Go Back   Ford Truck Enthusiasts Forums > Newer Light Duty Trucks > 1997 - 2003 F150
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
1997 - 2003 F150 1997-2003 F150, 1997-1999 F250LD, 7700 & 2004 F150 Heritage SPONSORED BY:
Is F-150 Still King?
  #1 (permalink)
Old 11-04-2009, 07:51 AM
wolfgang031691 wolfgang031691 is offline
wolfgang031691 is starting off with a positive reputation.
2002 F150 XLT FX4 brake question
I recently purchased a 2002 F150 XLT FX4. It has 4-wheel disc brakes. I have never owned a vehicle with 4-wheel disc brakes before...
I just put all new brake pads and rotors on it.
Sometimes I get a very full pedal and sometimes I don't. The pedal doesn't feel "spongy" to me. Since I can't simply adjust up brake shoes in the brake drum (b/c it is 4-wheel disc), do I just need to bleed the brakes?
Or is something else going on?
  #2 (permalink)
Old 11-04-2009, 08:15 AM
redwood's Avatar
redwood redwood is offline
2002 Ford F-150
redwood is starting off with a positive reputation.
bleed the brakes and replace your old fluid.
__________________
WCB
2002 Ford F-150 XLT FX4, 5.4L, Automatic
2010 Ford Escape XLS, 2.5L Duratec, Automatic
1948 Willys CJ2A, V6 Dauntless, Standard tranny
  #3 (permalink)
redwood's Avatar
2002 Ford F-150
You could also have an issue with your master cylinder...
__________________
WCB
  #4 (permalink)
Old 11-04-2009, 10:31 AM
Mawk Mawk is offline
Mawk is starting off with a positive reputation.
From the sound of it, sounds like the beginning stages of a brake booster/master cylinder failure.
First step would be to bleed the brakes first though. It's a simple and inexpensive remedy (if that's the case). At worse, you'll lose a few dollars.
  #5 (permalink)
Old 11-05-2009, 12:56 PM
What is the next stage of the master cylinder failing? Will it get worse?
I've replaced several master cylinders but never had one fail. I replaced them b/c they started to leak or what not. Never had a booster fail.
Are they difficult to change on this?
Tags
2002 , bleeding , brake , brakes , cylinder , disc , f150 , f250 , ford , master , pads , spongy , truck , trucks , xlt
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
