Go Back   Ford Truck Enthusiasts Forums > Performance, Engines and Troubleshooting > Small Block V8 (221, 260, 289, 5.0/302, 5.8/351W)
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
Is F-150 Still King?
  #1 (permalink)
Old 11-05-2009, 01:54 AM
matpasch matpasch is offline
matpasch is starting off with a positive reputation.
351 using oil
My 1993 F250 4x4 ext cab with 351 Windsor and 5spd seems to be using about 1 liter of oil every 1200-1500kms or so. The truck doesn't leak pil, no blue smoke or smoke at all, no smell. It has just over 300,000kms on the engine and just did a tune up, new pvc valve etc.
Im running 10w30 right now up in vancouver Canada. wondering if I should use a heavier weight oil like 10W40 or 20W50? Would this harm the motor, in the winter, never gets that could here. I run 20W50 in my 70 Torino with a 460, but it burns blue and never sees the winter.
thanks
mat
  #2 (permalink)
Old 11-05-2009, 12:21 PM
g_k50's Avatar
g_k50 g_k50 is offline
1990 Ford Bronco
My Garage
g_k50 is starting off with a positive reputation.
When you say leak, do you mean a spot on the driveway or do you mean a oil trail on the motor or congealed on the underside of the body? Because it sounds like a leak, and you've gotta have some leaking valve stem seals. How do the spark plugs look?
The 351w could use a heavier weight oil, 20W would not hurt that motor and maybe even a 30W in summer.
  #3 (permalink)
Old 11-05-2009, 12:42 PM
Kemicalburns's Avatar
Kemicalburns Kemicalburns is online now
Kemicalburns has a good reputation on FTE. Kemicalburns has a good reputation on FTE.
well with the cold coming i would stay with what you are using now. staying with the same oil year around is best practice for an old motor like that. you are probably getting some blowby the rings or the valve seals which is typical with that many miles on the motor. i wouldnt worry about it honestly just keep an eye on it. i would install a mechanical oil pressure gauge so you know whats going on there. the stock gauges suck.
__________________
94 XLT 5.8/E4OD/Warn HS9500I
6"ProComp Stage II 35x12.5x15 BFG MT's
4.88 gears/Aussie Front/rear open
JBA shorty, Custom Y pipe,3" exhaust
http://www.supermotors.org/registry/...il.php?id=4158
  #4 (permalink)
Old 11-05-2009, 02:52 PM
Sparkplugs are clean, no okl on them. Ya a mechanical oil gauge would be good, probably get a 3 Pack and install them
Tags
351 , oil , recommended , weight
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
