Go Back   Ford Truck Enthusiasts Forums > Small Chassis Trucks > Escape and Escape Hybrid
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
Is F-150 Still King?
  #1 (permalink)
Old 11-04-2009, 11:34 AM
triskadek's Avatar
triskadek triskadek is offline
triskadek is starting off with a positive reputation.
voltage regulator?
Battery light has taken to coming on when engine is cold.
Volts at battery 12.5 engine off, cold outside
Start engine, get battery light
Volts at battery 14.78, ~ 4 amps
About a 1.5 minutes of idling and the battery light goes off:
Volts at battery 14.5, ~3.5 amps
Seems to stay at about 14.5 v, 3.5 A once it is warmed up, but I've only just started metering.
No idea how old the battery is, or if it is the original alternator, PO didn't have any of that.
It's not throwing any codes.
__________________
1997 F250 HD XLT, 4x4, auto, 4.10 limited slip 265/75 KM2s approaching 300k mi
2002 Escape XLT, auto, tow package, Cooper disco STTs, ~80k mi
  #2 (permalink)
Old 11-04-2009, 06:42 PM
wptski wptski is offline
wptski is starting off with a positive reputation.
If you do a search on battery/alternator operation you'll find slight differences of opinion but I think that 14.5V is a good reading.
__________________
Bill
09 Ford Escape Limited, 3.0L, 4WD, AdvanceTrac
  #3 (permalink)
Old 11-04-2009, 09:45 PM
tcesni tcesni is offline
tcesni is new and has a neutral reputation at this point.
I have a 2002 and my battery light has been on for 6 months and my alternator output is OK just like yours. I've stopped worrying about it. Here is the weird part, when I take a sharp left hand turn up a steep hill about a 1/4 mile from my house and give it a lot of throttle the light will almost always go out - for a couple of minutes. An electical gremlin if there ever was one.
  #4 (permalink)
Old 11-04-2009, 11:37 PM
I put a fairly good Midtronics battery tester on a friend's '04 Ford Taurus that shows a Check Battery message or something. It tests the battery and with prompts, guides one through alternator test at idle, raised idle and with a load. The Taurus passed all tests. I found a TSB for the issue and the fix is a PCM update which nobody except a dealer can do of course!
__________________
Bill
  #5 (permalink)
Old 11-05-2009, 01:46 AM
cv18sro cv18sro is offline
cv18sro is starting off with a positive reputation.
Had this same issue on a Ford Contour that I once owned. If you battery is ok then take some elec parts cleaner or brake parts cleaner and flush the alternator with it. When I did this it solved the problem. Seemed to get full of dust and brush shavings and allowed better contact. I also cleaned all battery and alternator connections where they appeared ok or not.
  #6 (permalink)
Old 11-05-2009, 11:03 AM
triskadek's Avatar
They did stick the alternator pretty darn low. When I went looking for it, the first thing that came to mind was "wow that's gonna get full of crud and easily get wet in the creek crossings"
__________________
  #7 (permalink)
Old 11-06-2009, 07:43 AM
DoctorCAD DoctorCAD is offline
DoctorCAD is starting off with a positive reputation.
It is really easy to mistake the low coolant light for the battery light on these vehicles.
Tags
2002 , 2006 , alternator , battery , battery light , escape , f250 , ford , light , regulator , truck , voltage
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
