Go Back   Ford Truck Enthusiasts Forums > Older, Classic and Antique Trucks > 1961 - 1966 F-100 And Larger F-Series Trucks
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
1961 - 1966 F-100 And Larger F-Series Trucks Discuss the Slick Sixties Ford Truck SPONSORED BY:
Is F-150 Still King?
  #1 (permalink)
Old 11-05-2009, 12:09 AM
63'half ton 63'half ton is offline
63'half ton is starting off with a positive reputation.
Lowering my 63'on the "cheap"
Since everyone here has been SO informative and helpful to me,I thought I might throw another stupid question out there.
I want to put my truck "in the weeds".I saw a picture of a blue 63' onthe net with a super hot chick standing nex to it,the truck has stickers on the door and moon discs on the wheels.This is similar to what I want my truck to sit like.The hood of the truck is at about the same height as the chick's butt.It looks like it has stock size wheels.
I am a good fabricator and am not afraid to do some "hackin" and weldin' if I have to.
I just want to do this as cheap as I can but also want it safe.(at least mostly safe)
Thanks again you guys,you are all the best!!
  #2 (permalink)
Old 11-05-2009, 02:57 AM
matt2491's Avatar
matt2491 matt2491 is offline
matt2491 is new and has a neutral reputation at this point.
  #3 (permalink)
Old 11-05-2009, 03:00 AM
Yep!That's the one!!Just bad-ass!!
  #4 (permalink)
Old 11-05-2009, 12:33 PM
gritsngumbo's Avatar
gritsngumbo gritsngumbo is offline
1963 Ford F-100
My Garage
gritsngumbo is starting off with a positive reputation.
Trucks not bad either.
__________________
64 Ford F100 Styleside Short Bed /223 "6" & 4 speed "Little Red"
63 Ford F100 Unibody Styleside Longbed w/292 V-8, 3 deuces, dual exhausts & 3 speed "Big Red"
63 Ford F250 Flareside Long Bed w/292 V-8, two barrel, dual exhausts & 4 speed "Big Un"
63 F100 "Stageway" Crew Cab Long (wrong) bed. 292 V-8 & 3 speed
  #5 (permalink)
Old 11-05-2009, 12:45 PM
sgreen sgreen is offline
sgreen is starting off with a positive reputation.
how much for the woman?
  #6 (permalink)
Old 11-05-2009, 12:55 PM
1963 Ford F-100
My Garage
Quote:
Remember the old adage "if you have to ask you probably can't afford it"? :-)
(Note: sorry for the hi-jack Poster has a legitimate question)
__________________
  #7 (permalink)
Old 11-05-2009, 12:57 PM
gotta write the check don't I...
  #8 (permalink)
Old 11-05-2009, 12:59 PM
but i probably couldn't her just the same... would probably just piss the wife off.
  #9 (permalink)
Old 11-05-2009, 02:16 PM
1963 Ford F-100
My Garage
Sorry, double posted. Guess you can no longer delete a reply.
__________________
  #10 (permalink)
Old 11-05-2009, 03:44 PM
There are hot rod links around that describe how to stretch the straight axel, here is an article on building a jig to do it.
Suspension: Drop Axle Jig 2ND Generation pics - THE H.A.M.B.
S
  #11 (permalink)
Old 11-05-2009, 05:20 PM
airharley's Avatar
airharley airharley is offline
airharley is gaining momentum as a positive member of FTE.
You can also send your stock ones out to have them altered as well for less $$$ or buy new ones. Check Gangsters profile I believe he has some pics in his gallery covering what he did to his.
__________________
Mark J. Covill
"I'm not handicapped, I'm handicapable!"
'64 F-100 Shortbed 460/C-6
Author of the disc brake article for 57-64 F-100's
  #12 (permalink)
Old 11-06-2009, 08:38 AM
Log Hog Kust'em Log Hog Kust'em is offline
Log Hog Kust'em is starting off with a positive reputation.
a few more years and they both will sag. My buddy keeps telling me to heat the leafs (of the truck) and drop the front end. I keep telling the kid, I want (it) to stand proud. Any way, heating the springs is cheap, I don't know how well it works.
  #13 (permalink)
Old 11-06-2009, 09:21 AM
never heard of heating leaf springs to lower the ride, just heating coils.
I've wondered if the ibeams on the later trucks could be done the same as the thread shows?
S
  #14 (permalink)
Old 11-08-2009, 10:43 AM
Texas Jim Texas Jim is offline
Texas Jim is starting off with a positive reputation.
F/ about 50 bucks a piece, you can get reversed eye main leafs and drop it quite abit. I lowered mine about 15 years ago. I also installed a Ford 9" rear and removed afew leafs, not that you need another rear end to lower the rear of the truck. You can extend the shackles on the rear and drop it some more. In fact, a spring shop can make you a single leaf from heavier stock that will support your truck and by eliminating leafs, inturn dro the truck more. It's not expensive. The higher-dollar way is to get dropped spindles and front axle, too hig f/ me and takes from the original set-up. Bob's F-100 Shop in Calif. is probably still in business. I sent f/ a catalog and the info on dropping the truck is right in it. They also use the Toyota steering box, the one from the older 4x4 pick-ups w/ the solid front axle housing, to replace the original, and it works well.
Good Luck. Any questions, just drop me a line.
  #15 (permalink)
Old 11-08-2009, 11:45 AM
1965 F-100's Avatar
1965 F-100 1965 F-100 is offline
1965 F-100 is starting off with a positive reputation.
simple.....find a taller chic for the picture!
Tags
100 , 1963 , 63 , axle , drop , f100 , ford , forum , front , leaf , lower , lowered , springs , stepside , truck
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
