Go Back   Ford Truck Enthusiasts Forums > Diesel > 1999 - 2003 7.3L Power Stroke Diesel
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
1999 - 2003 7.3L Power Stroke Diesel SPONSORED BY:
Is F-150 Still King?
  #1 (permalink)
Old 11-04-2009, 11:05 PM
airassaultinfantry1 airassaultinfantry1 is offline
airassaultinfantry1 is starting off with a positive reputation.
airdog 130/75
I was wondering if any has installed this pump exculsive for powerstoke . It has an adjustable regulator built in up to 75 psi . I've had so many issues wiyh the fuel system . It keeps blowing the fuel bowl gaskets . I took the shim out . Cleaned the regulator . It suffers from #8 starvation . I have also ordered a return line . I did an in tank mod from dfuser .I have the programer set on emission . I also did the fuel bowl spring and plunger delete as well as the banjo fitting mod . I even changed the cps to an International one . Does someome have any suggestions ?
Thank you ,
John
  #2 (permalink)
Old 11-05-2009, 12:19 AM
Riffraff Performance's Avatar
Riffraff Performance Riffraff Performance is online now
Platinum Sponsor
Riffraff Performance has a great reputation on FTE. Riffraff Performance has a great reputation on FTE. Riffraff Performance has a great reputation on FTE. Riffraff Performance has a great reputation on FTE. Riffraff Performance has a great reputation on FTE.
If you are blowing the fuel filter gaskets then I would say that the Airdog II isn't going to solve it. It sounds like you have something blocking your return line. Do you have a fuel gauge? What is your fuel pressure? If your #8 is having issues then you need something like an FRx or CCK. As far as the AirDog II, they seem to be great on filteration and as a pump, just a little pricey.
__________________
Clay
Riffraff Diesel: Contact Us
Diesel O-Rings by Guzzle
Riffraff Facebook Page
Parts Guy Ed - The one and only choice for OEM Parts
  #3 (permalink)
Old 11-05-2009, 12:41 AM
I have taken apart everyting and cleaned it. I did find a thread off the lid in the fpr . I also took my shim out .I'll start out @ 62 to 75 psi then it 's up to 93 @ times ? I ordered a cck from dino fuel alt . Do you think the $190.00 adv auto pump would have an effect on anything ? (I knew needed an air dog but it was 2-3 weeks out due to thier move) and it couldnt stayed parked . It has a 1 to 2 second sputter while taking off sometimes . The reason I went with the air dog was quieting the "crackle" by removing entrained air as well as the 75 psi max .
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
