Wow! Check out the junk in my coolant filter!
My auxiliary coolant filter was leaking on the inlet side so I figured it was getting full. So I changed it and dumped the filter out in a bucket. I was amazed at how much crap came out! Looked like about a tablespoon of sand. I think it was a good idea to put in the filter! I got the filter mount at CarQuest and I use the Napa 4070 coolant filter. It cost about $40 to install.
That is CAT ELC.
Looks like ELC to me! And with a 2002, he had semi-ELC in there to start with. Imagine how much silicate drop-out is in a green coolant motor! I need to get this done. I've been putting off the coolant change for a while now.....
EDIT: It's NOT "casting sand". It's drop-out from coolant with SCA in it. Gold has a little SCA, green is full of it. Here's what it looks like:
No pics here at work, but it is a piece of cake install. You want the filter to be in "bypass" mode. I teed off the heater core and ran 5/8 heater hose to the coolant filter. I mounted the coolant filter on the driver's side body of the truck, near the factory location of the fuel pump. The return hose from the filter goes to the degas bottle. I just teed off the factory return to the degas bottle.
on
I put in full ELC, last year about this time, when I flushed my cooling system and put on a new water pump. I already had the coolant filter installed, so I left everything in place and changed the filter. It is still flowing fine. I wonder sometimes if it is still catching anything since the coolant change to ELC. I will cut it open later and see if it's still really necessary to be there. I may be taking it off to free up some room.
I went over to the Cat dealer the other day -- it'll cost me about $90 in coolant and about $20 in distilled to do it. Plus I want change that pesky hose, and maybe re-do the 'stat housing just to make sure I don't have any issues later. Maybe even the lower hose housing O-ring too. If I put this stuff in, I don't want to have do it again later.
This is the third time I have changed the filter, and I have been using the CAT ELC the whole while (I flushed, installed the CAT ELC and coolant filter all at the same time). I didn't dump the other two filters out, so i don't know what was in them. But it is still catching a lot of junk!
on
Great pics, not only the dropout you have to worry about, it's the rust from the upper and lower stamped steel intake and outlet coolant housings too, this is what my upper looked like after my T-stat changeout , the lower looks grungy also, that will be changed out eventually. Dieselsites aluminum housing on the left, stock stamped steel on the right. CAT red ELC user here with the D-S coolant filter system installed. I'll be pulling my coolant filter soon to see what I caught, been about 6 months approx.
