Go Back   Ford Truck Enthusiasts Forums > Bronco > Big Bronco (1978 - 1996)
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
Big Bronco (1978 - 1996) SPONSORED BY:
Is F-150 Still King?
  #16 (permalink)
Old 11-08-2009, 12:19 AM
g_k50's Avatar
g_k50 g_k50 is online now
1990 Ford Bronco
My Garage
g_k50 is starting off with a positive reputation.
I would check the fuel injectors next. Are they getting voltage to fire? It might be that the PCM is telling the fuel injectors to shut down for some reason. Have you disconnected the battery to reset the DTC? Are there any codes to begin with?
  #17 (permalink)
Old 11-08-2009, 12:46 AM
milleroutdoors's Avatar
milleroutdoors milleroutdoors is offline
milleroutdoors is gaining momentum as a positive member of FTE.
Quote:
I had to put a new battery in it, how would I check the injector voltage? Maybe I should ask what the voltage should be and start there. Thanks.
__________________
Mark - 2001 F350 PSD 4x4 CC, 4" MBRP Turbo back, CCV, OBA, AIH delete, AFE II, Isspro Performax Gauges, GPR LED, DP tuner (decel,40t,60t,80t,80e,120r), F-650 Dash, ceramic coated ATS 1.0 Housing, WW, hpx, bellowed uppipes, foil delete, and new intercooler boots, hutch/ harpoon mods, 6.0 transmission cooler.
  #18 (permalink)
Old 11-08-2009, 12:51 AM
g_k50's Avatar
1990 Ford Bronco
My Garage
A noid light is used, flashes when energized.
  #19 (permalink)
Old 11-08-2009, 06:14 PM
helirich helirich is offline
helirich is starting off with a positive reputation.
When you checked the fuel pressure, was that after it stalled? As I said earlier, When you first turn on the key, pump will turn on for a few seconds. But if it doesnt turn on agian after the engine starts, it wont run long. I believe theres a "accedent switch" that controls the pump turning on. This is so you dont keep feeding a fire after you crash. This switch goes bad sometimes.
__________________
90' Bronco, 351, MSD Ign., SS 3" exhaust,
38" x 15.50 R15 Dirt Grips, 14" x 15" Alcoa wheels
6" lift w/ cutout flares, 40 gal. fuel tank
F diff - lockright locker, 4.88's
R diff - Powertrax locker, 4.88's
Cast diff cover w/ carrier braces
Rear full float axles, truss, Above spring traction bars
  #20 (permalink)
Old 11-12-2009, 08:30 PM
Update bad map sensor. No correlating codes. Thanks for all of your advice.
__________________
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
