P1219-CID stuck low?
Old 11-05-2009, 03:52 AM
Muktown's Avatar
Muktown
Muktown is offline
i just bought a 1996 powerstroke, previoulsy had a 2000 7.3 and a duramax so im pretty familiar with them but today i was playing with auto enginuity and it passed the CCT but when i did the buzz test and KOEO test it came back with 2 codes. they diddnt trip the ses light though. the codes are 1219-CID stuck low, and 1298 IDM failure. i dont think i have a bad idm because the truck runs fine but im not sure about the 1219 code. is that an internal idm problem or maybe a bare wire shorting out? what is CID? thanks
Old 11-05-2009, 08:41 AM
Andy's250's Avatar
Andy's250
Andy's250 is offline
This website will definately help you, the codes are about halfway down its a pretty long page
Tips - Idea - Hints
Im not sure how to make it a hypertext link. this is the 1219 code off that site
1219 PCM/IDM CID stuck low Cyl. identification line stuck low (historical fault only) CID circuit short to ground, probably intermittent
Andy's250's Avatar
Andy's250
ha hypertexted itself
Old 11-05-2009, 08:44 AM
Andy's250's Avatar
Andy's250
1298 PCED IDM failure Internal IDM failure Internal IDM failure
Probably not good. if its still running thats a weird code tho . i didnt think they would run at all with bad idm but i may be wrong
Old 11-05-2009, 09:03 AM
Muktown's Avatar
Muktown
Muktown is offline
thats what i thought. its a weird code. i would think an idm failure would cause all kinds of problems? im wondering if there is a wire rubbed through somewhere on the cid circuit shorting it out and because that code is thrown the computer thinks the idm is bad also. just wondering if anyone had this problem and if it was an internal idm problem or an external(wiring) issue
Old 11-05-2009, 10:37 AM
Andy's250's Avatar
Andy's250
are you having any problems at all?
Old 11-05-2009, 06:38 PM
95bigtime's Avatar
95bigtime
95bigtime is offline
I had the 1298 and bought a new IDM and sure enough I still get the 1298. I dont worry about it and keep the old IDM under the seat just in case.
Old 11-05-2009, 06:46 PM
c00nhunterjoe's Avatar
c00nhunterjoe
c00nhunterjoe is offline
the 1219 is a chaffed or broken wire, its pin number 96 on your pcm. a yellow with lihgt blue tracer. runs from the pcm to the idm, if that wire is good then the idm is bad.
the 1298 is probably related to the first code.
Old 11-05-2009, 11:40 PM
oldbird1965's Avatar
oldbird1965
oldbird1965 is offline
I'm impressed Joe, do you have a photografic memory?
Old 11-05-2009, 11:44 PM
95_Dually's Avatar
95_Dually
95_Dually is offline
Joe you are amazing. The things you know are astonishing. Glad you are on this site.
Old 11-06-2009, 07:53 AM
Muktown's Avatar
Muktown
Muktown is offline
thanks ill have to get out the multi meter. thats kind of what i was thinkng that it said the idm was bad because one circuit in it was bad but wouldnt a cylinder i.d cirucit shorted to ground cause problems? the truck seems to run fine
Old 11-06-2009, 08:36 PM
c00nhunterjoe
certains things i do remeber photographicly, but with each passing day there are less and less....lol. the tank parts are taking over. i do recall most of the basic circuits but i always double check my pced's before posting when it comes to wire colors and numbers
Old 07-20-2014, 04:37 PM
SeanDrakejeeps's Avatar
SeanDrakejeeps
SeanDrakejeeps is offline
what is the cid
Tamara1219
6.7L Power Stroke Diesel
04-10-2017 06:06 PM
deshet1980
32
03-25-2017 03:22 PM
blrman1962
12-11-2016 10:42 AM
DRRXR
10-30-2016 01:22 PM
Farmboypowerstroke
10-29-2011 05:05 PM
Quick Reply: P1219-CID stuck low?
