Go Back   Ford Truck Enthusiasts Forums > Small Chassis Trucks > Ranger & B-Series
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
Ranger & B-Series All Ford Ranger and Mazda B-Series modelsSPONSORED BY:
Is F-150 Still King?
  #1 (permalink)
Old 11-04-2009, 05:48 PM
carsrus carsrus is offline
carsrus is starting off with a positive reputation.
98 4.0 OD Light Flashing, Hard Shifting
Hello everyone,
I have a 98 4.0 4x4 ranger thats been having some weird tranny issues lately. The truck almost has 165k miles on it.
Sometimes the OD light begins to flash and the transmission jerks going into second gear, and when it downshifts from 3rd to second it jerks again. I read all the valve body threads and thought that could be the problem. The thing is when I shut the truck off and turn it back on the light stops flashing the the truck shifts perfectly.
This happened for the first time about 2 months ago and maybe twice more after that. Lately its been occurring every 2-3 days.
  #2 (permalink)
Old 11-04-2009, 10:27 PM
g_k50's Avatar
g_k50 g_k50 is offline
1990 Ford Bronco
My Garage
g_k50 is starting off with a positive reputation.
check the fluid level or change the filter or have a mechanic check it
  #3 (permalink)
Old 11-05-2009, 08:18 AM
Fluid levels good, filter was changed about 20k ago.
I already had my friend scan it with a genisys and there arent any tranny codes so a mechanic cant really help out...
  #4 (permalink)
Old 11-05-2009, 12:07 PM
g_k50's Avatar
1990 Ford Bronco
My Garage
Sounds like then that the problem might be somewhere else.
How's the engine tune?
Transfer case issues with the 4x4?
Driveline-U joints? Pinion differential?
  #5 (permalink)
Old 11-14-2009, 10:05 PM
powersmoked powersmoked is offline
powersmoked is starting off with a positive reputation.
how about the vss in the differential. any other symptoms ie. abs light, screwed up speedometer
  #6 (permalink)
Old 11-14-2009, 11:45 PM
kawa's Avatar
kawa kawa is offline
kawa has a good reputation on FTE. kawa has a good reputation on FTE.
Talking
My '98 4X4 4.0 is doing the same thing except the CEL light comes on and after a while the O/D light starts to flash and the tranny goes into "Limp" mode. Turn off the engine and restart and the tranny operates normal for a few miles then starts all over again.
It shows a code of P1740 but I don't know if the code interpretation is the same for a diesel as it is for a gasser.
P1740 equates to: "TCC Inductive Signature Malfunction." Anyone know what that means?
Rog
__________________
1997 Red 4X2 CC S/B-3" DP- No Kitty-6637
Cooling Sys. Filter-7 Gauges-6 Pos.PHP Chip
140V IDM-The "Cure"-CCV Mod w/Filter
1.0 Turbo-No EBP-Detroit Locker/Finned Cover
U. S. Gear Exhaust Brake-Ext. plug for Heater &
Cadillac Battery Water-On board Batt. Charger
  #7 (permalink)
Old 11-15-2009, 02:46 PM
Any code over 1000 should be vehicle specific. If you have a abs/vss in your diff it costs $20 15 minutes to replace you might as well do that first. I have a manual so I did not have the tranny issues but I know that they cause problems with the autos. I had speedometer and funny brake peddle issues. And an off an on abs light
  #8 (permalink)
Old 11-15-2009, 02:57 PM
KhanTyranitar's Avatar
KhanTyranitar KhanTyranitar is offline
KhanTyranitar is starting off with a positive reputation.
That code means the computer has detected a problem with the OD solenoid. It does not tell you what it doesn't like, but i suspect the resistance is out of range, or the solenoid has shorted out. It could also be a bad connection or damaged wire. try not to drive it too much till this gets figured out, otherwise the problem could become more complicated and expensive.
  #9 (permalink)
Old 11-18-2009, 06:34 PM
Yeah so its happened a few times since my first post. The speedo and tach are completly fine when it happens.
It jerks a bit when it goes from first to second. I think im going to change the 1 gear solenoid if i can figure out which one it is and do the diy flush.
I still have no idea why restarting the car gets rid of the issue.
Tags
2003 , 98 , blinking , blinks , f150 , flashing , ford , hard , light , od , overdrive , proble , ranger , shifts , trany
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
