Transmission or engine sluggish when first cold - Ford Truck Enthusiasts Forums
1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
Old 11-04-2009, 12:32 PM
wildstang's Avatar
wildstang wildstang is offline
VT Chapter Ldr
wildstang has a superb reputationwildstang has a superb reputationwildstang has a superb reputationwildstang has a superb reputationwildstang has a superb reputationwildstang has a superb reputationwildstang has a superb reputationwildstang has a superb reputationwildstang has a superb reputationwildstang has a superb reputationwildstang has a superb reputation
Could be the engine also. It is a 01 excursion 7.3L 4x4 auto. This has happened a couple of times anyways. Seems like if it is below freezing for the night, the next morning when you take off there is hardly any response from the engine/transmission. Once it gets about 200 feet then is wakes up. Any ideas? Also seems to shift into od pretty firmly a lot of the time. We just bought it around 4 weeks ago with around 114k miles. Thanks for any help.
Old 11-04-2009, 12:47 PM
Toreador_Diesel's Avatar
Toreador_Diesel Toreador_Diesel is online now
Toreador_Diesel has a superb reputationToreador_Diesel has a superb reputationToreador_Diesel has a superb reputationToreador_Diesel has a superb reputationToreador_Diesel has a superb reputationToreador_Diesel has a superb reputationToreador_Diesel has a superb reputationToreador_Diesel has a superb reputationToreador_Diesel has a superb reputationToreador_Diesel has a superb reputationToreador_Diesel has a superb reputation
Perfectly normal, especially if it's that cold.
I got mine new and was initially worried about it, but then it donned on me that it wasn't a gas engine and probably needed time to warm up.
Plug it in at night and use 2 bottles of Prolong oil additive in your motor oil (Autozone) and it'll make a difference with the cold starts and cold weather performance. Worked well for mine...
Old 11-04-2009, 12:56 PM
JaySVX's Avatar
JaySVX JaySVX is offline
JaySVX is a name known to allJaySVX is a name known to allJaySVX is a name known to allJaySVX is a name known to allJaySVX is a name known to allJaySVX is a name known to all
Plug it in, as stated above, do a full prime of your glow plugs, and start. Give it a minute to warm up, don't shift to drive directly and go. The viscosity of the oil in the trans and engine gets pretty thick when it's that cold. If you aren't already, try rotella t 5w-40 full synthetic next time. Made a difference on cold starts for me. But let it go for a bit before you go, once the oil gets moving, then you're good to go.
Old 11-04-2009, 04:41 PM
Robs06SuperDuty's Avatar
Robs06SuperDuty Robs06SuperDuty is offline
Robs06SuperDuty is gaining momentum as a positive member of FTE.Robs06SuperDuty is gaining momentum as a positive member of FTE.
as said about many times let it warm up and let the oil circulate before driving. this should help.
Old 11-04-2009, 05:10 PM
FarmingFord's Avatar
FarmingFord FarmingFord is offline
FarmingFord is starting off with a positive reputation.
The ebpv (exhaust back pressure valve) probably has something to do with it too.
Old 11-04-2009, 05:28 PM
galaxie641 galaxie641 is offline
galaxie641 has a very good reputation on FTE.galaxie641 has a very good reputation on FTE.galaxie641 has a very good reputation on FTE.galaxie641 has a very good reputation on FTE.
I know the 6.0L's wouldn't allow you to "get up and go" right away, maybe the 7.3's had the same tuning.
Old 11-04-2009, 09:17 PM
wildstang's Avatar
VT Chapter Ldr
My 96 f250 7.3 doesn't do that. It wasn't that cold, maybe high 20's to low 30's. It like something isn't communicating between the skinny pedal and engine. I just changed the oil with motorcraft 5w-40. As it gets colder we will be letting it warm up some in the mornings. I haven't even looked to see if there is a heater plug but if it doesn't what is needed to add one?
Old 01-18-2010, 10:20 PM
hopalukjj hopalukjj is offline
hopalukjj is starting off with a positive reputation.
Its your ebpv It stays closed until your oil warms up then it actuates and will run fine I usually use 5w40 in the winter up here alberta it also works better if you plug in your block heater and let it warm up for a bit or you can take the ebpv out and no more problem
Old 01-18-2010, 10:32 PM
Boss08v10's Avatar
Boss08v10 Boss08v10 is offline
Boss08v10 is a splendid one to beholdBoss08v10 is a splendid one to beholdBoss08v10 is a splendid one to beholdBoss08v10 is a splendid one to beholdBoss08v10 is a splendid one to beholdBoss08v10 is a splendid one to beholdBoss08v10 is a splendid one to behold
Pretty sure if my memory is right that the computer will limit power until the a certin temp to keep the motor from hurting the transmission. I put 140,000 on my 00 ex psd here in MN so it was used in the cold half its life. I always used Mobil 1 trans fluid and Delvac 1300 15w 40.
Old 01-19-2010, 11:09 AM
wildstang's Avatar
VT Chapter Ldr
I usually let it idle some and on colder mornings, maybe 5F or less plug it in. I just wanted to make sure it wasn't a warning for major problem.
96 F250. Tranny problems. Speed Sensor? BuckHammer 1987 - 1996 F150 & Larger F-Series Trucks 15 03-26-2016 04:47 PM
Transmigration question. GM4WALLS 1973 - 1979 F-100 & Larger F-Series Trucks 13 06-21-2015 12:03 PM
73 F600. Spin the wheel what engine do I have? chris17453 Large Truck 2 04-17-2015 10:24 PM
Diagnosis procedure for Escape XLT 2008 CD4E trans when P0732/P0734 codes surface cchighman Escape & Escape Hybrid 4 09-11-2014 09:15 PM
E4OD Overheating JCs96 1987 - 1996 F150 & Larger F-Series Trucks 26 09-06-2013 11:52 AM
Tags
2004, 2006, 60, cold, cure, diesel, f250, ford, oil, powerstroke, runs, sluggish, started, transmission, viscosity
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
