Go Back   Ford Truck Enthusiasts Forums > Small Chassis Trucks > Ranger & B-Series
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
Ranger & B-Series All Ford Ranger and Mazda B-Series modelsSPONSORED BY:
Is F-150 Still King?
  #1 (permalink)
Old 11-05-2009, 09:26 AM
jowangel jowangel is offline
jowangel is starting off with a positive reputation.
94 Ranger Auto Transmission Problem
Issue started about a week ago. Was merging onto the highway and truck wouldn't shift out of 1st (auto transmission). I left off the gas and it jumped into gear. Next red light did the same thing. Me, my dad, my car friend all test drove and it just skips over 2nd gear. Fluids fine. After a week of driving it this way, it's doing the same thing (yes it didn't magically fix itself, darn!). I have to get it up to 30 mph or 35 mph and let off enough for it to shift, then ease back on. Uphills from a stop suck! It will go the whole way up to 4000 rpm if you let it, which I obviously try not to, but sometimes if you are a little too fast on the gas it'll jump back into 1st.
This same thing happened about 6 years ago to this same truck when I was a freshman in college. My dad, who is quite handy with vehicles and repair, took it to a guy who rebuilt the transmission for $750. This guy said that the 2nd gear belt was broken I believe. My dad called around and got a quote on the work and it was around $1250 to rebuild it. Well, that's more than half the value of the truck so not an option.
But the guy also said it could be the 2nd gear solenoid (?). Sorry I suck at spelling. But it would cost $60 for him to drop the pan and determine if that was an issue.
We located used trannys in the area for around $400-500 and can do the work ourselves if we rent a tranny jack.
Any ideas on what the best option is? Would the $60 to rule out what could be a cheaper $200 or less fix to replace a solenoid be worth it? Or is this an unlikely possibility?
My plan is to fix the truck and keep it, but get a cheaper fuel efficient car for daily driving to make things easier as the truck is getting older and racking up the miles. But I still need it for certain things. So we want to keep the costs of repair low, but not do a completely half-a$$ job.
  #2 (permalink)
Old 11-05-2009, 12:03 PM
g_k50's Avatar
g_k50 g_k50 is offline
1990 Ford Bronco
My Garage
g_k50 is starting off with a positive reputation.
put in the 2nd gear solenoid, if that works, fine, keep running until the next thing breaks.
If that doesn't work, find a used transmission, put the 2nd gear solenoid in it, and run it until the next thing breaks,
repeat as necessary.
I think it's unlikely that step one, replacing the 2nd gear solenoid, will fix the problem.
  #3 (permalink)
Old 11-05-2009, 01:53 PM
pawpaw pawpaw is offline
pawpaw has a good reputation on FTE. pawpaw has a good reputation on FTE. pawpaw has a good reputation on FTE.
Maybe consider running this puppy by a tranny shop that can scan the tranny computer for trouble codes, as that could give you some more clues as to what ails the tranny, so maybe then you could make a better informed decision as to what best to do.
If you think maybe deposits are the cause, perhaps consider a pan drop & cleaning, tranny filter change & continue on with a full tranny fluid pump out, using the proceedure in the Tech Info thread.
More thoughts to ponder.
Let us know how it goes.
__________________
99 Ranger 4dr 4x2 4.0L 5spd auto 3.55L/S Payload pkg2 tow pkg
Details are trifles but trifles make perfection & perfection is no trifle
(Ben Franklin)
Our signature is a sign of a job completed autograph your work with excellence
  #4 (permalink)
Old 11-06-2009, 12:09 AM
KhanTyranitar's Avatar
KhanTyranitar KhanTyranitar is offline
KhanTyranitar is starting off with a positive reputation.
A '94 Ranger uses the A4LD transmission. Skipping gears means at the least you need the valve body rebuilt. What is happening is that fluid is leaking from one part of the body to another, resulting in inappropriate things happening. The seals get old and worn. This can be exaggerated or accelerated by friction material into the fluid from a lack of maintenace. Most people are pretty good about oil changes, but forget that the transmission needs fluid changes far more frequently than most people realize. The old A4LD needs changes at 30,000 at the most. If the vehicle tows, or does a lot of stop and go, or races then you need to change it more often, at 15,000 - 20,000. The best fluid to use is Mercon V, though Merc III was the original fluid.
You can try changing the fluid and filter, but chances are you need to rebuild the valve body and make sure that the rest of the trans is in ok shape.
Tags
94 , auto , ford , problems , ranger , transmission
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
