 owners manual.
If you look at your "Ford Truck Operators Manual" you will see it covers more than just F100's.
This is why that diesel engine info is there.
Diesel engines were not available in F100/350's, not even as a special order.
There's far more to it then just installing a diesel in a F100/350. The suspension is different, the trans is different, the wiring is different, the whole tamale is different.
The 1951/75 P Series Parcel Delivery is different than any other Ford truck. Ford only sold the rolling chassis complete with powertrain, the bodies were installed by others.
UPS, Bakery companies, motorhome manufacturers and etc used this chassis thru 1975. The P Series was then replaced by the Econoline Cut-Away.
First factory installed diesel engine in an F350 occured in 1983, using the "Cornbinder" 6.9L.
IHC was near bankruptcy in 1979, Ford bailed them out. The deal was that Navistar (IHC's new name) would supply Ford with diesel engines.
Banjopicker: The axleshafts are obsolete, but there's quite a few available used.
B7TZ4234A .. Axle Shaft -28 Splines / Right/Left is the same / Fits all: 1957/67 F100's with 9" rear axles.
__________________
Bill / Retired Ford Partsman (1962/97) / SoCal Chapter Member.
Part Number Research: Trucks: 1928/2000 // Cars: 1928/79.
1934 Packard V12 Convertible Victoria // 2008 Fusion S // 2008 Edge SEL.
  #7 (permalink)
Old 11-07-2009, 09:50 AM
In Occupied CSA
Hey, Thanks for the details on the axle shafts too!
However - I am using a '76 rear axle brake setup on my '66 axle housing.
To make the offset from the wider brake shoes and drums work, I am using '68 - '72 axle shafts.
__________________
Deo Vindice!
  #8 (permalink)
Old 11-07-2009, 10:02 AM
Ford Parts Guru
C8TZ4234A .. Right/Left Axle Shaft - 28 Splines / Obsolete
Fits: 1968/72 F100 except 1970/72 F100's with the H/D 9" that has a 9 3/8" ring gear...and 31 spline axleshafts.
COLLECTORS AUTO SUPPLY in Oroville WA has ONE = 800-414-4462.
No one else has any.
btw: 1968/79 F100's, some 1980/83 F100's & 1975/96 F150's have the same rear brakes (11" x 2 1/4").
__________________
  #9 (permalink)
Old 11-07-2009, 11:39 AM
IsoGrifo's Avatar
IsoGrifo IsoGrifo is offline
IsoGrifo is starting off with a positive reputation.
correct me if I'm wrong, I thought 75 was the last year of the 100 and first for the 150?
  #10 (permalink)
Old 11-07-2009, 11:57 AM
jowilker's Avatar
jowilker jowilker is offline
1966 Ford F-100
jowilker has a great reputation on FTE. jowilker has a great reputation on FTE. jowilker has a great reputation on FTE. jowilker has a great reputation on FTE.
Quote:
They were both offered some years. Ford was trying to get around some emissions when it introduced the F150.
I think maybe 83 was last year for F100.
John
__________________
In the cool still quiet hours of night, you can hear chevies rusting away.
  #11 (permalink)
Old 11-08-2009, 02:38 AM
89ford73's Avatar
ok im sorry about the f-100 owners manual thing. i rebuilt a 330 fe block truck engine. it is the same as a 352 with a smaller bore. 3-7/8 i believe instead of 4" the 2.75 ring and pinion is a good ratio. i have a 89 f-150 with a 5,9 cummins and a 2.73 mustang gear rear 8.8 it will cruize 110 all day long at 2600 rpms in od. i am building a twin turbo 12 v p-pump that will rev to 4g. i don't even want to test the top speed when i get done with that! i hope my rear end holds up. if it don't it will get a dana 80 with 3.08 gear. idk if im going to get a 5 lug wheel to fit on a dana 80, but im going to try
__________________
  #12 (permalink)
Old 11-08-2009, 08:36 AM
Ford Parts Guru
Quote:
The 330 is an FT engine, not an FE engine. The 330 engine uses a different block than a 352.
There were two different 330 FT engines.
1964/67: The 330 Medium Duty crankshaft is the same as a 352.
1968/72: The 330 Medium Duty crankshaft is same as a 360.
The 330 Heavy Duty crankshaft is the same as a 361 (FT) crankshaft.
FT engines (330 2V M/D; 330 2V H/D; 361 2V; 391 4V) share some internal parts with FE engines. But the blocks, heads, flywheels, harmonic balancers and etc. are not the same.
__________________
Tags
1966f100diesel , 65 , 73 , 97 , cummins , diesel , f1 , f100 , ford , fuel , military , number , pick , plate , retired , sale , trucks , vin
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
