Go Back   Ford Truck Enthusiasts Forums > Older, Classic and Antique Trucks > 1987 - 1996 F150 And Larger F-Series Trucks
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
1987 - 1996 F150 And Larger F-Series Trucks SPONSORED BY:
Is F-150 Still King?
  #1 (permalink)
Old 11-04-2009, 10:36 PM
3BadBirds 3BadBirds is offline
3BadBirds is starting off with a positive reputation.
What Tire PSI Are You Running?
I have the standard 16 inch rims and knobby tires (LT235/85R16) on my 88 F250 and was curious what others were inflating theirs to. My door sticker is long gone but I know the tires specifies 80 psi as its max. I had been using 60.
Thanks!
  #2 (permalink)
Old 11-04-2009, 11:29 PM
93f250tn's Avatar
93f250tn 93f250tn is offline
93f250tn is starting off with a positive reputation.
Well for example on my bf goodrich all terrains it says max 40 psi but you have to remember during the summer the heat causes air to expand ontop of driving which also heats up tires so i keep mine at 35. That also applys during the winter the cold causes the air molcules to come closer together causing the air pressure to go down so ill fill my up to 40 or so. Hopefully that helps you out my friend I also forgot to add if your offroading you inflate or deflate your tires accordingly
__________________
95 F150 XLT Extended Cab. Short Bed 5.8L 351 Windsor 4x4 200k + and running strong! Built FORD Tough!
Next step- Bigger tires, some lift and some more ponys!
  #3 (permalink)
Old 11-05-2009, 10:26 AM
DBGrif91's Avatar
DBGrif91 DBGrif91 is offline
DBGrif91 is starting off with a positive reputation.
I'm in the same boat as 93f250tn - 35 in spring-fall, 40 from late fall to early spring.
__________________
"Official Project Stages: (1) Uncritical Acceptance. (2) Wild Enthusiasm (3) Dejected Disillusionment. (4) Total Confusion. (5) Search for the Guilty. (6) Punishment of the Innocent. (7) Promotion of the Non-participants."
-Unknown
  #4 (permalink)
Old 11-05-2009, 01:47 PM
Dancingchicken Dancingchicken is offline
Dancingchicken is starting off with a positive reputation.
Ha, ha. This reminds me of an old joke we used to pull on the new recruits in the unit when I was in the Army. First day in the motor pool we would pull them aside and tell them their first task for the day was to go around and change all the air in the truck tires from Summer to Winter air, or vice versa. What a riot!!!
  #5 (permalink)
Old 11-18-2009, 06:10 PM
awkoop's Avatar
awkoop awkoop is offline
awkoop is starting off with a positive reputation.
40psi for fall
  #6 (permalink)
Old 11-18-2009, 06:29 PM
bwoldschool65 bwoldschool65 is offline
bwoldschool65 is starting off with a positive reputation.
Well, my tires say max 50. but i only run 30 in the summer and 35 in winter. I do some pasture driving so it smooths it out a bit to have a little lower pressure. Not sure what the door tag says. But i do sometimes run about 45 in the rear when pulling a trailer.
__________________
1965 F-100 Long bed
302/AOD
1992 F-150 Custom
Short Bed/Standard Cab
300/auto
  #7 (permalink)
Old 11-19-2009, 04:59 AM
Here's something to consider if you are bothered by changing tire pressures with the seasons. Have your tires filled with Nitrogen. Guy that recently sold me tires for my Mustang says Nitrogen keeps a more constant pressure than plain air because it's not temperature sensitive. It also helps resist the corrosion that sometimes forms in tires with aluminum rims. Of course it costs, but it was only about $5 to do all four tires and in this case refills and top offs are free for the life of the tire. Just something to think about. I had never heard of it before last month.
  #8 (permalink)
Old 11-19-2009, 07:37 AM
M.L.S.C.'s Avatar
M.L.S.C. M.L.S.C. is offline
M.L.S.C. is gaining momentum as a positive member of FTE.
I got 265/75-16s in the front that I keep at 75 psi, and four 235/85-16s in the rear that I keep at 65 psi are are load range E.
__________________
Real trucks rattle! '90 F350 XLT Lariat, reg cab, dually, RWD, 4.10s, factory tow package, and lots of add-on goodies.
Quote:
Originally Posted by fx4wannabe
Some guys like there GF more than their truck. Not me. They don't make these trucks anymore, they make new GF's everyday.
  #9 (permalink)
Old 11-19-2009, 11:56 AM
1OldFordMan's Avatar
1OldFordMan 1OldFordMan is offline
1991 Ford F-150
My Garage
1OldFordMan is starting off with a positive reputation.
Quote:
How about the left handed monkey wrench or bucket of steam?
__________________
On a quiet night you can hear sh*trolets rusting a mile away.
Old Rusty '91 F-150, 302, 2WD, auto., reg. cab, long bed
The Beast '01 FORD ( of course ) ex-cop car. 4.6 liter
Pat C.
Mo. chapter member
  #10 (permalink)
Old 11-19-2009, 12:50 PM
Sycostang67's Avatar
Sycostang67 Sycostang67 is offline
1993 Ford F-250
Sycostang67 has a good reputation on FTE. Sycostang67 has a good reputation on FTE. Sycostang67 has a good reputation on FTE.
Mine are load reange E with a max psi of 80 as well. I run 50 front, 65 rear.
__________________
http://www.ford-trucks.com/user_gallery/tmp/159/159207.520.390
1993 F-250 HD XLT Lariat SC 4X4 7.3/5spd ATS Turbo 173hp/335tq
1986 F-250 HD XLT Lariat SC 4X4 460/C6
1985 F-250 HD XLT Lariat SC 4X4 460/5spd
1974 F-250 HD 2wd-360/C6
1967 Ford Mustang-351W/4spd
  #11 (permalink)
Old 11-19-2009, 01:06 PM
SaikotikGunman's Avatar
SaikotikGunman SaikotikGunman is offline
SaikotikGunman is starting off with a positive reputation.
35 all around. Except the one with the slow leak, that one ranges from 20-40, depending on the day of the week.
__________________
1995 F-150 XL 4x4 5.0L 5-speed ~65k
-8' Flatbed, 1-ton+ leaves, 4" lift, 35" Mud Kings on spare set of aluminum rims
1987 F-150 Custom 4x4 5.0L auto ~202k
1985 F-250 4x2 351 auto -Potential project truck-
RIP: '88 F-150 Custom 4x4 4.9L 5-speed, '87 F-150 Custom 4x4 4.9L 4-speed
  #12 (permalink)
Old 11-19-2009, 04:20 PM
mprice mprice is offline
mprice is starting off with a positive reputation.
The Combined Gas Law applies to your tires whether the fill is 85% or 99% Nitrogen.
EDIT: Going from 85F to 15F is a -13% change so starting at 40psi would get you 35psi.
  #13 (permalink)
Old 11-19-2009, 04:35 PM
broughy84 broughy84 is offline
broughy84 is starting off with a positive reputation.
LT285/75/16s Mastercraft Courser CT Load Range E 75 psi all the time.
__________________
Matthew Brough
2005 Chevy Uplander 95k
1989 Ford F250 4x4 351W C6 122k.
2007 Dodge Ram 1500 4x4 7k
  #14 (permalink)
Old 11-20-2009, 08:43 AM
So what you're telling me is the guy at the tire shop was blowing smoke up my arse about Nitrogen having the same volume under all temperatures.
  #15 (permalink)
Old 11-20-2009, 09:13 AM
Yeah, that's not possible. When you heat a gas it expands and/or the pressure goes up and every gas expands at about the same rate. The difference between air and straight nitrogen is so little you'd need a physics lab to measure it. There are some minor benefits from it but that isn't one of them. Don't get me wrong though, it's not a bad thing, especially if you got it for free, but some of the shops really go nuts trying to upsell it.
Off the top of my head two benefits come to mind:
*less water/humidity than shop air BUT if they used a water based lube to get the tires mounted that kind of kills that
*low oxygen can be good for some kinds of rims (aluminum) that don't react well to higher pressures of O2
Tags
150 , 1993 , 2wd , 80 , acsesories , ct , f250 , ford , left , mastercraft , psi , tire , tires , truck , trucks
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
