Transmission or engine sluggish when first cold
on
Could be the engine also. It is a 01 excursion 7.3L 4x4 auto. This has happened a couple of times anyways. Seems like if it is below freezing for the night, the next morning when you take off there is hardly any response from the engine/transmission. Once it gets about 200 feet then is wakes up. Any ideas? Also seems to shift into od pretty firmly a lot of the time. We just bought it around 4 weeks ago with around 114k miles. Thanks for any help.
Perfectly normal, especially if it's that cold.
I got mine new and was initially worried about it, but then it donned on me that it wasn't a gas engine and probably needed time to warm up.
Plug it in at night and use 2 bottles of Prolong oil additive in your motor oil (Autozone) and it'll make a difference with the cold starts and cold weather performance. Worked well for mine...
Plug it in, as stated above, do a full prime of your glow plugs, and start. Give it a minute to warm up, don't shift to drive directly and go. The viscosity of the oil in the trans and engine gets pretty thick when it's that cold. If you aren't already, try rotella t 5w-40 full synthetic next time. Made a difference on cold starts for me. But let it go for a bit before you go, once the oil gets moving, then you're good to go.
on
My 96 f250 7.3 doesn't do that. It wasn't that cold, maybe high 20's to low 30's. It like something isn't communicating between the skinny pedal and engine. I just changed the oil with motorcraft 5w-40. As it gets colder we will be letting it warm up some in the mornings. I haven't even looked to see if there is a heater plug but if it doesn't what is needed to add one?
BuckHammer
16
08-02-2018 04:40 PM
cchighman
Escape & Escape Hybrid
09-11-2014 09:15 PM
