Go Back   Ford Truck Enthusiasts Forums > Bronco > Big Bronco (1978 - 1996)
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
Big Bronco (1978 - 1996) SPONSORED BY:
Is F-150 Still King?
  #1 (permalink)
Old 11-04-2009, 11:06 PM
milleroutdoors's Avatar
milleroutdoors milleroutdoors is offline
milleroutdoors is gaining momentum as a positive member of FTE.
won't run
Good evening everyone. I am on the 7.3 forum quite a bit but have never posted on the bronco forum. I am trying to get my son's '89 bronco running. It ran fine this summer but has sat for several months. I can get it to start but won't respond to the throttle and will rev up and die. I have checked spark and fuel. When I pump the throttle it will slightly rev and backfire. It has a newer dist.cap, plugs, plug wires, coil. Any suggestions would be appreciated. This is a 302 with a manual tranny. Thanks in advance.
__________________
Mark - 2001 F350 PSD 4x4 CC, 4" MBRP Turbo back, CCV, OBA, AIH delete, AFE II, Isspro Performax Gauges, GPR LED, DP tuner (decel,40t,60t,80t,80e,120r), F-650 Dash, ceramic coated ATS 1.0 Housing, WW, hpx, bellowed uppipes, foil delete, and new intercooler boots, hutch/ harpoon mods, 6.0 transmission cooler.
  #2 (permalink)
Old 11-04-2009, 11:08 PM
g_k50's Avatar
g_k50 g_k50 is offline
1990 Ford Bronco
My Garage
g_k50 is starting off with a positive reputation.
Did you check the fuel pressure? Any work done in the several months that it sat? Check wires for routing and connection.
  #3 (permalink)
Old 11-04-2009, 11:23 PM
I have not checked fuel pressure. I do not have a pressure gauge where I am. I did disconnect the fuel line on the out side of the filter and it has a large volume. I have been checking connections and general visual of wires for the last 2 hours..
__________________
  #4 (permalink)
Old 11-04-2009, 11:26 PM
Also there has been no work done since it was parked. It has 1/2 tank of fuel. It is parked under cover.
__________________
  #5 (permalink)
Old 11-05-2009, 12:13 AM
g_k50's Avatar
1990 Ford Bronco
My Garage
If the Engine Coolant Temperature Sensor (ECT) doesn't tell the PCM that the truck is warmed up the PCM might be telling the engine to flood itself.
The backfire sounds like a timing problem but if there's no work been done then the timing should not have changed that's why I suggested the the wiring might be examined for deficiencies.
It does start and idle? But won't accelerate? Does it warm up? The cooling system is in good shape?
  #6 (permalink)
Old 11-05-2009, 12:21 AM
It will start, rev and die in about 2 seconds. It will not idle or run long enough to warm up. I disconnected every connector I could and checked for dielectric grease. I had filled them a couple of years ago. Maybe a condenser?? I am guessing. I have it in my shop now and will start getting serious tomorrow after work.
__________________
  #7 (permalink)
Old 11-05-2009, 12:29 AM
g_k50's Avatar
1990 Ford Bronco
My Garage
Check the spark plugs to see if they are wet from gas. If so I would suspect flooding,
I would suggest taking the Idle Speed Air Contol Bypass Valve off and cleaning it with some brake cleaner.
  #8 (permalink)
Old 11-05-2009, 12:40 AM
Good call on the idle speed air control bypass valve. That is one of the first things I will do. I want to check fuel pressure as well. I will pull some of the plugs. I also have another dist cap I will put on. Thanks for your insight.
__________________
  #9 (permalink)
Old 11-07-2009, 04:10 PM
Update, Fuel pressure is good, iac, egr cleaned, dist cap and rotor is new. Same thing starts revs up and dies. If you pump the throttle it will run with backfiring and erratic rpms until it dies. Plugs are dry, would not appear to be flooding. Not sure what to do next. Self read codes indicate a fuel inertia switch inactive, been this way since we bought it. The previous owner had an alarm and the switch was replaced with a relay. Nothing new for this vehicle. Any suggestions????
__________________
  #10 (permalink)
Old 11-07-2009, 05:28 PM
g_k50's Avatar
1990 Ford Bronco
My Garage
Did you consider water in the gasoline? What was the fuel pressure, should be above 35 and below 40. If you jump the fuel pump on the test connector the fuel pump will run continuously without the PCM cutting it off. The fuel pump is the electrical connection on the short arm of the test connector. Turn the key to run and the pump will run continuously. When the pump is turned off the pressure should not drop quickly, that indicates either bad injectors or a bad regulator. Check the return line for flow. there shouldn't be any flow if the pressure does not go to 40 with the engine off, if there is flow suspect fuel regulator. If not suspect fuel injectors.
  #11 (permalink)
Old 11-07-2009, 08:06 PM
vtjvt vtjvt is offline
1978 Ford F-150
vtjvt is starting off with a positive reputation.
If it has been sitting I would drain the tank and put fresh gas in,
  #12 (permalink)
Old 11-07-2009, 09:29 PM
I appreciate the responses and suggestions. Next step I will drain fuel tank (1/2 full). I have fresh gas at my shop so it is easy enough to address that issue. Needless to say I am frustrated and calling it a night. I will start rechecking everything again tomorrow. Thanks.
__________________
  #13 (permalink)
Old 11-07-2009, 09:44 PM
helirich helirich is offline
helirich is starting off with a positive reputation.
Sounds like fuel. When you turn on the key, the pump turns on for a few seconds, then it turns off untill you start. Then it is sappose to turn back on. I suspect it is not and it runs out of gas. A quick way to check this is to have someone spray starter fluid at the intake. If it keeps running, you know its fuel. Maybe the pump, maybe a filter.
__________________
90' Bronco, 351, MSD Ign., SS 3" exhaust,
38" x 15.50 R15 Dirt Grips, 14" x 15" Alcoa wheels
6" lift w/ cutout flares, 40 gal. fuel tank
F diff - lockright locker, 4.88's
R diff - Powertrax locker, 4.88's
Cast diff cover w/ carrier braces
Rear full float axles, truss, Above spring traction bars
  #14 (permalink)
Old 11-07-2009, 10:36 PM
Quote:
I did spray starting fluid in the plenum, its response led me to replacing the high pressure pump and filter. I thought the pressure was a little low, something like 29psi. Have great pressure now but problem persists.
__________________
  #15 (permalink)
Old 11-07-2009, 11:20 PM
1978 Ford F-150
When I picked up my 90 a few months ago it had been sitting for awhile, it ran enough to get it home but that was about it, I drained and refilled the tank and added a can of seafoam to the tank, plus ran some through the intake, (vaccum line) runs great.
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
