Go Back   Ford Truck Enthusiasts Forums > Diesel > 1999 - 2003 7.3L Power Stroke Diesel
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
1999 - 2003 7.3L Power Stroke Diesel SPONSORED BY:
Is F-150 Still King?
  #1 (permalink)
Old 11-04-2009, 08:10 PM
agentsmith1 agentsmith1 is offline
agentsmith1 is starting off with a positive reputation.
Titan Fuel Tank Install
Hi,
I thought some of you might like to see how big the Titan 67 gallon fuel tank is vs stock. I pulled the bed to spray some Eastwood extreme chassis black, install MBRP 4" exhaust, and install the Titan 67 tank. I didn't need to pull the bed, but it made it easy to spray the frame.
The tank is huge!
I was going to take a pic of the tank installed with the bed off, but I forgot.
My Truck
Ford 2002 F-350 4x4 w/7.3
05-07 front end
08-10 manual tow mirrors, bed, & rear bumper
I'd like to get a 2011 front clip!
  #2 (permalink)
Old 11-04-2009, 08:14 PM
agg_bagg agg_bagg is offline
agg_bagg is gaining momentum as a positive member of FTE.
looks good man i would love to have that extra fuel. does it just bolt up and use the existing wires(for the fuel gauge). what all did you have to buy with it or did it come with it. and how much did that cost if you don't mind me asking.
__________________
Jeron
Early 99 F250 SD PSD Super Cab, 210,000 miles, 4" lift 35" tires, Hutch & Harpoon, CCV, 6637, TransGo Tugger with rebuild, DiPricol Gauges EGT/Boost/Trans Temp, Door Lock Foil Fix
  #3 (permalink)
Old 11-04-2009, 08:17 PM
Kwikkordead's Avatar
Kwikkordead Kwikkordead is offline
Jesus spoke a lot
1999 Ford F-550
Kwikkordead has a brilliant future Kwikkordead has a brilliant future Kwikkordead has a brilliant future Kwikkordead has a brilliant future Kwikkordead has a brilliant future Kwikkordead has a brilliant future Kwikkordead has a brilliant future Kwikkordead has a brilliant future Kwikkordead has a brilliant future Kwikkordead has a brilliant future Kwikkordead has a brilliant future
Nice.
I love big fuel tanks, you can drive farther than your butt and/or bladder will allow and still have plenty of fuel to get to the next station.
__________________
Dan
1999 F550 4x4 ZF6 pulling a Cedar Creek 36RLTS. Lotta mods.
1999 VW Jetta TDI 5speed stick, all stock.
1996 Audi A4 Quattro. Unstoppable in the snow and ice.
God and Dog
  #4 (permalink)
Old 11-04-2009, 08:35 PM
papadelogan's Avatar
papadelogan papadelogan is offline
of Brent's moral decline
papadelogan has a great reputation on FTE. papadelogan has a great reputation on FTE. papadelogan has a great reputation on FTE. papadelogan has a great reputation on FTE. papadelogan has a great reputation on FTE. papadelogan has a great reputation on FTE.
WOW! Massive!!! I've thought about getting the 52(55?) gallon tank for my shortie... with luck I'd almost do 1,000 miles. (sad side note: my 96 Passat TDI with 19 gallon tank can almost do that distance now...but it'll never tow a gooseneck!!)
__________________
Brendan
1999 F250 CC SB 4x4 7.3 PSD named "Nyx"
BTS VB;6637;A-pillar (pyro, boost, trans temp);XM radio;Alpine CDA-9831 w/RCA inputs;Leveling kit;Adrenaline HPOP;UnderCover tonneau cover;05 headlights
  #5 (permalink)
Old 11-04-2009, 08:50 PM
Thanks guys,
The tanks comes with everything you need to bolt it up. It was really easy to do if you have the tools and some mechanical skills. The Titan tank cost just under $1400 bucks shipped. A lot I know, I would have liked a new intercooler, but the extra range is worth it to me. As Kwikkordead said I'll have to pull over to take a wee more than I'll need to fill up my truck. I know it will add a lot of weight when it's full, but I'll be able to buy my diesel when I find it at a good price. The tank has pros & cons but what really made me buy one is the extended range, if I'm pulling my trailer and can't get into a diesel pump at the gas station I can just go on to the next one. It really sucks that so many gas cars block the diesel pump when they get gas.
Note: I paid about $1200 bucks, $1400 is the shipped price from Titan. If you look around you can find it for around $1200.
  #6 (permalink)
Old 11-04-2009, 08:56 PM
binuya's Avatar
binuya binuya is online now
binuya is gaining momentum as a positive member of FTE.
Nice! Thanks for sharing that. Way down the line, this is something I would like to do as well. Too bad Titan's shortbed version isn't as big as yours though. I believe they have a 47 and a 51 gallon tank for the shortbed. A 67 gallon tank would be great.
__________________
Alvin
2001 F250 CC SB 4x4 Lariat
6637, MBRP 4" Turbo Back, HPX, AIH Delete,
Isspro EV2's, Bilsteins, Warn Premium Hubs, Firestone Bags with Airlift onboard
Homebrew American Biodiesel (B100 whenever I can)
  #7 (permalink)
Old 11-04-2009, 09:18 PM
triskit16's Avatar
triskit16 triskit16 is offline
2000 Ford F-250
triskit16 has a very good reputation on FTE. triskit16 has a very good reputation on FTE. triskit16 has a very good reputation on FTE.
Off the subject a lil bit, but how hard was it to remove the bed? The bolts and then disconnect tail light wiring and filler neck, or is it a little more involved?
__________________
-Tristan
2000 F-250 XLT 4x4 Ext Cab SB Auto DP Tuner 60T 80E 120R 4" Turbo Back WW F650 Dash DiPricols MAC Intake Foil Delete CCV Firestone Bags LED...
  #8 (permalink)
Old 11-04-2009, 10:41 PM
jeff7825's Avatar
jeff7825 jeff7825 is offline
2001 Ford F-250
jeff7825 has a good reputation on FTE. jeff7825 has a good reputation on FTE. jeff7825 has a good reputation on FTE.
Damn that thing dwarfs that stock tank, and I thought my short bed tank was pretty big when I had it out.
__________________
Jeffrey
2001 Ford F-250 Lariat CC SB 4x4 7.3 Powerstroke
Dipricol HPOP Gauge for sale: http://www.ford-trucks.com/forums/89...ure-gauge.html
  #9 (permalink)
Old 11-04-2009, 10:53 PM
big poppa's Avatar
big poppa big poppa is offline
Monitoring The Vitals
2003 Ford F-250
big poppa has much to be proud of big poppa has much to be proud of big poppa has much to be proud of big poppa has much to be proud of big poppa has much to be proud of big poppa has much to be proud of big poppa has much to be proud of big poppa has much to be proud of
Nice job, thats some nice volume for a replacement, thanks for sharing..
__________________
Mike's 03 F-250 7.3 CC SB XLT 4x4 Auto, GTP38R BB Turbo, S-B intake With Pete's Armor, MBRP Duals, DP Tuner F-5, 3 Isspros Gauges In Pillar, JW-VB, OBA, Clay's AIH Delete, Clay's FRx (CCK), CCV, Zoodad And GPR LED Mod and some other goodies. 131,000 on the ticker. PAA#26 Roadside Help Network Riffraff Diesel Performance http://www.dieselorings.com/ http://www.guzzle7pt3.com/index.php
  #10 (permalink)
Old 11-04-2009, 11:08 PM
mndiesel's Avatar
mndiesel mndiesel is offline
USAF 84-90
1999 Ford F-250
mndiesel has a good reputation on FTE. mndiesel has a good reputation on FTE. mndiesel has a good reputation on FTE.
Quote:
Mike love the avatar!!!!!!!!!! Tomb of the unknown soldier (if I am not mistaken). reps when I can
__________________
Tom 99.5 f-250 7.3 sd ec, 4x4 many mods
Minnesota Chapter Leader
Join the MN chapter Here
Join the Roadside help Network
  #11 (permalink)
Old 11-05-2009, 08:25 PM
shadetree01 shadetree01 is offline
shadetree01 is starting off with a positive reputation.
I have this tank as well it's nice to able to pull trailers without stopping for 600mi. The only things I don't like is no baffles in the tank so fuel sloshes and you will feel a thump under the cab at anything around 3/4 of a tank. The next thing I don't like is mine loves to spit a lot of fuel when filling when pump shuts off. I made sure there was no low spots in vent line to trap fuel. Titan says the rollover valve needs bigger holes drilled in it. And lastly I felt uncomfortable with only 2 straps holding the tank up so I added another one on the nose of the tank to help support it a little better afterall it's like 550 lbs full of fuel. With this being said it is very nice replacement tank that utilizes all the factory stuff from the old tank. It must have been a little faster with bed off especially for the vent lines.
  #12 (permalink)
Old 11-05-2009, 09:13 PM
makomaker's Avatar
makomaker makomaker is offline
makomaker is gaining momentum as a positive member of FTE. makomaker is gaining momentum as a positive member of FTE.
My envy meter is running on high. I have been eyeballing that thing for a while now. Titan also makes a tank that goes where your spare fits and transfers into your stock tank, I think it runs at 40+ gals for a total fuel haul in at 80 gals...
__________________
Jay
'02 F350 DRW 4x4. 6637. THE DP Tuner. Isspro gauges. MBRP 4". HPX. AIH.
LSU National Champs 1958 2003 2007
[SIGPIC][/SIGPIC]
We contend that for a nation to tax itself into prosperity is like a man standing in a bucket and trying to lift himself up by the handle.-Sir Winston Churchill
  #13 (permalink)
Old 11-05-2009, 10:03 PM
PaysonPSD's Avatar
PaysonPSD PaysonPSD is offline
Support FTE
PaysonPSD has much to be proud of PaysonPSD has much to be proud of PaysonPSD has much to be proud of PaysonPSD has much to be proud of PaysonPSD has much to be proud of PaysonPSD has much to be proud of PaysonPSD has much to be proud of PaysonPSD has much to be proud of
Quote:
Sounds like the Titan Tank like the stocker has a fill tube and air vent tube that extend down into the tank. You should do to the Titan Tank that
many do to the stock tank, and that is to "Harpoon" it. Harpooning the tank is to cut off the fill and air vent tubes as close to the top of the tank
as possible. PVC pipe ratchet cutters work the best. No more "spitting" after that is done.
  #14 (permalink)
Old 11-06-2009, 12:56 AM
turboboost's Avatar
turboboost turboboost is offline
turboboost is starting off with a positive reputation.
get a shop to build you a custom slip tank that goes in the box of your truck. They don't take up that much space and are easy to remove when you need the bed, you can tie it into your tank, or buy a pump. these are way cheaper.
But if you want bed space you can use one of these. I'd like to see how one of these holds up on gravel.
__________________
2000 F-250 super cab auto 7.3L- ALI-ARC bumper,Firestone bags, bushwhacker flares,foil delete, LED's under tailgate, 400Watts of foglights, BF Goodrich Mud King XL's, 4" SS exhaust, 6637, DP tuner, BDS shocks, heavier springs, Line X, 5th wheel rails,Di-Procol gauges,seatcovers,.
along with two other F-250's both with 460 gas, five F-150's,a dakota, a Duramax, and a 6.5L
  #15 (permalink)
Old 11-06-2009, 08:26 AM
03_PSD's Avatar
03_PSD 03_PSD is offline
Black Smoke
2003 Ford F-250
03_PSD has a very good reputation on FTE. 03_PSD has a very good reputation on FTE. 03_PSD has a very good reputation on FTE.
that thing is huge, nice upgrade indeed!
__________________
Glenn
03 F250 Lariat 4x4~6 Gears~ProComp Lift~Front Ranch Hand w/4 Hella's and Rear Ranch Hand~Tony Wildman Tuned~08 Console~4 Gauge Pillar~Van Turbo/1.15/WW~4" Exh~6637 w/ Pete's Cover~ITP OBA~Clay's AIH Delete~SS HPX~CCV~CCK~Fuel PSI Gauge~Foil Delete~Alum. Rear Diff~203˚ w/Billet Housing~Recon Smoke Cab Lights~IH Emblems~Fumoto Plug~IH UP-PIPES
Tags
08 , 51 , bed , extended , ford , fuel , gas , install , range , remove , reviews , tank , tanks , titan , truck
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
