Go Back   Ford Truck Enthusiasts Forums > Diesel > 1999 - 2003 7.3L Power Stroke Diesel
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
1999 - 2003 7.3L Power Stroke Diesel SPONSORED BY:
Is F-150 Still King?
  #1 (permalink)
Old 11-04-2009, 08:46 PM
cattlerancher cattlerancher is offline
cattlerancher is starting off with a positive reputation.
Is elc coolant realy needed
I know its needed in semis and other diesel motors to keep from eating holes in the block, but is it realy needed in the 7.3?
__________________
00 F350, sc, 7.3, 4x4, 6 sp, Lariat, Dually, TS 6 pos chip, 6637, 4" MBRP, Pyro, J&I Flatbed, Bloomington Spring Shop 1.5 ton rear springs
  #2 (permalink)
Old 11-04-2009, 09:02 PM
indyF-350psd's Avatar
indyF-350psd indyF-350psd is offline
Springfield Armory
indyF-350psd is gaining momentum as a positive member of FTE. indyF-350psd is gaining momentum as a positive member of FTE.
no its not "needed" but you dont have to mess with additives and other stuff like that. plus the intervals using elc coolants are alot longer than normal coolants if you wanted to take it that far....
__________________
BILL ----> 2002 F350 7.3L CC LB DUALLY LARIAT 6X6
http://www.roadsidehelpnetwork.info/
  #3 (permalink)
Old 11-04-2009, 09:05 PM
Izzy351's Avatar
Izzy351 Izzy351 is offline
Getting Faster...
Izzy351 has much to be proud of Izzy351 has much to be proud of Izzy351 has much to be proud of Izzy351 has much to be proud of Izzy351 has much to be proud of Izzy351 has much to be proud of Izzy351 has much to be proud of Izzy351 has much to be proud of
What Bill said. At least go with the gold stuff -- it lasts 100k and you don't mess with test strips & additives.
__________________
  #4 (permalink)
Old 11-04-2009, 09:06 PM
Tenn01PSD350's Avatar
Tenn01PSD350 Tenn01PSD350 is offline
for now.....
Tenn01PSD350 is a splendid one to behold Tenn01PSD350 is a splendid one to behold Tenn01PSD350 is a splendid one to behold Tenn01PSD350 is a splendid one to behold Tenn01PSD350 is a splendid one to behold Tenn01PSD350 is a splendid one to behold Tenn01PSD350 is a splendid one to behold
Interesting question. Manufacturer says yes so I will not chance it. Why would you think a 7.3 would be different than other diesels?
__________________
Mike
Silver truck with a hairdryer and sticks. A lot of other less expensive chit too which adds up to expensive.
  #5 (permalink)
Old 11-04-2009, 09:07 PM
RedBoat's Avatar
RedBoat RedBoat is offline
Rather Be Floatin
RedBoat has a very good reputation on FTE. RedBoat has a very good reputation on FTE. RedBoat has a very good reputation on FTE.
I am using the final charge coolant from WallyWorld. It was easy to get and says it does not need to be tested for 300k and replaced for 600k.
__________________
Costa
2003, F-250, 7.3L, 2wd, Auto, 4 Door, Lariat, Short Box, DP-Tuner, Isspro Pyro, Boost, and Tranny Temp, 6637 with Petes cover, Fumoto, Bilsteins,
2" Leveling Kit, Hutch/Harpoon, Foil Delete Mod, Upgraded boots, CCV Mod, Ac Improvement Mod, Michelin LT285/75R/16 LTX AT2's
  #6 (permalink)
Old 11-04-2009, 09:11 PM
F350-6's Avatar
F350-6 F350-6 is online now
Slow Typing
F350-6 has a brilliant future F350-6 has a brilliant future F350-6 has a brilliant future F350-6 has a brilliant future F350-6 has a brilliant future F350-6 has a brilliant future F350-6 has a brilliant future F350-6 has a brilliant future F350-6 has a brilliant future F350-6 has a brilliant future F350-6 has a brilliant future
Quote:
No, it's not needed at all, but if you're running the green coolant, you need to test for SCA's to make sure the coolant will not eat a hole in your block. The green coolant requires test strips and additive, the gold coolant needs to be changed at 100,000 miles, and the new ELC should be changed every 300,000 miles (or possibly some timetable I'm not aware of).
__________________
Chris
2002 F350 6-speed 444 CID. XLT, Heated Seat, 310,000 & counting.
RHN Mods & Maintenance
“Good judgment comes from experience, and a lot of that comes from bad judgment.” Will Rogers
  #7 (permalink)
Old 11-04-2009, 09:24 PM
Old and Busted's Avatar
Old and Busted Old and Busted is offline
Old and Busted is starting off with a positive reputation.
Do we have a verdict yet on the early '99s? I find conflicting info even here in this forum. Bought my truck with green and it had the additive in it. Would like to flush it and change to atleast the gold, but I'm not sure.
__________________
-Kenny-
Early 1999 F-350 Crew Cab SRW 7.3L 4x4 ZF6 Speed Manual 160K, 6637 Filter
  #8 (permalink)
Old 11-04-2009, 09:42 PM
hucka1a's Avatar
hucka1a hucka1a is offline
Welcome Home 776th!!!
hucka1a has a great reputation on FTE. hucka1a has a great reputation on FTE. hucka1a has a great reputation on FTE. hucka1a has a great reputation on FTE.
Quote:
It's really at your own discretion. IH say's no, but there are several guys that have racked up some miles running ELC. I chose to stick with the conventional coolant, but I did add a bypass filter.
__________________
Huck PAA Member 66, E.T.A.P.S. Member
early 99 (11/24/98) F250, PSD, auto, 4x4, ec, short bed.6637/wrapped by Pete, CCV Mod, 6.0 Trans Cooler, MKO 4", '05 Power Seats(Thanks Scott), PMT2, Transgo Tugger, DP Tuner F6, diy oba, Isspro Performax, pyro, boost,Trans temp, and EOT mueckster 710 cap,True-Trac(Thanks Cory),diy Coolant filter.Riffraff Diesel Pete's Covers DP-Tuner Roadside Help Network
  #9 (permalink)
Old 11-04-2009, 09:47 PM
F350-6's Avatar
Slow Typing
If it were me, I'd stick with the gold. Is changing the coolant every 100,000 miles really too much to ask?
__________________
Chris
  #10 (permalink)
Old 11-04-2009, 09:55 PM
for now.....
Quote:
Whoops, misunderstood the question. No, not needed, just keep up with SCA levels. My bad.
__________________
Mike
  #11 (permalink)
Old 11-04-2009, 09:58 PM
Quote:
It's not too much to ask. I would gladly settle for the gold and forget about the test strips if there isn't a problem with the early '99s.
__________________
-Kenny-
  #12 (permalink)
Old 11-04-2009, 10:00 PM
F350-6's Avatar
Slow Typing
From what I've heard, it's the new Red ELC that has the issues with the E99. The gold stuff should be fine.
__________________
Chris
  #13 (permalink)
Old 11-04-2009, 10:05 PM
hucka1a's Avatar
It's the OAT or Organic Acid Technology, that's found in most extended life coolants. That is not compatible in the early 99's. Most extended life coolants have oat's, that's why I chose to stick with the green junk.
__________________
  #14 (permalink)
Old 11-04-2009, 10:22 PM
Izzy351's Avatar
Getting Faster...
Gold is partially OAT and partially SCA, which is why it's called H-OAT, or Hybrid Organic Acid Technology.
__________________
  #15 (permalink)
Old 11-04-2009, 11:24 PM
mueckster's Avatar
mueckster mueckster is online now
Redneck Wrencher
mueckster is a splendid one to behold mueckster is a splendid one to behold mueckster is a splendid one to behold mueckster is a splendid one to behold mueckster is a splendid one to behold mueckster is a splendid one to behold
Quote:
Excuse my ignorance, but what is different about the E99's that IH doesn't recommend the ELC in them. I must have missed somthing somewhere. I figured the cooling system reqirements would be the same for all.
__________________
-Roland-
'01 F-250 Lariat CC SB 4x4, DP Tuner F6, AFE II w/ Pete's Cover, Garrett GTP38R w/ 1.15, 6.0 IC, Casserly SS 160cc 100% over, Stealth HPOP, Autometer Phantom gauges, DIY HD 4R100, 4" MBRP, Procomp lift pump, CCK, TruCool, billet 710 cap, Truetrac rear
PAA Member #62
Tags
coolant , elc , fleetrite
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
This forum is owned and operated by Internet Brands, Inc., a Delaware corporation. It is not authorized or endorsed by the Ford Motor Company and is not affiliated with the Ford Motor Company or its related companies in any way. Ford® is a registered trademark of the Ford Motor Company.
