f350 no crank no start??? - Ford Truck Enthusiasts Forums
1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
Old 11-05-2009, 09:01 AM
GT V10 GT V10 is offline
GT V10 is starting off with a positive reputation.
Hey guys - been out for a while. Hoping one of you can help me. My 350 v10 has a no crank no start. About 4 months ago it wouldn't start, turn the key and nothing. I replaced the starter and it was fine. 2 or 3 times since the starter replacement it has no crank no start, try again and its fine. A guy I know with a 250 told me that it was the nuetral safety switch in the first place that is probably never needed a starter. Now the truck has a no crank no start. I replaced the nuetral safety switch and it didn't help. I also know that the timing of the switch is crucial. I lined up the marks on the switch to the nuetral position with the truck in nuetral and tightened it down, to no avail. any one have anything to add?? Anything would be greatly appreciated.
Old 11-05-2009, 02:13 PM
jim henderson jim henderson is offline
jim henderson has a great reputation on FTE.jim henderson has a great reputation on FTE.jim henderson has a great reputation on FTE.jim henderson has a great reputation on FTE.
I assume you check the usual culprits? Battery charge level(at least 13v after a fresh charge, 12 v is too low), clean and tight connections on battery and starter and any associated connectors you can find.
No crank usually means the battery is dead, or the connections are corroded, or there is something wrong with the start circuit/comptuer.
Does the truck do anything when you turn the key? Dash ligfht up? Do the head lights burn bright?
Does it crank on a jump start?
Good Luck,
Jim Henderson
Old 11-05-2009, 03:26 PM
Thanks Jim - I did check the usual stuff and all looks ok. When you turn the key, electrically the truck comes to life. All of the guages come up, the fuel pump cycles and the hvac system does what it should. There is nothing at the starter. One more tidbit I just thought of.... if you jump the connections at the starter it spins fine but does not throw the bendix drive out to hit the flywheel. I don't know if there is enough of a voltage drop so the starter cant throw the bendix drive or if I have more of a issue than I am aware of.
Old 11-05-2009, 07:03 PM
I think I may have found it. The positive battery cable is coming apart in my hands. I have one coming in tomorrow from ford. Is this normal?
Old 11-05-2009, 09:03 PM
BareBones BareBones is offline
BareBones is gaining momentum as a positive member of FTE.
When you jumpt the connection to the starter and the bendix doesn't engage, where are you getting the power from? I would re-run this test with power from another vehicle, not the truck battery....
Old 11-06-2009, 02:09 PM
I went to ford and asked for a positive cable. At the parts persons suggestion I replaced both positive and negative cable assemblies ($300). The price floored me but the truck started right up!!!!!
03 no start Vinford 1999 to 2016 Super Duty 9 04-21-2015 11:17 AM
Nuetral Safety Switch Charles77f150 1973 - 1979 F-100 & Larger F-Series Trucks 10 11-24-2014 07:44 PM
F250 7.3. No crank starter issues stumped! Windstorm 1999 - 2003 7.3L Power Stroke Diesel 4 09-17-2014 11:22 AM
How do I bypass a nuetral safety switch on a 1972 F100? HELP tersing 1967 - 1972 F-100 & Larger F-Series Trucks 5 04-09-2010 12:55 PM
problem engaging the starter ya sure 1978 - 1996 Big Bronco 6 06-23-2003 04:48 PM
Tags
1999, 2001, 2003, 2008, 350, crank, cranks, diesel, duty, f250, f350, ford, start, super, v10
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
