Go Back   Ford Truck Enthusiasts Forums > Performance, Engines and Troubleshooting > Big Block V8 - 385 Series (6.1/370, 7.0/429, 7.5/460)
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
Is F-150 Still King?
  #1 (permalink)
Old 11-04-2009, 10:17 AM
AMSContr AMSContr is offline
AMSContr is starting off with a positive reputation.
Coolant coming out exhaust bolt hole
I was tightening down the right side of our '88 7.5/460 EFI and the 3rd cylinder from the front has a stud with a long nut on it. I tightened it and it stripped out, then I pulled the stud out and it started dripping coolant. What could this nightmare be? Cracked head, a common problem, or??
If it a cracked head I suppose pretty much a complete tear down from the air cleaner down to the block or can you remove the head without removing the intake etc.?
  #2 (permalink)
Old 11-04-2009, 02:34 PM
jim henderson jim henderson is offline
jim henderson has a very good reputation on FTE. jim henderson has a very good reputation on FTE. jim henderson has a very good reputation on FTE.
I never had to remove the exhaust on my 460 so I don't KNOW the answer...
But many engines do have bolts or studs that bottom out in a water passage. If this is the case, all you need to do is re thread the hole or put in a helicoil and put in the new stud, possibly with sealant.
You might be able to check if this is a thru hole into the water jacket by using a strong light to look into the hole or use something pokey, like a bamboo skewer or a pipe cleaner to see if the hole goes thru or if the threaded hole has a bottom. If it has a bottom to it and it leaks then you have a crack. But I bet it is just a stud that is supposed to be in the water jacket so there won't be a bottom to the threaded hole.
Hope the guys who do KNOW chip in to be sure.
Jim Henderson
  #3 (permalink)
Old 11-04-2009, 06:01 PM
Thanks for the reply!
  #4 (permalink)
Old 11-04-2009, 08:38 PM
mark a.'s Avatar
mark a. mark a. is online now
mark a. is gaining momentum as a positive member of FTE. mark a. is gaining momentum as a positive member of FTE.
Sounds like it had a bolt broke off of it at one time. Someone drilled it out and went a little too far and hit water, probably messed the threads up along the way too. That would be my guess. It could be fixed but it would be a lot of work & you would need a mill.
__________________
'79 F250 13" lift 42" Super Swampers
  #5 (permalink)
Old 11-05-2009, 12:45 AM
Well after some research and gambling, I cleaned the threads bought new bolts/studs and used sealant on the one leaking. Now I'm letting the sealant setup for 24 hours.
I went to the local NAPA to buy new studs/bolts, they didn't have them, Ford had to order them, after they quoted me the price of about 179 bucks for 8 bolts/studs I'm gambling with some grade 8 bolts from the local hardware store.
Oh well I'm hoping it will work, if not I hear scrap prices will be going back up soon.
  #6 (permalink)
Old 11-06-2009, 08:13 AM
Still leaking
I guess it's time to try a helicoil and drill. What's the best thread sealant to use?
  #7 (permalink)
Old 11-10-2009, 05:01 PM
jamies460 jamies460 is offline
jamies460 is starting off with a positive reputation.
Maybe a easy fix if you have a Tap & Die, just put a new thread on it, but make sure you use some silastic gasket on that bolt.....
Tags
bolts , coolant , drilled , exhaust , f250 , ford , head , jacket , truck , water
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
