Go Back   Ford Truck Enthusiasts Forums > Diesel > 1994.5 - 1997 7.3L Power Stroke Diesel
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
1994.5 - 1997 7.3L Power Stroke Diesel SPONSORED BY:
Is F-150 Still King?
  #1 (permalink)
Old 11-03-2009, 11:43 PM
Benny D Benny D is offline
1997 Ford F-Series Pickup
Benny D is starting off with a positive reputation.
Intercooler
how hard is it to install a banks intercooler on my 1997 f-250 hd 7.3L?
  #2 (permalink)
Old 11-04-2009, 10:25 AM
Fullcrew7.3's Avatar
Fullcrew7.3 Fullcrew7.3 is offline
Rice Rocket Eater
Fullcrew7.3 is gaining momentum as a positive member of FTE.
Not too sure, I'm just getting set up to put in a '99 SD IC. I'm sure someone who's already done it will chime in soon.
__________________
Fullcrew7.3
Dave
1996 F350 CC 7.3L PSD DRW 3.55 gears ,cat delete, 4" exhaust, SC 1705, Stage 1 DIY sticks, Valair SMF, 203* thermostat, 3" DP, SD intercooler, 17* HPOP, 37/12.50/16.5's and some more stuff
  #3 (permalink)
Old 11-04-2009, 10:45 AM
nateairman's Avatar
nateairman nateairman is offline
nateairman is starting off with a positive reputation.
Will the 99-00 IC fit around the 97 radiator or will it have to mounted in front so that the pipes on the end tanks clear the radiator. Just curious and it sounds like Fullcrew 7.3 has a IC in his hands. Other than that little hang up is the piping around the turbo and intake.
  #4 (permalink)
Old 11-04-2009, 11:20 AM
MagKarl MagKarl is offline
MagKarl is starting off with a positive reputation.
The IC inlet/outlet on mine barely cleared the radiator. I had to notch the radiator and shroud flanges along with the core support on mine. I have the early style radiator though so yours is likely a bit different. It all fits good, you just need to do some careful measurement, layout, and trimming.
__________________
1995 F350 XLT CC 4WD PSD 5 Speed
2001 Excursion Limited 4x4 V-10
  #5 (permalink)
Old 11-04-2009, 12:36 PM
tbone heller's Avatar
tbone heller tbone heller is offline
tbone heller is starting off with a positive reputation.
Read this: http://assets.bankspower.com/manuals...ord-v4-web.pdf .
I am going to use it as a guide to install a 6.0L intercooler in mine.
__________________
1997 F-Super Duty XLT, PSD, 5-Speed
  #6 (permalink)
Old 11-04-2009, 01:25 PM
RÖENTGEEP's Avatar
RÖENTGEEP RÖENTGEEP is offline
FOREIGN GURU
1996 Ford F-250
RÖENTGEEP has a good reputation on FTE. RÖENTGEEP has a good reputation on FTE.
Exclamation
Quote:
Did you buy the banks intercooler yet?. I ask this because with a lot less money you can install an IC in your truck.
__________________
96 F250, PSD, XLT, SC, SB, E40D, 2WD, 3.55, 143K.
DIY intake and exhaust brake. DP 3-3.5" ceramic coated; HPX; GPR switch; Isspro gauges; shim FPR; tranny cooler; CCV mod; 4" stainless Magnaflow; SS 5" tip; no cat; RacerX VB; TW 6p chip; 203*.
«Primum non nosere»
  #7 (permalink)
Old 11-04-2009, 01:47 PM
fordboy2 fordboy2 is offline
fordboy2 is starting off with a positive reputation.
Quote:
do tell us how please
__________________
06 f350 lariat srw-factory 20's(winter), mb shakers w/35" toyo mt's(summer), chrome package,zoodad, pioneer D3 with rear monitor,riderite air bags, sky jacker leveling kit, air lift air bags in front, 8.2 Boss v-plow, 90 watt corner strobes, 4" magnaflow turbo back exhaust minus the kitty, K&N fipk, coming soon spartan tunes, analog gauges
96 f350 reg cab lb, 7.3 auto 191000miles just gettin started
  #8 (permalink)
Old 11-04-2009, 02:44 PM
RÖENTGEEP's Avatar
FOREIGN GURU
1996 Ford F-250
Wink
Buy an IC from a SD 7.3 or 6.0, about $100 to 200, buy an early 99 Y-PIPE, it goes about from $50 to 100; the clamp for the TURBO about 10-20; buy some sort of exhaust pipe and fab your pipes, finish buying some boots and clamps and install yourself.
You can always look on e-bay for the stuff or in the clasifieds.
Most people here had completed the IC for about $400. Do you know how much costs the Banks IC? aroud $1,400.
__________________
«Primum non nosere»
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
This forum is owned and operated by Internet Brands, Inc., a Delaware corporation. It is not authorized or endorsed by the Ford Motor Company and is not affiliated with the Ford Motor Company or its related companies in any way. Ford® is a registered trademark of the Ford Motor Company.
