Go Back   Ford Truck Enthusiasts Forums > Diesel > 1999 - 2003 7.3L Power Stroke Diesel
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
1999 - 2003 7.3L Power Stroke Diesel SPONSORED BY:
Is F-150 Still King?
  #16 (permalink)
Old 11-04-2009, 10:24 AM
big poppa's Avatar
big poppa big poppa is offline
Monitoring The Vitals
2003 Ford F-250
big poppa has much to be proud of big poppa has much to be proud of big poppa has much to be proud of big poppa has much to be proud of big poppa has much to be proud of big poppa has much to be proud of big poppa has much to be proud of big poppa has much to be proud of
Quote:
Originally Posted by rat49f6 View Post
As a Group did we ever decide if ELC is or isnt ok in early 99?
I think Huck ran a thread not to long ago, maybe a week about the early birds coolant changeouts, he was thinking of doing it too. http://www.ford-trucks.com/forums/89...ntifreeze.html
__________________
Mike's 03 F-250 7.3 CC SB XLT 4x4 Auto, GTP38R BB Turbo, S-B intake With Pete's Armor, MBRP Duals, DP Tuner F-5, 3 Isspros Gauges In Pillar, JW-VB, OBA, Clay's AIH Delete, Clay's FRx (CCK), CCV, Zoodad And GPR LED Mod and some other goodies. 132,000 on the ticker. PAA#26 Roadside Help Network Riffraff Diesel Performance http://www.dieselorings.com/ http://www.guzzle7pt3.com/index.php
  #17 (permalink)
Old 11-04-2009, 10:39 AM
Izzy351's Avatar
Izzy351 Izzy351 is offline
Getting Faster...
Izzy351 has much to be proud of Izzy351 has much to be proud of Izzy351 has much to be proud of Izzy351 has much to be proud of Izzy351 has much to be proud of Izzy351 has much to be proud of Izzy351 has much to be proud of Izzy351 has much to be proud of
There are quire a few guys running it now, but it really is a "time will tell" situation. It's ultimately up to you, but I think I'd swap out the green junk at least for gold if I had it. Being free of the constant maintenance on that stuff would be worth it to me.
__________________
Quote:
Originally Posted by Smokin'
I am not that cool. I am just a normal guy, stuck in a girl's body, who just happens to be attracted to men. LOL
  #18 (permalink)
Old 11-04-2009, 10:43 AM
wrtaz's Avatar
wrtaz wrtaz is offline
wrtaz is starting off with a positive reputation.
Quote:
Originally Posted by Izzy351 View Post
I went over to the Cat dealer the other day -- it'll cost me about $90 in coolant and about $20 in distilled to do it. Plus I want change that pesky hose, and maybe re-do the 'stat housing just to make sure I don't have any issues later. Maybe even the lower hose housing O-ring too. If I put this stuff in, I don't want to have do it again later.
Don't forget the belt while you're in there! Fyi, there's two different upper hoses type, one goes through the belt the other around it. I stuck with what I had and went through the belt. Only issue there is if you need to change the belt the hose needs to come off. If you go with the hose that goes around the belt, if the belt ever broke it would hit and maybe cut the hose. Just figured I'd add that info if you don't already know.
  #19 (permalink)
Old 11-04-2009, 10:47 AM
Izzy351's Avatar
Getting Faster...
That's what I meant by changing the hose. The one that goes around the belt will be going on.
__________________
  #20 (permalink)
Old 11-04-2009, 10:55 AM
Flying Finn's Avatar
Flying Finn Flying Finn is offline
Flying Finn is starting off with a positive reputation.
I need to change my coolant also. Confused of what coolant to use though (I tried searching but between green & gold got lost)...
So, what coolant I need to use in 2003 7.3L diesel?
Thanks!
__________________
Flying Finn
2003 Ford F-350 7.3 4x4 SD Lariat Crew Cab
1995 Porsche 993 Carrera 2
2004 Jaguar XJ8
1973 Fiat 600 Abarth Convertible
1980 KTM 250
  #21 (permalink)
Old 11-04-2009, 10:57 AM
Izzy351's Avatar
Getting Faster...
At least gold (should have that in it already), and you can switch full ELC if you want.
__________________
  #22 (permalink)
Old 11-04-2009, 11:11 AM
Smokin''s Avatar
Smokin' Smokin' is online now
Smith & Wesson
1999 Ford F-250
Smokin' has much to be proud of Smokin' has much to be proud of Smokin' has much to be proud of Smokin' has much to be proud of Smokin' has much to be proud of Smokin' has much to be proud of Smokin' has much to be proud of Smokin' has much to be proud of Smokin' has much to be proud of Smokin' has much to be proud of
Quote:
Originally Posted by big poppa View Post
Great pics, not only the dropout you have to worry about, it's the rust from the upper and lower stamped steel intake and outlet coolant housings too, this is what my upper looked like after my T-stat changeout , the lower looks grungy also, that will be changed out eventually. Dieselsites aluminum housing on the left, stock stamped steel on the right. CAT red ELC user here with the D-S coolant filter system installed. I'll be pulling my coolant filter soon to see what I caught, been about 6 months approx.
Eeww. Mine didn't look anything like that. I've never seen any of that silicate, either...and I did a full flush on my '99 last year.
__________________
Lisa Early '99 PSD long bed XLT supercab. 4" Pro Comp suspension lift, 315 BFG AT's on 17" Liquid Metal Gatlins, Hypermax Boost Pyrometer, 4" exhaust, DP Tunes - no start, 60 Tow, 80 Econo, 120 Race, 203* thermostat and billet housing, 6637 w/Pete's cover, CCV, oil crossover Kit.
  #23 (permalink)
Old 11-04-2009, 11:15 AM
hucka1a's Avatar
hucka1a hucka1a is offline
Oh Fudge...
hucka1a has a great reputation on FTE. hucka1a has a great reputation on FTE. hucka1a has a great reputation on FTE. hucka1a has a great reputation on FTE.
Looks like ELC to me! And with a 2002, he had semi-ELC in there to start with. Imagine how much silicate drop-out is in a green coolant motor! I need to get this done. I've been putting off the coolant change for a while now.....
EDIT: It's NOT "casting sand". It's drop-out from coolant with SCA in it. Gold has a little SCA, green is full of it. Here's what it looks like:
Thanks for the pic, Joe. You have proved a point that I've been trying to make.
Quote:
Originally Posted by mueckster View Post
I ordered a case of the Peak Final Charge ELC (CAT approved) from O'Reailly's. It was $19.99/gallon and they had it at their warehouse. They had it at the store that afternoon. Picked it up the next day. Most auto parts houses and some OTR trucks parts didn't know what I was talking about when I asked for the CAT approved ELC.
I know exactly what your talking about. Stowers(Cat dealer), and Fleet Pride were the only places that knew anything about ELC and SCA for that matter.
Like Joe said, it's really up to you. If you do a really good flush, you should be fine. Ottomatic has been running it in his truck for +300k miles.
__________________
Huck PAA Member 66, E.T.A.P.S. Member
early 99 (11/24/98) F250, PSD, auto, 4x4, ec, short bed.6637/wrapped by Pete, CCV Mod, 6.0 Trans Cooler, MKO 4", '05 Power Seats(Thanks Scott), PMT2, Transgo Tugger, DP Tuner F6, diy oba, Isspro Performax, pyro, boost,Trans temp, and EOT mueckster 710 cap,True-Trac(Thanks Cory),diy Coolant filter.Riffraff Diesel Pete's Covers DP-Tuner Roadside Help Network
  #24 (permalink)
Old 11-04-2009, 11:20 AM
I have gold in there now. What's full ELC?
What brand do you guys use? Can you get it from just Pep Boys etc?
Thanks!
__________________
Flying Finn
2004 Jaguar XJ8
1980 KTM 250
  #25 (permalink)
Old 11-04-2009, 11:23 AM
hucka1a's Avatar
Oh Fudge...
Thanks!
Final Charge Heavy Duty Coolant/Antifreeze
__________________
  #26 (permalink)
Old 11-04-2009, 11:50 AM
indyF-350psd's Avatar
indyF-350psd indyF-350psd is offline
Springfield Armory
indyF-350psd is gaining momentum as a positive member of FTE. indyF-350psd is gaining momentum as a positive member of FTE.
Thanks!
i went to my international dealer and got the concentrated stuff. Delo makes it and youll need 4 gallon of concentrate to get the job done. its actually good for 800,000 miles and can go to 1,000,000 if you add the booster to it......
__________________
BILL ----> 2002 F350 7.3L CC LB DUALLY LARIAT 6X6
http://www.roadsidehelpnetwork.info/
  #27 (permalink)
Old 11-04-2009, 11:53 AM
F250_'s Avatar
F250_ F250_ is offline
Still learning every day!
2002 Ford F-250
F250_ has much to be proud of F250_ has much to be proud of F250_ has much to be proud of F250_ has much to be proud of F250_ has much to be proud of F250_ has much to be proud of F250_ has much to be proud of F250_ has much to be proud of
Dang it. When I switched mine over this past spring, I didn't know about the lower hose housing being replaceable, and didn't nbotice it while doing all the work, either. I replaced both upper and lower hoses, belt, stat, stat housing, and installed the Dieselsite filter to boot. I though the only issue I was going to be facing was the heater hoses down the road, but I'm going to have to investigate the condition of my lower housing.
Joe (and anyone else), when you do the new upper hose around hte belt, Home Depot now carries some super wide (like 1/2") cable ties that work wonders to snug the hose up to the alternator frame so that it can't flex out and rub the belt. Good cheap insurance for the hose.
__________________
http://guzzle.rbmicro.com/7pt3/Mods.html
Become a SUPPORTER!!
  #28 (permalink)
Old 11-04-2009, 11:57 AM
F250_'s Avatar
2002 Ford F-250
Quote:
The trick there is to add the booster at the recommended mileage point. Adding it on teh front end of the swap won't do you any good. The CAT ELC (which is really Shell's Rotella ELC) has the same kind of option to boost the coolant part way through its life. Just check it about every 50,000 miles for proper pH levels.
__________________
  #29 (permalink)
Old 11-04-2009, 11:59 AM
Izzy351's Avatar
Getting Faster...
Thanks, Pete. I was just going to use a hose clamp. Not all water pumps have the replaceable lower housing. Some are one piece with an extension molded in place with the rest of pump:
__________________
  #30 (permalink)
Old 11-04-2009, 12:12 PM
Thanks guys, I'm going to search a place that has that Final Charge and will get 4 gallons of concentrated.
__________________
Flying Finn
2004 Jaguar XJ8
1980 KTM 250
Tags
2001 , 60 , 73 , 73l , cat , coolant , diesel , engine , f250 , filter , flush , ford , gauge , temperature , truck
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
