Go Back   Ford Truck Enthusiasts Forums > Older, Classic and Antique Trucks > 1973 - 1979 F-100 And Larger F-Series Trucks
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
1973 - 1979 F-100 And Larger F-Series Trucks Discuss the Dentsides Ford Truck SPONSORED BY:
Is F-150 Still King?
  #1 (permalink)
Old 11-04-2009, 12:25 PM
76F100guy's Avatar
76F100guy 76F100guy is offline
76F100guy is starting off with a positive reputation.
So, I'm driving along and...
the engine cuts out and the tach goes to 0, as though I'd turned the key off. Two seconds later, it comes back to life and runs fine the rest of the trip.
Any suggestions? I'm guessing the box under the hood, but don't want to guess, and really don't want to get stranded. '76 300 with 3 speed, Duraspark I.
  #2 (permalink)
Old 11-04-2009, 01:48 PM
427 fordman 427 fordman is offline
427 fordman is gaining momentum as a positive member of FTE.
That would be my guess also. Unless you find something obvious like a dead short or something
__________________
Darin I BLEED BLUE
1976 F250 hboy w/71box 390 "Ol'brown"
1997 F250 HD 7.3 10k 3-4" downpipe w/straightpipe 6637 intake ebpv gone
1966 Ford Fairlane drag car 514cu.
  #3 (permalink)
Old 11-04-2009, 02:22 PM
trap4x4 trap4x4 is offline
trap4x4 is starting off with a positive reputation.
Thats probably it , but trace your tach to coil wire and make sure its not bared and shorting out along the way. Happened to me once and wasnt an easy find either!!!!
  #4 (permalink)
Old 11-04-2009, 05:18 PM
Drac Drac is offline
Drac is starting off with a positive reputation.
Also could be the trigger pick up coil located under the rotor in the distributor.
__________________
'65 F-250 4x4 w/ '76 460 & 514 in a 1900lb Drag Rail
Under construction: "Black & Bad" '79 F-150 4x4 -351w, 435np, 205np, TFS Twisted Wedge heads, Speed demon, Comp 4x4 extreme cam, edelbrock RPM AirGap, NOS Powershot, detriot locker, w/a '73 grille
  #5 (permalink)
Old 11-04-2009, 07:38 PM
90taz 90taz is offline
90taz is starting off with a positive reputation.
if it has the electronic module in it that is definately your problem. i had a 77 about 30 years ago and they were known for heating up, this would cause them to malfunction. back then we would swap to points to eleminate the problem. after i rebuilt the motor i went with a mallory unilite.
  #6 (permalink)
Old 11-04-2009, 07:59 PM
Tees77f150's Avatar
Tees77f150 Tees77f150 is offline
Tees77f150 is starting off with a positive reputation.
I just priced an after market module, it was $26 at Napa. They have another one for $64 if you think it is any better. I just picked up an extra to have just in case. I am really not into being aggravated if I can help it.
Best part was the guy at the parts store had an old dent he used for plowing, didn't have use fore the module since the dent his history, so free was real nice!!
__________________
Harold
Molly Hatchet: No guts, No Glory
http://i540.photobucket.com/albums/g...e/DSCF0073.jpg
  #7 (permalink)
Old 11-04-2009, 08:16 PM
fmc400's Avatar
fmc400 fmc400 is offline
fmc400 has a great reputation on FTE. fmc400 has a great reputation on FTE. fmc400 has a great reputation on FTE. fmc400 has a great reputation on FTE.
If it came back on right away, I don't think it's the module. When they experience a heat-related failure, they often take 20-30 minutes to start back up. My guess would be loose wiring that got budged due to road vibration. This is not to say it wouldn't hurt to carry a spare module.
  #8 (permalink)
Old 11-04-2009, 08:45 PM
mine would cut out going down the interstate and the then come rite back on
  #9 (permalink)
Old 11-04-2009, 11:53 PM
76F100guy's Avatar
Wow, great responses.
I looked at the tach wire shortly after it happened. I took my time when routing it, and there were only a couple of spots where it might possibly chafe, so I put heatshrink around the wire at those spots, during the installation.
Drac - is there any way to troubleshoot the trigger pickup coil? I was in the distributor last weekend, doing the recurve. I was really careful with everything I touched, but that doesn't mean I didn't inadvertently damage something.
I picked up a new ignition control module today, which I'll install for peace of mind, with the old one as a backup. A buddy of mine, who used to work on these things back in the day, said to always carry a spare; they'll expire with no warning.
  #10 (permalink)
Old 11-05-2009, 01:31 AM
I had a problem where I was going down the road 50-60mph, and it would just shut off like you turned the key off, then in 5-10 secoonds it would fire right back up. Well, when I kept my foot on the gas, it would dump raw fuel down the exhaust. When it fires back up it would make one h-ll of a back fire. so much that it split my 7" round muffler wide open. I went though three mufflers before I got it figured out. $$. I'm a slow learner.
So when it dies let off the gas pedal quick.
It started out doing this once every couple weeks, but progresively got to a daily deal. At least then I could trouble shoot it more.
I changed the module box three times trying different units. used and new
Changed the Coil twice
Checked all the wiring several times
Put in a new Pick Up Trigger - Have not had the issue in 2 years now.
Originally I was told you have to pull the distributor, and Gut it from the bottom to replace the coil. NOT TRUE. remove the rotor and then the 6 or 8 finger trigger star. ( Lack of better word). I used two small prybars on the bottom of the star against the distributor housing. very gently. The star removed easier than I thought it would. The Pick up coil is simply screwed to the advance plate with 1 or 2 screws and I think there is an alignment notch. There really wasn't much to it. Of course the wires go through the housing, so check for nicks and cracks there.
I don't think there was a gapping type spec between the coil and the star ( alignment notch?). I did check my timing when done, just because.
There was nothing that told me it was bad, just the only thing I didn't change. ended up being pretty cheap and easy. so I was a little pizzed at myself for not diving into it earlier. at first i was a bit scared of it. Ended up being easy. Have to admit i did play with an old distributor first.
Good Luck
__________________
  #11 (permalink)
Old 11-05-2009, 12:13 PM
76F100guy's Avatar
Quote:
I'm familiar with that tune
I think I'll replace the pickup coil as well. I'm starting to drive this thing a lot, so it's cheap insurance. I was also told to check ignition switch wires, which I haven't done yet.
The official term for the trigger star is reluctor. I learned a lot about removing it when I recurved the distributor three times last weekend. I also learned that on the Duraspark I, it's held in place by a tiny roll pin that you'd never know was there, until it's lost.
  #12 (permalink)
Old 11-05-2009, 01:42 PM
BrutalBronco's Avatar
BrutalBronco BrutalBronco is offline
BrutalBronco is starting off with a positive reputation.
stumble start stumble start
One drizzling chilly September day, I had a very very similar situation happen to me. The truck started up, warmed up, and went into gear just fine. As I let off the gas to coast to the first stop sign, it happened just as you described . Having the long term intimate knowledge of my truck, I instantly thought it was coil before my boot hit the bumper.
I had just installed a SuperStock coil and remembered that I had one short length connection that I wasn't confident about at the time. I changed the terminal ends, from female spade for the factory coil, to a loop the was snug on the coil's post. Anyway, I found that one of my crimps had let loose, and wouldn't you know it would be on that short piece. I knew that particular wire was too short to allow enough slack for normal harness movement, especially on my rough riding (empty) F250 flatbed. So, I fought cold electrical tape for a rainy roadside repair that lasted a year and a half until I swapped intakes.
Glad to hear your gonna be driving it a lot more.
  #13 (permalink)
Old 11-05-2009, 06:00 PM
79F150400M 79F150400M is offline
79F150400M is starting off with a positive reputation.
Oh yeah.....been through all that too. Just last week I was experiencing the "shut itself off" syndrome. I'd just push in the clutch, turn the key and it would start right up again. So when I got home (I was only a mile er so away) I pulled out the spare Iggy module I've had for many years and swapped them out. Haven't had a problem since. So now I'm going to go get me another spare module. Im glad I kept one in reserve and I will continue to do so. Not bad considering I haven't dealt with this issue for somewhere close to 20yrs.
__________________
Edelbrock Intake, Carter 625 carb, Comp Cams 268 bumpstick, Crane BBC roller tip rockers, Dynomax headers, Summit Turbo mufflers, 2 1/2in Rancho lift, 33x12.50 BFG All Terrain TA KO's, TFI coil, Taylor wires, Hayden fan clutch, and no "M" in 400.
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
