Go Back   Ford Truck Enthusiasts Forums > Diesel > 1999 - 2003 7.3L Power Stroke Diesel
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
1999 - 2003 7.3L Power Stroke Diesel SPONSORED BY:
Is F-150 Still King?
  #16 (permalink)
Old 11-07-2009, 10:25 AM
mechelement's Avatar
mechelement mechelement is offline
mechelement is gaining momentum as a positive member of FTE. mechelement is gaining momentum as a positive member of FTE.
bdrummonds, what pressure are you running in those tires? I have 285 D rated tires on my F350 CC SRW and hate them because of how much the sidewalls flex up front. I'm running 60psi up front. All E rated tires I've seen on trucks exactly like mine don't flex or bulge out like mine. E rated / 10 plys seem to work better. I really have to buy new tires here within the next month or so and will be buying 265's E rated.
__________________
Jason
2000 F350 XLT PSD CC 6-sp SRW 4x4 - 6637
1986 F250 XLT Lariat supercab 4x4 6.9L IDI T-19, 4.10's
  #17 (permalink)
Old 11-07-2009, 01:07 PM
Izzy351's Avatar
Izzy351 Izzy351 is offline
Izzy351 has much to be proud of Izzy351 has much to be proud of Izzy351 has much to be proud of Izzy351 has much to be proud of Izzy351 has much to be proud of Izzy351 has much to be proud of Izzy351 has much to be proud of Izzy351 has much to be proud of Izzy351 has much to be proud of
I'm running 265 Es in Good Year Silent Armor flavor. I like them so far, but they weren't that cheap. About $800 & change out the door. Believe it or not, the dealership had the best price!
__________________
  #18 (permalink)
Old 11-07-2009, 01:44 PM
CampSpringsJohn CampSpringsJohn is offline
CampSpringsJohn is a splendid one to behold CampSpringsJohn is a splendid one to behold CampSpringsJohn is a splendid one to behold CampSpringsJohn is a splendid one to behold CampSpringsJohn is a splendid one to behold CampSpringsJohn is a splendid one to behold CampSpringsJohn is a splendid one to behold
Cooper Tires - Discoverer H/T - O.E. Replacement Tires
Here is a link for cooper tires. What's nice about this link is that in the lower right hand corner is a link for tire specifications. It lists the tire sizes available, overall height and width, rating, recommended rim widths, and even the tread depth. I run cooper ATR's on both trucks. Cooper makes a lot of different tires. Check out the different types of tires they sell. As you check out the different tires, they have a rating system there also for traction in mud, snow, wet, or dry. Also the noise level.
__________________
1997 Super Duty, PSD,6637, high idle, 50hp, & 80hp. 150cc injectors.
2002 F250 Crew Cab, 8' bed, 4X4, PSD, 6637, 4" magnaflow exhaust, high idle, 50, 75 tow, 100, 120, & 140, HPX Crossover
Kentucky Chapter Member
  #19 (permalink)
Old 11-07-2009, 02:51 PM
Bigcat350's Avatar
Bigcat350 Bigcat350 is offline
Caution! Will Blow Smoke.
Bigcat350 has a good reputation on FTE. Bigcat350 has a good reputation on FTE.
I just got a quote today from our local Firestone dealer. He recommended the 235/85/16 Firestone Transforce H/T for highway all 6 tires on the truck for $1063 ant the A/T a more aggresive design for $1219 on the truck. I ask about warranty and that is road hazard but there is no mileage warranty. I do see a lot of these tire on trucks around here. Does any one here run these? I would like to put some bigger tires on also since I will be putting out over a grand any way.
__________________
Eddie Late 01/99 F-350 XLT 7.3 EC DRW 4x4 6-speed 4:10, some common mods done. 6637 filter & Pete's Cover, Billet Grill,Muffler Delete,Stancore GPR,2 Pillar Pod Gauges,Swamps Hybrid Single Shot Injectors,DP Tuner NS,Modified Stock,Hi-Idle,80E,120R,140A,Foil Delete,CCV,AIH Delete,Garrett GTP38R BB Turbo with a 1.15 Housing, Valair Clutch. And more. Over 400HP BIG RED TRUCK - PAA#79
  #20 (permalink)
Old 11-07-2009, 03:24 PM
pwstroker69 pwstroker69 is offline
pwstroker69 is starting off with a positive reputation.
I have been running Transforce AT's (265/ 70/ r16's) on my 2WD, SRW since switching from the Michelin's about 3 years ago. They were similar in price at the time I switched, have lasted twice as long and ride nicer....... in my HUMBLE opinion.
I'm glad I read this thread because I am ready for a new set and wanted to switch up a size, so will go with the 285's this time but will DEFINITELY shop the Firestone Transforce's again. Mostly hard top for me when I switched (had 2 Mich rear and 2 F/stones up front fer a while) and they seem to do well on the hard/ sand and gravel roads where I live now also.
Hope this helps,
[quote=Bigcat350;8117748]I just got a quote today from our local Firestone dealer. He recommended the 235/85/16 Firestone Transforce H/T for highway all 6 tires on the truck for $1063 ant the A/T a more aggresive design for $1219 on the truck. quote]
__________________
David.
99.5 PSD. CC, SB, 2WD XLT. Batt box/ intake delete w 6637 & Pete's cover. NO cat OR back (naked for now), DP with 40T 80E & 120R, ISSPro gauges, still waiting to be finalized. Also in the box and waiting; AIH delete from Clay, ITP in tank mods, DF RR and 6.0 tranny cooler.
  #21 (permalink)
Old 11-07-2009, 04:01 PM
spdmpo's Avatar
spdmpo spdmpo is offline
2000 Ford F-350
spdmpo has a very good reputation on FTE. spdmpo has a very good reputation on FTE. spdmpo has a very good reputation on FTE.
I also went with the 285/75-16 on mine. The tire is a little taller and I do like the way it looks, but I kind of regret doing that because it affects the final gear ratio and I can tell a difference when pulling. But not bad enough to buy a new set of tires I guess.
__________________
Keith
"The Wicked Flee When No Man Pursueth, But The Righteous Are Bold As A Lion."
'00 F350 CC LB 4x4 PSD - DP Live Tuning, ATS housing, 6.0 IC, Ford AIS, 4" Magnaflow, BD X-Monitor, Front leveling kit, Firestone air bags, JWVB, FRx, HPX, coolant filter, Hutch mod, ITP in-tank, Carter lift pump, CCV, Tru-cool, AIH delete, OBA, cold a/c
  #22 (permalink)
Old 11-07-2009, 04:11 PM
74baja's Avatar
74baja 74baja is offline
2001 Ford F-350
74baja is starting off with a positive reputation.
I'm in the same exact boat as Keith. Just put on 285s, they look cool, but with 3.73 gears, I noticed more dropping out of OD, and even possibly more sluggish acceleration. I got Firestone Destination A/T 285/75/16. They're alright, I guess. I got a decent deal.
__________________
Jack
2001 F350 7.3 PSD SRW SC SB Limited Slip 3.73's 4x4 Off-Road Auto. 4" Magnaflow, 6637, Transgo HD-2, Autometer 3 gauge pod w/ pyro, Trans. temp. and boost, PHP PHOENIX (40T, 80DD, 100P, SS), GPR LED, FRx, HPx, Foil Delete, Truxport bed cover, Hide-A-Ball Gooseneck Hitch...
  #23 (permalink)
Old 11-07-2009, 04:49 PM
Sorry, mine should've read 265/ 75/ 16's, NOT 256/ 70.
__________________
David.
  #24 (permalink)
Old 11-07-2009, 05:06 PM
schlepprock250's Avatar
schlepprock250 schlepprock250 is offline
1999 Ford F-Super Duty
schlepprock250 is gaining momentum as a positive member of FTE. schlepprock250 is gaining momentum as a positive member of FTE.
Quote:
Originally Posted by papadelogan View Post
I ran Uniroyal Liberators in 285/75R16 and they lasted just over 60,000 miles. They were quiet on the highway, were rated for 3400lbs each (D load rating), had good traction (though I'd sipe ANY tire that didn't come that way) and cost under $700 mounted, balanced, ... TOTAL. Get 'em at Wal-Mart.
I'm running the same tire as Brendon,a little over $600., D-rated,285's,they're really a beefy looking tire compared to the 265's.
__________________
Phil '99.5 F-250 SuperDuty 4x4 CrewCab/7.3 PowerStroke Magnaflow4"TurboBack SS Exhaust 5"Tip DP-Tuner:Stock,High Idle,Lope Idle,60Tow,80Econo,120Race AIH Delete OverBoost Annihilator AutoMeter UltraLite Series Gauges Boost/Trans/Pyro BTS ValveBody Spicer/Custom Driveline ATS Housing HPX Crossover DIY Tymar 6637 6.0 Trans.cooler Bellowed Up Pipes PAA Member # 34
  #25 (permalink)
Old 11-07-2009, 05:15 PM
Bigcat350's Avatar
Quote:
I have a new set of these on my 1/2 ton Chevy 4X4 and they are great on it. I have had 2 sets on it before and get about 60,000 each but I am just alittle hesitant on putting them on a dually being a D rated and I haul. If I had a F250 and didn't haul alot thats what I would get.
__________________
  #26 (permalink)
Old 11-07-2009, 06:36 PM
Billyclub's Avatar
Billyclub Billyclub is offline
Billyclub is starting off with a positive reputation.
I'm running 285/75/16's Michelin LTX AT2's, really liking this tire. Just put 2400 miles on them with a trip to Illinois and back to Maine. I have mud flaps on my truck and they do rub, not bad but definitely hear them at full turn. Got my Michelin's at Sams Club last month with a $70 instant rebate. Equates to $210 a tire.
__________________
2000 Ford F250SD Lariat 7.3, 4" MBRP Turbo back,
6637 Cold Air Intake, A Pillar 3 Gauge POD- EGT, Tranny Temp, Turbo boost. Superchip, Zoo mod. Foil delete, Michelin LTX AT2- 285/75/16, '09 8' bed
  #27 (permalink)
Old 11-07-2009, 10:14 PM
bdrummonds's Avatar
bdrummonds bdrummonds is offline
Maximus Overdrive
1999 Ford F-250
bdrummonds has much to be proud of bdrummonds has much to be proud of bdrummonds has much to be proud of bdrummonds has much to be proud of bdrummonds has much to be proud of bdrummonds has much to be proud of bdrummonds has much to be proud of bdrummonds has much to be proud of bdrummonds has much to be proud of
Quote:
the reason you are seeing the "sidewall flex" is because you now have an 11.5" wide tire on a 7" wide rim. I doesn't matter whether you are running an 8 ply D rated or a 10 ply E rated you will still see the same sidewall deflection. Now if we moved up to a 10" wide rim then we would both see much less deflection. To bring this into perspective, stock 265 tires are 31x10.5x16 on a 7" wide wheel. 10.5"-7"= 3.5". Now 3.5"/2= 1.75" of overhang per side of the wheel. An 11.5" wide tire)285/75/16 would provide 2.25 inches of overhang, and a 12.5" wide tire(305/70/16) will provide 2.75" of overhang, so of course we're going to have more sidewall deflection. DISCLAIMER: the above figures are for representative purposes only. Manufactures measure their respective tires differently, but the above numbers are close enough for discussions sake.
If it makes any difference I am running 65PSI of Nitrogen in my tires. Air is good, but the oxygen molecules are actually small enough to seep through the pores in the rubber of your tires, thus the reason you have to check and adjust your pressure every few thousand miles. Nitrogen is a larger molecule and is to big to seep though the pores of the rubber. I had Nitrogen put in my tires when the were new, and over two years have not lost any pressure. I have my tires rotated, balanced, and the pressure checked every 5k miles.
__________________
Brandon
PAA MEMBER # 7.3, 99.5 CC,4X4,SB, leveled,live tuned by Jody,1.15 van turbo w ATS housing,6.0 IC,AFE big boost filter, Petes Armour, FASS/DFA fuel system,fuel bowl delete,black MBRP stacks, 02 headlights,F650 dash, and a bunch other stuff that wont fit in my sig. 299K and counting.
  #28 (permalink)
Old 11-07-2009, 10:33 PM
canuckelhead's Avatar
canuckelhead canuckelhead is offline
canuckelhead is starting off with a positive reputation.
Lots of good info, thanks
I replaced the rears this year with Michelin LTX M/S, 235 85/16 E's, planning to do the same for the front this winter but will increase the width to 285's by 85/16 E's for the look.
Question- your talking sidewall flex due to the narrow rim and wider tire. Flex=heat, Could this be a possible issue with 2900 lbs on the pin, flying down the hard stuff in the truck's sweet spot?
__________________
RICK
2002 F350, DRW, CC, LWB, 4X4, 7.3 PSD, LARIAT
Isspro Gauges, Terminator Gauge, 6637, Foil Delete, Derale Trans Cooler, 4" MBRP Dual Exhaust, DP F6, John Wood VB, Ride Rite Front Lift,
Industrial Injection Compressor Housing, heavy foot
  #29 (permalink)
Old 11-07-2009, 10:41 PM
That makes sense. I'm going back to the stock size 10 ply E rating tire. I don't like the sidewall bulge or flex. The rear tires don't bulge, only the fronts. It's odd looking and I think the truck's ride feels slushy compared to the same truck running 10 ply 265's.
__________________
Jason
  #30 (permalink)
Old 11-07-2009, 11:13 PM
bdrummonds's Avatar
Maximus Overdrive
1999 Ford F-250
It could, but in my experience (11.5K 5er) towed all over the Southeast US in 95* to 100+* temps, it has not ever presented a problem. My theory is that with the larger area of sidewall and tread that is contacted with the flow of air around the tires is that the heat that may have been caused by the flex is cooled. i may be wrong but it makes sense in my head.....
__________________
Brandon
Tags
2358516 , 265 , 26575r16 , 285 , 2857516 , difference , drw , f250 , f350 , kit , leveling , liberator , tire , tires , uniroyal , versus , walmart
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
