Go Back   Ford Truck Enthusiasts Forums > Performance, Engines and Troubleshooting > Ford Inline Six, 200, 250, 4.9L / 300
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
Is F-150 Still King?
  #1 (permalink)
Old 11-04-2009, 12:13 AM
86sixbanger's Avatar
86sixbanger 86sixbanger is online now
1986 Ford F-250
86sixbanger is starting off with a positive reputation.
Which 4 barrel for me?
I am planning on tearing a few things on my 300 off and putting a few better things back on again. Off will come the stock "log" exhaust manifold, the stock intake manifold, and last, but definately not least, that crappy carter 1-barrel will come off, and get thrown as far as I can throw off the nearest pier. So, all you more experienced 300 carb swappers,I was wondering which carb, and offy manifold you would suggest. I have already heard enough stuff to pretty much be talked out of the Holley 390. I was wondering if the Holley truck avenger 470 would be much better? And I am also considering a 500 edelbrock. Any others I might try? I am mainly looking for something easy to tune, and hopefully stay tuned for a while, and I am shooting for around 17 mpg, (would be nice, we'll see, 1986 f250 4x4 np435 3.55 gears) I know this topic gets quite a bit of airtime, but it always seems to be about the holley 390, and I want to know more about the holley 470 and the edelbrock. All input accepted graciously. Thank You.
  #2 (permalink)
Old 11-04-2009, 09:35 AM
F-250 restorer's Avatar
F-250 restorer F-250 restorer is offline
F-250 restorer is starting off with a positive reputation.
To make all your componets work efficently together you need to help your engine breathe easier. The way you do that is by porting and polishing the head. You can do it yourself or have a professional do it for about $300. That will wake up your engine.
I personally have the Edelbrock 500. It is a great carburetor, and was a bolt on operation for my truck. However, I have over-size valves in my engine, and an rv cam, so that might make a difference. If the stock Edelbrock is too much, you can buy the metering kit for it, and dial it in. The kit runs about $40. You can check the Edelbrock instructions for how it is done on their website, or through the Summit Racing website. It seems like a pretty easy procedure.
It is a blast when you feel the secondaries open up and the beast takes off! For a week or so, until you get tired of 'driving like in high school' and get over the thrill of your new engine, your milage won't be too good.
Two other things to consider prior to the swap: A cover plate for the bottom of the Offy intake, with cooling fluid entrance and exit. A tip I would offer would be to make the tubes going in and out as long as possible to clean the manifold and make it as easy as possible to attach hoses.
Tip #2: Throttle linkage. Your carb is going to sit so that the throttle pulls toward the passenger fender. Lokar makes a cable that works quite nicely, and a bracket to secure it as well.
MSD mounted with vibration  mounts
You can see the cable in the photo above.
long hose fittings to clear headers
The one tube I should have made a couple of inches longer.
Offenhauser bottom plate
I welded the fittings to the plate so I wouldn't have to worry about leaks. I should have welded the pipe into the elbows as well.
  #3 (permalink)
Old 11-04-2009, 10:06 AM
jas88's Avatar
jas88 jas88 is offline
jas88 is gaining momentum as a positive member of FTE.
The best carburetor ever made by man is the Rochester Quadrajet. Closest thing to EFI in a carb you can get. Find one for a Chevy 305 or Pontiac 301 and you will be good to go. Very sophisticated fuel metering and much more durable than a Holley.
Isn't the Edelbrock carb the same as the old Carter AFB?
__________________
1991 F150 SuperCab 4.9L/ZF5
1991 Bronco SAE 5.0L/E4OD
2005 Escape 2.3L/CD4E
  #4 (permalink)
Old 11-04-2009, 11:30 AM
NavyMIDN08's Avatar
NavyMIDN08 NavyMIDN08 is offline
NavyMIDN08 is starting off with a positive reputation.
yes, the carter and edelbrock are pretty much the same. i must agree with the rochester comment. the smaller primaries on the q-jet improve economy, while the larger secondaries give a great boost. whatever you go with, make sure and get vacuum secondaries. i had the carter 500 on mine, and was satisfied, but it was more than i needed with a stock head and cam. i'll probably be happier with it when i finally get the truck back and start swappin' parts again.
__________________
If it ain't broke, you ain't worked it hard enough...
  #5 (permalink)
Old 11-04-2009, 12:57 PM
91Bronc300 91Bronc300 is offline
91Bronc300 is starting off with a positive reputation.
I agree that the rochester is a fantastic carb. But in at least one way it is definitely not like EFI, and that's metering fuel well in a vehicle that's off camber. The holley truck avengers are specifically designed to do that. I've seen videos of rock and mud buggies almost verticle and the engine still running. If you don't offroad your truck that extreme though I'd say a rochester may be a better street carb than a 470 truck avenger. But the 670, 770 truck avengers come with annular boosters in the primaries, making the carb atomize fuel well even at low vacuum signals (making the carb act smaller on smaller engines, while still having the breathing benefits of a bigger carb). I've run a 670 truck avenger on a 300 before and I liked it. (didn't do extreme offroading with it though)
Restorer, your engine looks great! I didn't really think blasting the black off the clifford valve cover and chroming it would look that good but I was wrong, it looks sweet
__________________
1991 Bronco; 4.9L; Mazda 5 speed; BW1356, 8.8 open rear; 44TTB open front, 3.55; daily driver
1985 F-250 4x4; 300; C6; BW1345, Ford sterling semi float posi rear; 44HD TTB open front; 3.55; runs
1979 F-250 4x4; 400, NP435; NP205; Dana 60 full float open rear; Dana 44HD open front, project truck
  #6 (permalink)
Old 11-04-2009, 05:59 PM
Thanks! But it isn't chromed. It is polished aluminum. Just go to Home Cheapo (Depot) and get some paint stripper. Spread it on with a cheap paint brush, let it blister, then wash it off with the hose and a bit of scrubbing with a plastic bristle brush. Repeat until all the paint is gone. When it was dry I took mine to a chrome shop and had them polish it for $70 bucks. BEFORE REINSTALLING, CLEAN THE POLISHING COMPOUND UP UNDER THE BAFFLE, INSIDE THE VALVE COVER. That little mistake cost me a set of bearings!!
  #7 (permalink)
Old 11-04-2009, 06:09 PM
1986 Ford F-250
How would you say the Q Jet, Edelbrock 500, and the Holley truck avenger stack up as far as gas milage? Oh and by the way thanks for all the input.
  #8 (permalink)
Old 11-04-2009, 06:17 PM
carb suggestion
If you were going to use the C manifold, so the carb could sit lengthwise to the engine, then I would suggest an Autolite 4100. I had one on my 300, but with the dp manifold, it sat so close to the valve cover that I couldn't adjust the mixture. But it kicked butt! Super easy to rebuild, with kits readily available.
Google pony carburetors .com and read up on them. Holley paid Ford to copy the annular fuel discharge system. You can pick one up for pretty cheap at a swap meet or craig's list, and rebuild it yourself. The 1.08 venturi size (480 cfm) came stock on the Mustang 289's, up until '68. Pony Carbs also sells 'shims' for the 1.12 venturi size (600 cfm), which makes it (internally) a spreadbore, cutting down the primary venturi size to 1.00. That way you'll get killer mpg, and still have snap-neck acceleration for the 'highschool' moments.
autolite 4100
This 4100 Autolite has been replated.
  #9 (permalink)
Old 11-04-2009, 06:35 PM
How do they stack up? Vehicle weight, configuration, gear ratio's, cam size, engine state of tune, intake type, trans ... all come in to play. Under identical conditions in a laboratory, I'd guess the carb with the lowest cfm would take the mpg prize. But in the real world?
Note: I have a '75 F-250 with a '78 300 bored .030 over, rv cam, ported and polished head with over-size valves, bumped compression ratio, msd ignition with tfi street blaster coil, offy dp intake, hedman header, and Edelbrock 500, 3.31:1 rear end, and I get 15 mpg on the freeway, average over 500 miles, and about 60 miles of that was foothills. And that made me happy.
  #10 (permalink)
Old 11-04-2009, 08:29 PM
1986 Ford F-250
This will be on a 1986 f250 4x4 NP435 trans 3.55 gears. What are the main differences between the two offy intakes? Sorry I'm kind of new to this whole induction modification thing. (That will probably be one of my easiest choices for this whole project, because I don't have enough dough for the clifford manifold, so my new manifold is going to have to be one of the offys, I'm just not quite sure which one.)
  #11 (permalink)
Old 11-04-2009, 11:58 PM
RESEARCH is a big part of any project. DO YOUR RESEARCH. Don't rely on what others tell you. Go to the websites and read about the products and the differences. Weigh the differences and decide according to the GOALS you set for your project.
Things to remember:
1. Set a goal for your project.
2. Do your research.
  #12 (permalink)
Old 11-05-2009, 12:14 AM
1986 Ford F-250
Yeah you're right I haven't quite been thinking about this project as much as I've been thinking about other projects lately.
  #13 (permalink)
Old 11-05-2009, 12:20 AM
Harte3 Harte3 is online now
Harte3 is starting off with a positive reputation.
Phethean Racing Products - Offenhauser
Just to get you started...
__________________
1983 F150 300 I6, Comp Cam 260h and lifter kit, Port/Polished head, Offy DP Manifold, Holley 4160/1848-1 465 cfm, EFI Exhaust manifolds, Walker Y Pipe to 3-Way Cat, generic Turbo Muffler, Recurved DSII, Mallory HyFire 6a & ACCEL Super Stock Coil, Taylor Spiro Pro Wires, EFI plugs.
  #14 (permalink)
Old 11-05-2009, 08:03 AM
gfw1985's Avatar
gfw1985 gfw1985 is offline
gfw1985 is starting off with a positive reputation.
Just for info only, not an opinion. If thinking about a quadrajet, check BC Bronco's. He builds that carb in I believe 3 diff config. and the Bronco crowd have very good things to say about his carbs. I wish I could use the Edelbrock on my 200 but will have to go with the Holley 390. Glad you posted that pic with the Lokar cable F-250 restorer, hope to get mine installed this weekend.
__________________
76 Bronco Explorer 289 Hi-Po
66 U14 Half Cab Bronco frame off in progress
  #15 (permalink)
Old 11-05-2009, 05:58 PM
1986 Ford F-250
Quote:
Originally Posted by Harte3 View Post
Thanks, I have searched those offy 6 cylinder manifolds before, and that site was pretty much all I found. Why the lack of "official" info on the offies?
Tags
289 , 300 , 4100 , afb , autolite , barrel , carb , carburetor , carter , edelbrock , f250 , ford , gas , mileage , offroad , troubleshooting
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
