Go Back   Ford Truck Enthusiasts Forums > Older, Classic and Antique Trucks > 1973 - 1979 F-100 And Larger F-Series Trucks
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
1973 - 1979 F-100 And Larger F-Series Trucks Discuss the Dentsides Ford Truck SPONSORED BY:
Is F-150 Still King?
  #1 (permalink)
Old 11-04-2009, 11:10 PM
Hmann Hmann is offline
Hmann is starting off with a positive reputation.
Flooring?
when i got my truck the carpet was all gnarly and stuff so i removed it and since have been driving around with a bare metal floor. my main question is, what should i use for flooring?
i am considering getting a quart or two of that roll on bed liner stuff, and doing a bed liner on the floor.
http://www.jcwhitney.com/COMPLETE_READY-TO-USE_BRUSH-ON_BED_LINER_KIT?ID=12;0;510001314;0;100002;Produc tName;1;0;0;0;2000789;0;0
i also found some super thin carpet at shucks for like 13 a roll and would just glue it to the floor.
http://shop.oreillyauto.com/ProductDetail.aspx?MfrCode=SCP&MfrPartNumber=107&CategoryCode=3028
and the cheapest molded carpet ive been able to find is like $125
im on a really strict budget of about $70, and wanted some opinions about what to do also if ive overlooked anything please let me know!
  #2 (permalink)
Old 11-04-2009, 11:38 PM
78_f800crewcab4x4's Avatar
78_f800crewcab4x4 78_f800crewcab4x4 is offline
78_f800crewcab4x4 is gaining momentum as a positive member of FTE. 78_f800crewcab4x4 is gaining momentum as a positive member of FTE.
maybe a couple quarts of herculiner. I've used it on a few floorpans with excellent results. but you have to scuff the surface, remove rust, and degrease, and mask off before you roll it on. wal mart should have it.
__________________
1978 F600 Bronco 4 door "Centurion"
1958 F700 next "Centurion" project
1973 F350 Crew Cab Special, 460 all race
2002 Excursion Limited 4x4 7.3
Please help them:
http://www.lionconservation.org/index.html
  #3 (permalink)
Old 11-05-2009, 12:00 AM
so i do have to remove all of the rust? because the passangers side has a bit on it, and i just put some rustoleum on it.
  #4 (permalink)
Old 11-05-2009, 10:20 PM
jdv19 jdv19 is offline
jdv19 is starting off with a positive reputation.
I'm going with a similar project. I'm going to replace my floor pans totally 1st then go with the Herculiner. From what i read the Hurculiner is the best. Yes you will have to remove the rust. The prep is the most important step. Poor prep and the herculiner won't stay. Not sure of the total cost.
  #5 (permalink)
Old 11-05-2009, 10:39 PM
SevenT4's Avatar
SevenT4 SevenT4 is offline
SevenT4 is starting off with a positive reputation.
I would go with the Herculiner. I used it in an old Montero of mine. You can always buy molded carpet later and place it over the liner.
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
