P1219-CID stuck low? - Ford Truck Enthusiasts Forums
1994.5 - 1997 7.3L Power Stroke Diesel SPONSORED BY:
Old 11-05-2009, 04:52 AM
Muktown's Avatar
Muktown Muktown is offline
Muktown is gaining momentum as a positive member of FTE.Muktown is gaining momentum as a positive member of FTE.
i just bought a 1996 powerstroke, previoulsy had a 2000 7.3 and a duramax so im pretty familiar with them but today i was playing with auto enginuity and it passed the CCT but when i did the buzz test and KOEO test it came back with 2 codes. they diddnt trip the ses light though. the codes are 1219-CID stuck low, and 1298 IDM failure. i dont think i have a bad idm because the truck runs fine but im not sure about the 1219 code. is that an internal idm problem or maybe a bare wire shorting out? what is CID? thanks
Old 11-05-2009, 09:41 AM
Andy's250's Avatar
Andy's250 Andy's250 is offline
Andy's250 is starting off with a positive reputation.
This website will definately help you, the codes are about halfway down its a pretty long page
Tips - Idea - Hints
Im not sure how to make it a hypertext link. this is the 1219 code off that site
1219 PCM/IDM CID stuck low Cyl. identification line stuck low (historical fault only) CID circuit short to ground, probably intermittent
Andy's250's Avatar
ha hypertexted itself
Old 11-05-2009, 09:44 AM
Andy's250's Avatar
1298 PCED IDM failure Internal IDM failure Internal IDM failure
Probably not good. if its still running thats a weird code tho . i didnt think they would run at all with bad idm but i may be wrong
Old 11-05-2009, 10:03 AM
Muktown's Avatar
thats what i thought. its a weird code. i would think an idm failure would cause all kinds of problems? im wondering if there is a wire rubbed through somewhere on the cid circuit shorting it out and because that code is thrown the computer thinks the idm is bad also. just wondering if anyone had this problem and if it was an internal idm problem or an external(wiring) issue
Old 11-05-2009, 11:37 AM
Andy's250's Avatar
are you having any problems at all?
Old 11-05-2009, 07:38 PM
95bigtime 95bigtime is offline
95bigtime is starting off with a positive reputation.
I had the 1298 and bought a new IDM and sure enough I still get the 1298. I dont worry about it and keep the old IDM under the seat just in case.
Old 11-05-2009, 07:46 PM
c00nhunterjoe's Avatar
c00nhunterjoe c00nhunterjoe is offline
c00nhunterjoe has a very good reputation on FTE.c00nhunterjoe has a very good reputation on FTE.c00nhunterjoe has a very good reputation on FTE.
the 1219 is a chaffed or broken wire, its pin number 96 on your pcm. a yellow with lihgt blue tracer. runs from the pcm to the idm, if that wire is good then the idm is bad.
the 1298 is probably related to the first code.
Old 11-06-2009, 12:40 AM
oldbird1965's Avatar
oldbird1965 oldbird1965 is online now
oldbird1965 is a splendid one to beholdoldbird1965 is a splendid one to beholdoldbird1965 is a splendid one to beholdoldbird1965 is a splendid one to beholdoldbird1965 is a splendid one to beholdoldbird1965 is a splendid one to beholdoldbird1965 is a splendid one to behold
I'm impressed Joe, do you have a photografic memory?
Old 11-06-2009, 12:44 AM
95_Dually's Avatar
95_Dually 95_Dually is offline
95_Dually has a great reputation on FTE.95_Dually has a great reputation on FTE.95_Dually has a great reputation on FTE.95_Dually has a great reputation on FTE.
Joe you are amazing. The things you know are astonishing. Glad you are on this site.
Old 11-06-2009, 08:53 AM
Muktown's Avatar
thanks ill have to get out the multi meter. thats kind of what i was thinkng that it said the idm was bad because one circuit in it was bad but wouldnt a cylinder i.d cirucit shorted to ground cause problems? the truck seems to run fine
Old 11-06-2009, 09:36 PM
certains things i do remeber photographicly, but with each passing day there are less and less....lol. the tank parts are taking over. i do recall most of the basic circuits but i always double check my pced's before posting when it comes to wire colors and numbers
Old 07-20-2014, 05:37 PM
SeanDrakejeeps SeanDrakejeeps is offline
SeanDrakejeeps is starting off with a positive reputation.
what is the cid
TRUCK WONT RUN IDM P01668 blrman1962 1999 - 2003 7.3L Power Stroke Diesel 2 12-11-2016 11:42 AM
2003 F-250 Dorman Timing Cover, crank no start mjbavid 1999 to 2016 Super Duty 1 11-25-2012 01:02 PM
Help truck died on the way home Farmboypowerstroke 1999 - 2003 7.3L Power Stroke Diesel 10 10-29-2011 06:05 PM
2001 E450 p1218 and p1219 demon305 1999 - 2003 7.3L Power Stroke Diesel 5 10-13-2011 05:57 PM
Diagnostic code question f-150 on 22's 1999 - 2003 7.3L Power Stroke Diesel 7 02-12-2008 04:25 PM
Tags
02, 73, 97, bad, cid, code, cylinder, diesel, ford, idm, low, p1219, powerstroke, problems, stuck
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
