Go Back   Ford Truck Enthusiasts Forums > Diesel > 1999 - 2003 7.3L Power Stroke Diesel
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
1999 - 2003 7.3L Power Stroke Diesel SPONSORED BY:
Is F-150 Still King?
  #31 (permalink)
Old 11-08-2009, 12:23 AM
canuckelhead's Avatar
canuckelhead canuckelhead is offline
brrrr, cold suks
canuckelhead is starting off with a positive reputation.
What I thought too, but just checking.
Thanks Brandon, looking forward to the change. The nitrogen is interesting.
__________________
Rick
2002 F350, DRW, CC, LWB, 4X4, 7.3 PSD, LARIAT
Isspro Gauges, Terminator Gauge, 6637, Foil Delete, Derale Trans Cooler, 4" MBRP Dual Exhaust, DP F6, John Wood VB, Ride Rite Front Lift,
Industrial Injection Compressor Housing, heavy foot
  #32 (permalink)
Old 11-08-2009, 12:32 AM
mechelement's Avatar
mechelement mechelement is offline
mechelement is gaining momentum as a positive member of FTE.
Brandon, it doesn't appear your front tires have a bulge at the bottom like mine do. I was asking because your tires don't appear to bulge. The ballooning is understandable.
__________________
Jason
2000 F350 XLT PSD CC 6-sp SRW 4x4
6637
  #33 (permalink)
Old 11-08-2009, 11:58 AM
Quote:
Originally Posted by bdrummonds View Post
If it makes any difference I am running 65PSI of Nitrogen in my tires. Air is good, but the oxygen molecules are actually small enough to seep through the pores in the rubber of your tires, thus the reason you have to check and adjust your pressure every few thousand miles. Nitrogen is a larger molecule and is to big to seep though the pores of the rubber. I had Nitrogen put in my tires when the were new, and over two years have not lost any pressure. I have my tires rotated, balanced, and the pressure checked every 5k miles.
Ideal Gas Law: PV = nRT; P = pressure; V = volume; n = amount of substance in # of moles; R = ideal gas constant; T = temperature. Thus, when T drops, the pressure in your tires drop (volume stays the same) even when you run pure nitrogen.
Race cars use nitrogen in their tires because they calculate the pressure increase more exactly when the tires warm up and so that when the car wrecks and explodes, the nitrogen won't act as fuel for the fire, not because the oxygen leaks through the rubber. Nitrogen leaks through rubber too, just at a slower rate.
I thought running nitrogen in my tires sounded like a good idea until my professor went on a rant about it in my thermodynamics class. LOL. It's not worth the $5.00 fee every time you fill with Nitrogen, especially when you have your own air compressor.
__________________
Jason
6637
Tags
2358516 , 265 , 26575r16 , 285 , 2857516 , difference , drw , f250 , f350 , kit , leveling , liberator , tire , tires , uniroyal , versus , walmart
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
