Will the 99-00 IC fit around the 97 radiator or will it have to mounted in front so that the pipes on the end tanks clear the radiator. Just curious and it sounds like Fullcrew 7.3 has a IC in his hands. Other than that little hang up is the piping around the turbo and intake.
The IC inlet/outlet on mine barely cleared the radiator. I had to notch the radiator and shroud flanges along with the core support on mine. I have the early style radiator though so yours is likely a bit different. It all fits good, you just need to do some careful measurement, layout, and trimming.
__________________
1995 F350 XLT CC 4WD PSD 5 Speed
Did you buy the banks intercooler yet?. I ask this because with a lot less money you can install an IC in your truck.
do tell us how please
__________________
06 f350 lariat srw-factory 20's(winter), mb shakers w/35" toyo mt's(summer), chrome package,zoodad, pioneer D3 with rear monitor,riderite air bags, sky jacker leveling kit, air lift air bags in front, 8.2 Boss v-plow, 90 watt corner strobes, 4" magnaflow turbo back exhaust minus the kitty, K&N fipk, coming soon spartan tunes, analog gauges
96 f350 reg cab lb, 7.3 auto 191000miles just gettin started
Buy an IC from a SD 7.3 or 6.0, about $100 to 200, buy an early 99 Y-PIPE, it goes about from $50 to 100; the clamp for the TURBO about 10-20; buy some sort of exhaust pipe and fab your pipes, finish buying some boots and clamps and install yourself.
You can always look on e-bay for the stuff or in the clasifieds.
Most people here had completed the IC for about $400. Do you know how much costs the Banks IC? aroud $1,400.
This forum is owned and operated by Internet Brands, Inc., a Delaware corporation. It is not authorized or endorsed by the Ford Motor Company and is not affiliated with the Ford Motor Company or its related companies in any way. Ford® is a registered trademark of the Ford Motor Company.
