Go Back   Ford Truck Enthusiasts Forums > Diesel > Pre-Power Stroke Diesel (7.3L IDI & 6.9L)
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
Is F-150 Still King?
  #1 (permalink)
Old 11-04-2009, 09:21 PM
kenpobuck kenpobuck is offline
kenpobuck is starting off with a positive reputation.
arp head studs
I got my arp studs today and was reading the paperwork with them. It says to torque them to 85 ft lbs. but Chilton says to go in four stages, 40, 65in numbered sequence, then inline sequence to 75 twice. Do I just go in the numbered sequence once with the studs or follow the sequence in the book?
__________________
DON'T BUY IT ..FAB IT!!!!
88 Bronco XLT 6.9 IDI, C6, Dana60 rear, 50 front, 3.55 gears, 33x12.5x16.5's. built by me becuase I just had to!
Kentucky Chapter Member
  #2 (permalink)
Old 11-04-2009, 09:52 PM
johnboggs21's Avatar
johnboggs21 johnboggs21 is online now
johnboggs21 is starting off with a positive reputation.
I would definitly torque them in stages. Probly should go with what the chiltons manual says.
__________________
1993 F-250HD 7.3L IDI E4OD
I'm gonna sign my name in that diesel smoke and let the ones that come along behind me choke!
  #3 (permalink)
Old 11-04-2009, 09:53 PM
symonds86's Avatar
symonds86 symonds86 is offline
symonds86 is starting off with a positive reputation.
normally you go with what the studs say, i called arp when o got the ones for my 347 and they said go with there specs because of the way they are designed. id call them and double check just to be safe
  #4 (permalink)
Old 11-04-2009, 10:05 PM
I will call them tomarrow and find out. I am putting a lotof money into these heads and studs with the current economy and if I screw them up my baby will kill me lol!!
__________________
  #5 (permalink)
Old 11-04-2009, 10:24 PM
symonds86's Avatar
i hear ya that y i called them aswell ididn't wanna ruin 6000 dollars worth of parts over head studs being torqued wring
  #6 (permalink)
Old 11-04-2009, 10:29 PM
87crewdually's Avatar
87crewdually 87crewdually is offline
87crewdually is starting off with a positive reputation.
Torque in the sequence and values written in the book ending with the final torque value of ARP's spec.
This is where it gets crazy. You need to "untorque" in the reversal sequence and retorque them all over again IIRC 5 times. The reason for this is to pre stretch the new studs.
Learn from my mistakes as I didn't know this at first and replaced the gaskets again after a few hundred miles because the studs stretched just enough to weep pressure into the water jackets. Also I ended up torquing my studs to 106 ftlbs with no issues since.
__________________
87 CCD, 6.9 Banks Sidewinder turbo & ARP studs, fresh pump & injectors, str8 Pipe out the side, worked C-6, 4.56R&P & Laycock/GearVendors Overdrive
  #7 (permalink)
Old 11-04-2009, 11:24 PM
Dave Sponaugle's Avatar
Dave Sponaugle Dave Sponaugle is offline
1986 Ford F-250
Dave Sponaugle is a name known to all Dave Sponaugle is a name known to all Dave Sponaugle is a name known to all Dave Sponaugle is a name known to all Dave Sponaugle is a name known to all Dave Sponaugle is a name known to all
When you install the studs, do use the pattern in the engine manual, starting in the center of the head and working out in a circle.
Also do it in steps like the engine manual specifies.
When you read the ARP paper, torque to spec and then remove a minimum of four times.
Then on the fifth install, you are good to go.
The install and remove four times helps the nuts and stud threads wear to each other.
And I payed rather close attention to how many turns it took to get to torque each time I installed mine.
The fifth time each nut turned about 1 turn farther than it did the first time I installed them.
Be sparing with the moly assembly lube, you don't want to contaminate the head gasket or mating surfaces with lube.
I wiped the head and block surface with acetone to remove all traces of oil before I dropped the gaskets and heads on.
__________________
86 F250 HD 6.9 IDI ATS turbo "not exactly" stock 4x4 T19 BW1345 3.55LS both ends D60 front, 10.25" Sterling rear, ram air, dual stacks.
"I dig dirt"
FTE Guidelines
FTE Moderator IDI diesel forum
WV Chapter Member
  #8 (permalink)
Old 11-05-2009, 07:17 PM
Thanks guys that is what I needed to know.
__________________
  #9 (permalink)
Old 11-06-2009, 10:43 AM
Marianna2003 Marianna2003 is offline
Marianna2003 is starting off with a positive reputation.
I believe that you are collapsing the gasket and seating it. The way metallurgy works, bolts are not rigid. Nothing is totally rigid. The bolts are like real tough springs. They normally stretch. The trick is to stretch them enough to hold the gasket in place under the highest pressures possible while leaving a safety margin for possible anomalies.
Tags
69 , 69l , 73 , 73l , arp , bolts , diesel , ford , head , idi , iirc , kit , pattern , stud , studs , torque
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
