Go Back   Ford Truck Enthusiasts Forums > Diesel > 1999 - 2003 7.3L Power Stroke Diesel
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
1999 - 2003 7.3L Power Stroke Diesel SPONSORED BY:
Is F-150 Still King?
  #1 (permalink)
Old 11-04-2009, 10:50 PM
airassaultinfantry1 airassaultinfantry1 is offline
airassaultinfantry1 is starting off with a positive reputation.
Adrenaline HPOP
Greetings,
I was wondering who installed an adrenaline hpop and if you have any words to help someone out ? What did you find out to expidite the install ? Also , what type of inprovement did it make ?
Thanks,
John
  #2 (permalink)
Old 11-04-2009, 10:59 PM
indyF-350psd's Avatar
indyF-350psd indyF-350psd is offline
Springfield Armory
indyF-350psd is gaining momentum as a positive member of FTE. indyF-350psd is gaining momentum as a positive member of FTE.
the adrenaline is a nice upgrade over the stocker to run the split shots and dieselsite has good instructions for the install.....
__________________
BILL ----> 2002 F350 7.3L CC LB DUALLY LARIAT 6X6
http://www.roadsidehelpnetwork.info/
  #3 (permalink)
Old 11-04-2009, 11:08 PM
Quote:
Thanks for the heads up . the only things left to do is head studs and injectors . I need more jing
  #4 (permalink)
Old 11-04-2009, 11:28 PM
gasgrunt88's Avatar
gasgrunt88 gasgrunt88 is offline
2002 Ford F-250
gasgrunt88 is gaining momentum as a positive member of FTE. gasgrunt88 is gaining momentum as a positive member of FTE.
Look for my thread on upgrading HPOP. Some of the guys posted a lot of good info about the subject.
__________________
Chris PAA MEMBER #90
2002 F-250 7.3L 114,000+ K&N Intake w/6637 & Pete's cover, MBRP 4" Turbo back, JW VB, Zoodad, AutoMeter Ultralite Boost & Pyro, DP Tuner w/80e 120r, 140x, CCV mod, ITP OBA, AIH delete w/boost, HPX, Foil Delete... Mods purchased & waiting for install: Big Poppa's Loaner Turbo
"Black smoke don't mean its broke!"
  #5 (permalink)
Old 11-04-2009, 11:34 PM
Quote:
Thanks , I'll check it out
  #6 (permalink)
Old 11-04-2009, 11:39 PM
PaysonPSD's Avatar
PaysonPSD PaysonPSD is offline
Support FTE
PaysonPSD has much to be proud of PaysonPSD has much to be proud of PaysonPSD has much to be proud of PaysonPSD has much to be proud of PaysonPSD has much to be proud of PaysonPSD has much to be proud of PaysonPSD has much to be proud of PaysonPSD has much to be proud of
Upgraded HPOP was probably the best upgrade I have done because my stock HPOP was a 15° pump. I went with the Adrenaline but there are other choices. See this TREAD LINK for more info about HPOP upgrades.
  #7 (permalink)
Old 11-05-2009, 12:00 AM
Quote:
This is the land of the free because of the brave . Did I see a E.I.B. in lower section ?
Thank you for your response
John
  #8 (permalink)
Old 11-05-2009, 12:18 AM
PaysonPSD's Avatar
Support FTE
John
Not an EIB but a CIB. I was an 11Bravo way back in '67 to '69. Actually got out as an 11B40.
That thread has allot of info.
This was my original thread after installing the Adrenaline last April. LINK
Tags
73 , adrenaline , hpop , instalation , install , powerstroke , pumps , upgraded
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
