I have a 06 F350 with a Dump body...When the trailer is hooked up it only has runner lights..Im using a 7-pin plug in tester with the LED's. And backing it up with my voltmeter. I have NO power for the turn signals and brake lights(left and right)....i have checked ALL the fuses both under dash and underhood. however i am UN-sure of the relay location...should there be a relay for each side? 2? any help would be great!
__________________ White 2004 F250 6.0 CC SB Auto FX4. Mods 4" Mbrp TB, Amsoil Bmk-11 By-pass,Intakelbow.com polished elbow,Napa #4019 coolant filter kit,Autometer Boost/Coolant Guage. 1990 Mustang LX 2.3L Turbo 400RWHP.
Is this the first time you used the connector or has it worked before? Left turn/stop and right turn/stop should each have its own fuse. IIRC, the 99-03's have the relays under the dash below the radio, your truck may be different though. Find the two fuses I mentioned and check them with an ohm meter. Sometimes they look good but aren't.
__________________
Trevor
01 F-350 CC 8ft bed SRW 7.3L a/t. 152k
PAA Member #7
Ok, just looked up your owners manual. If you have a copy of it, open it to page 212. There's a diagram of the fuse box under the hood. Relay 201 is for rightt turn/stop and relay 202 is left turn/stop. You can swap the a/c clutch relay in spot 203 with one of those to verify that they work. The fuse for both relays is #9 in the same box. Its a 20 amp mini fuse, those are especially hard to see when blown.
I can tell that some of the fuses have been replaced before...but all checked good with my meter. The lights use to work...when i turn the hazards on there is 1 relay clicking in the fuse panel in the engine bay....thats it..are the trailer lights on a different relay from the flashers on the actual truck? all fuses in that panel tested good. and all lights on the actual truck work..........
With the 4-ways on, there should be two relays clicking in the under-hood fuse box. The relays provide dedicated power to the trailer so if something happens there, it wont take out the signals on your truck.
Can you tell which relay was clicking? Its possible they could still be bad even if it clicks. Did you try swapping the one I mentioned?
__________________
Trevor
PAA Member #7
Curious to see what you have going with yours too. I have a 2006 F-250 and I have the same problem, I have running lights, but no turn signals or brake lights. My trailer has brakes on it and they won't work unless I manually use the brake controller. I'd be surprised if both relays went out at the same time. Any added help is appreciated.
#9 fuse had a spread out terminal on the fuse panel....from some one wiggling the fuse the wrong way during removal. It still tested good with my meter but the way i found it was removing it and saw the fuse prongs were burnt....so after i fixed the fuse terminal both relays started clicking....now i had left side but no right.....traced that to a broken wire close to the 7-pin female connector at the back of the truck.............thanks for the help!!
Dan, do you have a factory installed brake controller or an aftermarket add on? The brakes not working when you apply the pedal sounds like the controller isn't receiving a signal that you're on the brakes. On an aftermarket controller, its a simple wire going from the brake pedal switch to a terminal or wire or the controller. No idea how the factory one is hooked up though.
__________________
Trevor
PAA Member #7
Yep, it's the factory controller. Thinking I may have to take it in somewhere to have it looked at. Need to go through all the fuses first though. maybe today, the weather's nice up here.
Going through something similar with my 06 with the integrated brake controller right now. Everything worked fine (or so I thought?), installed new brakes on my trailer and it seemed like they weren't working. Checked the 7 pin and only getting 1 volt to the trailer brakes when I step on the pedal with the controller set on 5, hitting the slide gives me 7 volts on the back.
I read a couple of posts on various boards that the integrated controller doesn't apply much voltage unless you are going over 15 mph? If I hold the slide, the trailer brakes lock up so I'm assuming it's working correctly. I have to take the trailer out next week, only have some lawn furniture to move so it shouldn't be a problem either way.
__________________
2006 F250 XLT 4X4 V10 CC/LB aka "Big Red"
99-122 Bright Atlantic Blue Saleen S-281 S/C Convertible
FFR4784 Factory Five Daytona Coupe #139
