Go Back   Ford Truck Enthusiasts Forums > Diesel > Pre-Power Stroke Diesel (7.3L IDI & 6.9L)
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
Is F-150 Still King?
  #1 (permalink)
Old 11-04-2009, 06:15 PM
u.f.o u.f.o is offline
u.f.o is starting off with a positive reputation.
block drain
Anyone know were the block drain plug is located on a 7.3 I want to install a tank heater?
  #2 (permalink)
Old 11-04-2009, 09:56 PM
PLC7.3 PLC7.3 is offline
PLC7.3 is gaining momentum as a positive member of FTE.
There are two........one on each side of the block in the center just above pan line....just 1/4"npt
__________________
93 F250 SC 4x4 E4OD 355LS
  #3 (permalink)
Old 11-05-2009, 05:36 AM
Thanks for that but thats not going to work Ib need 1/2 in pipe thread hole in the low point in the block according to the instuctions?
  #4 (permalink)
Old 11-05-2009, 11:03 AM
Franklin2's Avatar
Franklin2 Franklin2 is offline
Franklin2 is a splendid one to behold Franklin2 is a splendid one to behold Franklin2 is a splendid one to behold Franklin2 is a splendid one to behold Franklin2 is a splendid one to behold Franklin2 is a splendid one to behold
They are in the low point of the block, it drains all the coolant out. Don't know what you are going to do about needing a 1/2" hole.
__________________
Dave F
1989 F250 XLT Diesel
  #5 (permalink)
Old 11-05-2009, 05:44 PM
Thats what the instructions is the best place to hook into the engine next is I have to make something to run off lower rad hose.
  #6 (permalink)
Old 11-05-2009, 07:30 PM
87crewdually's Avatar
87crewdually 87crewdually is offline
87crewdually is starting off with a positive reputation.
IIRC there is a decent size plug in the oil cooler end casting. The cooler is the piece your oil filter screws on. Maybe someone with one laying around can confirm.
Why dont you use heater hoses off the engine for your tank heater?
__________________
87 CCD, 6.9 Banks Sidewinder turbo & ARP studs, fresh pump & injectors, str8 Pipe out the side, worked C-6, 4.56R&P & Laycock/GearVendors Overdrive
  #7 (permalink)
Old 11-05-2009, 09:25 PM
Dave Sponaugle's Avatar
Dave Sponaugle Dave Sponaugle is online now
1986 Ford F-250
Dave Sponaugle is a name known to all Dave Sponaugle is a name known to all Dave Sponaugle is a name known to all Dave Sponaugle is a name known to all Dave Sponaugle is a name known to all Dave Sponaugle is a name known to all
There is actually a plug in the rear oil cooler header that International uses for a block heater.
Can be seen in this picture.
And if I remember right it is a 1/2" pipe thread.
__________________
86 F250 HD 6.9 IDI ATS turbo "not exactly" stock 4x4 T19 BW1345 3.55LS both ends D60 front, 10.25" Sterling rear, ram air, dual stacks.
"I dig dirt"
FTE Guidelines
FTE Moderator IDI diesel forum
WV Chapter Member
  #8 (permalink)
Old 11-05-2009, 09:42 PM
That's the plug I was talking about. Didn't have a pic though. I know 2000 excursion stroke has the heater here (coolers are similiar).
__________________
  #9 (permalink)
Old 11-05-2009, 10:37 PM
1986 Ford F-250
I should remember that plug when the 83 thru 85 guys are worried about the block cracking.
That would be an excellent place for them to install a block heater.
Need to find out what the International block heater number is that goes in there.
__________________
"I dig dirt"
FTE Guidelines
WV Chapter Member
  #10 (permalink)
Old 11-06-2009, 05:04 PM
That looks like that will work the other end of this heater splices into the heater hose. I had one years ago that just spliced into the heater line that worked very well. Thanks guys. Frank
Tags
2004 , 69 , block , diesel , drain , drains , engine , f150 , ford , heater , install , location , plug
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
