Go Back   Ford Truck Enthusiasts Forums > Diesel > 1994.5 - 1997 7.3L Power Stroke Diesel
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
1994.5 - 1997 7.3L Power Stroke Diesel SPONSORED BY:
Is F-150 Still King?
  #1 (permalink)
Old 11-04-2009, 04:31 PM
FLYBOY07's Avatar
FLYBOY07 FLYBOY07 is offline
FLYBOY07 is starting off with a positive reputation.
Exhaust manifold/up pipe replacement
I have a pretty bad exhaust leak coming from where the exhaust manifold and the up pipe to the turbo Connect. Black soot everywhere, truck sounds and runs HORRIBLE. How Hard and complicated is this? and where can I get the parts at a decent price?
__________________
1995 Ford F-350 CC- DRW -PSD- Centarus Conversion Package-Under Construction/Retired
2009 CHEVY Silverado 1500- Ext Cab Z71 4x4-Daily Driver
Previously owned Fords- 1988 Ford F-150 Reg Cab. 300-6 125,000 miles, 1995 Ford Escort - 2dr Hatch 1.9l 4 cyl 315,000 miles
  #2 (permalink)
Old 11-04-2009, 11:09 PM
nateairman's Avatar
nateairman nateairman is offline
nateairman is starting off with a positive reputation.
I had a similar problem and found all my piping to be miss aligned and loose. After straightening this out and tightening the exhaust manifold bolts it got a lot better. As far as replacing the pipe not sure.
  #3 (permalink)
Old 11-05-2009, 01:22 AM
FLYBOY07's Avatar
ha I'll try this first it sounds horrible man... talk about having no balls. all it is is where they join up drives me nuts I don't even drive it that much anymore till I get this fixed
__________________
  #4 (permalink)
Old 11-05-2009, 01:30 AM
rideracelivemx7 rideracelivemx7 is offline
1995 Ford F-250
rideracelivemx7 is starting off with a positive reputation.
lay off it when ever possible! man your egts must be threw the roof!
__________________
red 7.3 powerstroke diesel-6637-10k-6 POS chip big name tunes-HPX line-3" Downpipe--> 6" Aussie stacks! 3:55s auto-122k miles-Rotella Synthetic, ebpv butterfly removed
  #5 (permalink)
Old 11-05-2009, 08:20 AM
Neal 97 250's Avatar
Neal 97 250 Neal 97 250 is offline
Neal 97 250 has a great reputation on FTE. Neal 97 250 has a great reputation on FTE. Neal 97 250 has a great reputation on FTE. Neal 97 250 has a great reputation on FTE. Neal 97 250 has a great reputation on FTE.
You might as well get rid of that thing. You will never be able to fix that problem!
Just bring it over to me you don't need that headache anymore. Seriously!
If you decide to not let me have it then I will try to help...I guessssss....
The uppipes may actually be loose like said earlier. Chances are the uppipe donut gaskets are bad too. They are what seal the top part of the pipe to the turbo collector. If it is leaking down at the exhaust manifold too then you really need to take out that pipe and inspect it. It seals to the manifold just metal to metal and if it is rubbed thru or has a gouge in it it will continue to leak even after you tighten it.
I will trade you a 2000 Excursion 7.3 psd for that ratty old worn out truck.LOL
__________________
97 F250 7.3PSD X-Cab, SWB, 4X4 5spd, 4.10gears, 3.5” DP, 4” Exh.,BDP 140v IDM,CCV,HPX,6637mods
Rosewood 180cc Stage II's, DP Tuner Live Tuned, Modded H2E, 6.oh Cooler, BDP elec. reg. return fuel, Valair full feramic clutch
Neal's Pics and H2E install
Tennessee Chapter Leader Join Chapter here
  #6 (permalink)
Old 11-05-2009, 10:46 AM
nateairman's Avatar
Maybe there is a rats nest under thef hood and they chewed through the pipes....
  #7 (permalink)
Old 11-05-2009, 12:04 PM
BadDogPSD's Avatar
BadDogPSD BadDogPSD is offline
BadDogPSD is starting off with a positive reputation.
Quote:
Check with Clay at RiffRaff. Not sure if he has them for the OBS, but he's got a ceramic coated exhaust manifold exchange deal for the SD's. I think
he can get you bellowed up pipes too that would eliminate the stupid donut gasket.
__________________
Craig
1997 F250 4x4 Crew Cab PSD, Dana 60 conversion with SD 'V' Code front springs & SKY RSK. SD 'B' Code rear springs adding other goodies as time and money permits
  #8 (permalink)
Old 11-05-2009, 01:33 PM
Riffraff Performance's Avatar
Riffraff Performance Riffraff Performance is online now
Platinum Sponsor
Riffraff Performance has a great reputation on FTE. Riffraff Performance has a great reputation on FTE. Riffraff Performance has a great reputation on FTE. Riffraff Performance has a great reputation on FTE. Riffraff Performance has a great reputation on FTE.
The manifolds should all be the same for the OBS and the Super Duty's. You can move up to the bellowed up-pipes if you convert over to the later turbo set-up as well.
__________________
Clay
Riffraff Diesel: Contact Us
Diesel O-Rings by Guzzle
Riffraff Facebook Page
Parts Guy Ed - The one and only choice for OEM Parts
  #9 (permalink)
Old 11-21-2009, 03:25 PM
FLYBOY07's Avatar
LOL been a while since I been on here last.. I'll try using your advice allthough for some reason seems like its bent some kind of way I wish I could take some pictures. Its been doing this a while but I was patch fixing it because I couldn't afford to have my truck down for any length of time but It always failed no matter what I tried .. so since I just bought my new truck this week I'll finally have the time to tear it apart and fix it right.. I'll keep you posted on how it goes.. I'm pretty sure its gonna be tough the trucks almost 15 years old and its from the midwest. Thanks again guys for your help
Neal your never going to give up on getting that damn truck are you? LOL ever since I bought the Silverado a few days ago I get calls constantly asking if I'm selling it Truck just has way too much history and sentimental value for me to ever think about selling, its just gotten to the point to where its getting old and tired and Its time for me to tear it down and build it back up to the Bad ass road queen it used to be.. But if I ever do decide to get rid of it You'll be the first to know
__________________
Tags
2006 , 73 , 73l , exhaust , f350 , ford , forums , leak , manifold , pipe , pipes , powerstroke , replacing , truck , turbo
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
This forum is owned and operated by Internet Brands, Inc., a Delaware corporation. It is not authorized or endorsed by the Ford Motor Company and is not affiliated with the Ford Motor Company or its related companies in any way. Ford® is a registered trademark of the Ford Motor Company.
