Go Back   Ford Truck Enthusiasts Forums > Performance, Engines and Troubleshooting > Ford Inline Six, 200, 250, 4.9L / 300
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
Is F-150 Still King?
  #1 (permalink)
Old 11-04-2009, 03:46 PM
1977ford250 1977ford250 is offline
1977ford250 is starting off with a positive reputation.
1983 300 6 compression test
Hi, i have a 1983 ford inline 6. I did a compression test on it today and the first cylinder was 80 psi where every other one was 158 psi. So i redid the first on with a little squirt of oil down the cylinder and the compression was still 80 psi which leads me to believe the rings are fine. I next did a cylider leakage test and i pressurized the first cylinder and found no bubbles from the radiator but i had a lot of air coming from the oil fill on top of the valve cover. This one has me puzzled maybe a problem with the piston? please let me know what you think. thanks alot, mike
  #2 (permalink)
Old 11-04-2009, 05:04 PM
AbandonedBronco's Avatar
AbandonedBronco AbandonedBronco is offline
1981 Ford Bronco
AbandonedBronco is starting off with a positive reputation.
Generally, if you have low compression in a cylinder and then fill it with oil and still have low compression, it means that the valves are bad.
Engine Compression Testing
__________________
4bbl Holley 390 w/ Offenhauser DP intake. 4 speed Manual w/OD. K&N air filter, EFI manifolds, 2.5" exhaust.
3.00 rear end and 2000 RPMs @ 80mph!
Boise, Idaho
  #3 (permalink)
Old 11-04-2009, 06:52 PM
91Bronc300 91Bronc300 is offline
91Bronc300 is starting off with a positive reputation.
Both your tests indicate bad valves in that cylinder. A leakdown test will give you audible evidence of where your pressure loss is. Hissing in the crankcase is bad rings, hissing in the head is bad valves. And bubbles in the water is a blown head gasket or possibly a cracked head. Seems though like you have a pretty sound engine that just needs a little valve work. Could easily be fixed for a small bit of money by a machine shop.
__________________
1991 Bronco; 4.9L; Mazda 5 speed; BW1356, 8.8 open rear; 44TTB open front, 3.55; daily driver
1985 F-250 4x4; 300; C6; BW1345, Ford sterling semi float posi rear; 44HD TTB open front; 3.55; runs
1979 F-250 4x4; 400, NP435; NP205; Dana 60 full float open rear; Dana 44HD open front, project truck
  #4 (permalink)
Old 11-04-2009, 08:26 PM
JimsRebel's Avatar
JimsRebel JimsRebel is offline
JimsRebel is starting off with a positive reputation.
Is this a daily driver or has it been parked for a long time?
I would drive it hard and then retest #1.
__________________
1986 F150 XLT Lariat 4x4 300 C6, 9 inch 3:50, sway bars, DS2 w/ GM 4 pin and no computer; 90,000 miles, 2nd owner
  #5 (permalink)
Old 11-04-2009, 08:36 PM
Thanks for the advice. The truck sat for 8 years but in this past year ive put 14,000 miles on her.
  #6 (permalink)
Old 11-06-2009, 11:14 PM
300 Buster's Avatar
300 Buster 300 Buster is offline
300 Buster is starting off with a positive reputation.
Try that leak down test with the air cleaner off and throttle plates open and listen at the carb and the exhaust.I guess you could maybe have a bad valve guide or more letting air into the valve cover,but you may have something up with the piston,crack,broken ring,but I would check everything else first.Maybe when you remove the head for the valve work,you may see something,but do all the checking first,once the head's off,the checking is over.
__________________
'96 F150 4.9IL 5 Speed Stick
Tags
1994 , 250 , 300 , 3006 , bad , compression , cylinder , engine , f150 , ford , inline , specs , test
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
