Go Back   Ford Truck Enthusiasts Forums > Diesel > 1994.5 - 1997 7.3L Power Stroke Diesel
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
1994.5 - 1997 7.3L Power Stroke Diesel SPONSORED BY:
Is F-150 Still King?
  #1 (permalink)
Old 11-04-2009, 10:37 AM
fordboy2 fordboy2 is offline
fordboy2 is starting off with a positive reputation.
bought 96 what to do
ok as some of you may have read I bought a 96 f350 that was a repo. the truck has 191000 miles on it. wondering what you all recommend doing. I figure I will change the oil,trans fluid, t-case fluid, and both diffs. Obviously chaeck all the front end parts also. needs 4wd shifter, tires, and batteries. can I fit 35's without lifting it? As for mods what do you recommend on these, I have not had a obs truck just 99 and newer 7.3's. I am thinking down pipe and exhaust, but which one and where should I get it. I assume the chip to have is the dp tuner the same as my superduty's were. what about air intake? I am also going to add some gauges on the pillar. I will post pics a s soon as I can but was looking for opinions from you all.
__________________
06 f350 lariat srw-factory 20's(winter), mb shakers w/35" toyo mt's(summer), chrome package,zoodad, pioneer D3 with rear monitor,riderite air bags, sky jacker leveling kit, air lift air bags in front, 8.2 Boss v-plow, 90 watt corner strobes, 4" magnaflow turbo back exhaust minus the kitty, K&N fipk, coming soon spartan tunes, analog gauges
96 f350 reg cab lb, 7.3 auto 191000miles just gettin started
  #2 (permalink)
Old 11-04-2009, 11:01 AM
Talyn's Avatar
Talyn Talyn is online now
1994 Ford F-250
Talyn has a very good reputation on FTE. Talyn has a very good reputation on FTE. Talyn has a very good reputation on FTE.
most of the mods are the same.
__________________
Talyn (AKA: William) - Resident Sheep Shearer
1994 - F250 - Direct Injection Turbo Diesel, 5 speed, 4x4, Standard Cab.
Rosewood Stage 1's, 6 pos PHP Tuner, 6637, Midwest Short Throw Shift Kit.
Head over to www.midnightmods.com to see some of my projects.
Midwest Shift Kit- http://www.midnightmods.com/2009/11/...ifter-kit.html
  #3 (permalink)
Old 11-04-2009, 11:32 AM
Talyn's Avatar
1994 Ford F-250
err. sorry.
SD's have electric fuel.
So there are a few others.
__________________
  #4 (permalink)
Old 11-04-2009, 12:21 PM
triskadek's Avatar
triskadek triskadek is offline
triskadek is starting off with a positive reputation.
I don't think you will fit the 35s on there stock.
Do the bumpers sag?
__________________
1997 F250 HD XLT, 4x4, auto, 4.10 limited slip 265/75 KM2s approaching 300k mi
2002 Escape XLT, auto, tow package, Cooper disco STTs, ~80k mi
  #5 (permalink)
Old 11-04-2009, 12:32 PM
I dont believe the bumpers sag, what about an intercooler is this a worthwhile mod?
__________________
  #6 (permalink)
Old 11-04-2009, 12:33 PM
how much lift for the 35's
__________________
  #7 (permalink)
Old 11-04-2009, 12:35 PM
triskadek's Avatar
A fresh IC thread just started http://www.ford-trucks.com/forums/89...tercooler.html
__________________
  #8 (permalink)
Old 11-04-2009, 01:26 PM
427 fordman 427 fordman is offline
427 fordman is gaining momentum as a positive member of FTE.
If you are going to tow a lot an intercooler is a very very good mod. I just got all my parts to install my 6.0 cooler on mine. Also a bigger tranny cooler is a good idea if you tow with it.
__________________
Darin I BLEED BLUE
1976 F250 hboy w/71box 390 "Ol'brown"
1997 F250 HD 7.3 10k 3-4" downpipe w/straightpipe 6637 intake ebpv gone
1966 Ford Fairlane drag car 514cu.
  #9 (permalink)
Old 11-04-2009, 04:32 PM
Copedawg's Avatar
Copedawg Copedawg is online now
Copedawg is starting off with a positive reputation.
I put 285's on mine and they rubbed the bumper some so I took off the bumper and shimmed it out some w/longer bolts and some washers
__________________
Ian pronounced E-N just like the letters sound. 97 F350 7.3L Auto 4WD Crew Cab 195K. MODS: HOOOOGA! horn, PO MAN's air intake, Service/Utility bed, 3" DP, Testing that Cat, FPR shim (whoknows PSI), 140v IDM, 2 10K pots. US ARMY OAS, OJE-IFOR, SFOR,2,5, OJG-KFOR, OIF, OEF.
To ALL that have served, THANK YOU!
  #10 (permalink)
Old 11-05-2009, 09:33 AM
sand1's Avatar
sand1 sand1 is offline
sand1 is starting off with a positive reputation.
i have a 4 inch spring with 35s but its better to do a shackle reversal kit 2.5-3 inches of lift and a smoother ride
  #11 (permalink)
Old 11-05-2009, 05:52 PM
fireman-175 fireman-175 is offline
fireman-175 is starting off with a positive reputation.
I don't believe you can put any chips in that 1996. You can buy a programmer that works pretty similar. My programmer has three settings... normal, more power and smoke, and lots of power and smoke. I use the middle one and get pretty good mileage and power.
You should really check the antifreeze and make sure the readings are appropriate. Hopefully, the previous owner was on top of that. Go by a CAT store and get the test kit and conditioner.
  #12 (permalink)
Old 11-05-2009, 06:06 PM
foxracing0934's Avatar
foxracing0934 foxracing0934 is offline
1997 Ford F-350
foxracing0934 is starting off with a positive reputation.
It won't be a problem running a chip on a 96, and you also have PHP and TW to choose from for custom chips (there are also a bunch more but those are the most popular). As for the tires it really depends on the truck, if the front springs have a good amount of sag then chances are that the tires are going to rubb. But with some good springs there are people on here running 315's with stock height, and i'm pretty sure that 315's are equivilant to 35" tires.
__________________
97 F-350 w/88,*** miles
DP Tuner, S.S. HPX Line, 4in MBRP, FPR shim, Dipricol Gauges (Tranny, EGT, Boost), 6637 Intake, Rosewood Stage II's, 6.0 I/C, 5" mitre cuts (6" soon though)
Soon to Come
New Tranny, H-11 studs, H2E, wheels and tires.
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
