What are the "other blunt cut wires" for?
Sam
The only thing I didn't like about the pass-through wires was that they don't really seem large enough to handle the bigger loads (30a) that upfitters #1 & #2 can carry.
I recently added some additional off-road lights to the front of my truck and determined that the current the light would draw is greater than 20a; therefore, I needed to use one of the higher current upfitters. The yellow blunt cut wire under the steering wheel was larger gauge than the pass-through wire, and I didn't feel comfortable having that kind of bottleneck. What I did was solder a new wire the same gauge as the yellow wire and simply ran it through the firewall in the factory location. More work, I know, but now there isn't a bottleneck.
Sam
Use a relay.
"I recently added some additional off-road lights to the front of my truck and determined that the current the light would draw is greater than 20a; therefore, I needed to use one of the higher current upfitters. The yellow blunt cut wire under the steering wheel was larger gauge than the pass-through wire, and I didn't feel comfortable having that kind of bottleneck. What I did was solder a new wire the same gauge as the yellow wire and simply ran it through the firewall in the factory location. More work, I know, but now there isn't a bottleneck."
It would be better to use a relay for the lights and use one of the smaller upfitter switches to trigger the relay.
For a cab chassis it's a different game as you might have a separate control station behind the cab and the wiring setup would be more involved.
SR is right about the wire gauge. There should be a "through" wire at the same capacity as the "heavy" switch. This avoids having to add a relay. SR - very cool avatar!
Necronommicon
Electrical Systems/Wiring
03-12-2016 06:52 AM
40 oz
1999 to 2016 Super Duty
13
10-28-2012 07:48 PM
