I am still confused about the names on those hoses from different sources. According to the instructions on Prestone's Flush and Fill kit
"2) Two heater hoses extend from the fire wall to the engine, in both front and rear wheel drive vehicles. Hose #1 runs from fire wall to water pump. Hose #2 runs from fire wall to top of engine. This is the heater inlet hose. Ask a qualified mechanic if uncertain."
The Haynes manual states that the return hose goes into the thermostat housing/engine and supply hose goes into the water pump.
If I am reading this right, supply [haynes] = outlet [prestone] and return [haynes] = inlet [prestone]. Is this correct? I would expect inlet = supply and outlet = return, but I may be wrong. It may be a case of semantics ... (LOL)
