Go Back   Ford Truck Enthusiasts Forums > Diesel > 1994.5 - 1997 7.3L Power Stroke Diesel
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
1994.5 - 1997 7.3L Power Stroke Diesel SPONSORED BY:
Is F-150 Still King?
  #1 (permalink)
Old 11-03-2009, 09:49 AM
drewmgd73 drewmgd73 is offline
drewmgd73 is starting off with a positive reputation.
Turbo whistle?
Okay I just bought a 97 f250 7.3 im noticing that the turbo is not whistling like my 95 dodge did. Why is this I recently had a fuel issue underneath the turbo which i got it takin care of but when I get on it I dont hear the turbo whistling and I dont even see smoke coming from the exhaust. What can I do to see if the turbo is working correctly the dealership gave me a 30 day warranty on the truck and yes they have fixed everything I have found wrong with it. But this turbo has got me baffled and dont know what to try next. Help
  #2 (permalink)
Old 11-03-2009, 10:13 AM
rupejosh's Avatar
rupejosh rupejosh is offline
1994 Ford F-250
rupejosh is starting off with a positive reputation.
your in the wrong forum,you need the first gen powerstroke forum.but i can tell you the 1st gen's dont whistle much without a straight pipe and a cold air intake.and with no black smoke that means the turbo is working fine
__________________
94 ford f250 7.3 turbo idi headlight mod,electric fuel pump,tinted windows all around,straight piped and 6" stack and sweet camo trim in the cab
  #3 (permalink)
Old 11-03-2009, 10:31 AM
99SevenPoint3's Avatar
99SevenPoint3 99SevenPoint3 is offline
99SevenPoint3 is starting off with a positive reputation.
plus those down pipes they got on those trucks dont help either ... but deff u need the the first gen powerstroke forum
__________________
Zeus
_Early 99 7.3L 6spd F350 Dually 8" inch lift w/22.5's ..hpx,ccv,intank, zoodad -H/M k&n kit,SouthBendClutch, 02 turbo/w WW,intank pump club,Bellowed up-pipes,MKO 5" exhaust
_94 7.3L IDI Factory turbo 5spd F350 (some upgrades)
  #4 (permalink)
Old 11-03-2009, 11:23 PM
Dave Sponaugle's Avatar
Dave Sponaugle Dave Sponaugle is offline
1986 Ford F-250
Dave Sponaugle is a name known to all Dave Sponaugle is a name known to all Dave Sponaugle is a name known to all Dave Sponaugle is a name known to all Dave Sponaugle is a name known to all Dave Sponaugle is a name known to all
Moved to the 1994 tru 1997 7.3 Power Stroke forum.
__________________
86 F250 HD 6.9 IDI ATS turbo "not exactly" stock 4x4 T19 BW1345 3.55LS both ends D60 front, 10.25" Sterling rear, ram air, dual stacks.
"I dig dirt"
FTE Guidelines
FTE Moderator IDI diesel forum
WV Chapter Member
  #5 (permalink)
Old 11-03-2009, 11:38 PM
rodneywar's Avatar
rodneywar rodneywar is online now
rodneywar is starting off with a positive reputation.
Ok You need to open up the intake and add a down pipe if the cat is still there delete it if is ok in your state then u can hear the turbo whistle. Mine whistles at 2200 rpm and up. And the smodke thing is because dodge has injection pumps we have heui systems which is electrohydraulic injectors. You can make the engine smoke with a custom chip like tony wildman. I hope I helped.
__________________
Ronnie Warfield
1995 F 250 Turbo diesel reg cab 2wd
6637 mod, 3 inch dp, lost kitty, GPR mod, 120v idm, 2500 watt inverter
Maryland Chapter member
  #6 (permalink)
Old 11-03-2009, 11:48 PM
nateairman's Avatar
nateairman nateairman is offline
nateairman is starting off with a positive reputation.
Smokey
Quote:
rodneywar: I have a bit of smoke on my truck in the mid to upper rpms. Seems to be the worst in first and second, which is accompanied with a miss. Where do I start with diagnosing this? 1997 f350 5spd 4x4
  #7 (permalink)
Old 11-03-2009, 11:52 PM
rodneywar's Avatar
as for the miss does the truck sorta shakes when you drive it normally?
__________________
Ronnie Warfield
  #8 (permalink)
Old 11-04-2009, 12:02 AM
strokin'_tatsch strokin'_tatsch is offline
strokin'_tatsch is starting off with a positive reputation.
for the smoke and whistle question by the OP. if you want smoke you need fuel. your dodge probably didn't have the baffle in the turbo that came with it. when you take the baffle outta a dodge turbo the scream at you, but we don't have those. so you need to do the intake. for that go with the 6637 intake. you may be able to type in 6637 mod in the search and find a lot of pics, but in the mean time i will try to get a pic of mine. that intake only costs around $50 to build. then you need to do the exhaust. i would go with 3" downpipe to 4" exhaust with or without a muffler and no cat. then you should do guages and then the chip. for the chip if you want smoke look at tony wildman @ www.totaldieselperformance.com or Jody's tunes at DP-Tuner
__________________
DEATH ROW DIESEL INMATE # 7-- TRAVIS
1995 F-250 PSD- Tony's tunes, CPR fuel system, 120v IDM, T.E 17* HPOP, DIY stage 2's, val-air full ceramic clutch, ISSPRO's, 3" dp-5" stacks, IC, ccv mod, 6637.... DYNO'D 352hp/731tq w/ stage 1's........... '94 F150 SC SB 4x4 5 speed(PROJECT!)
  #9 (permalink)
Old 11-04-2009, 12:03 AM
rodneywar's Avatar
Ok i found your post on the other thread I would say one of your injector o rings is giving out under high pressure from the hpop letting oil into the cylinder that could account for the smoke also it accounts for the miss cause the injector isnt getting the oil pressure it needs due to the oil going into the cylinder causing a miss. I hope some one else will verify my theory cause i don't have the actual engine in my hands.
__________________
Ronnie Warfield
  #10 (permalink)
Old 11-04-2009, 12:19 AM
nateairman's Avatar
I have been eyeing the DIY injector rebuild kits and am not fond of throwing money at a machine without a plan. It doesn't really shake or shudder until you get into the throttle but the problem seems to go away once its in third gear. Seems to have something to do with the rate of rpm change. dunno. I found that the exhaust manifolds and some of the pre turbine pipes weren't tight. After tightening all that up the engine makes a swooshing noise as the turbo comes up to pressure. Not sure that is normal so I will check for pressure leaks tomorrow, unless it is normal. Turbo gas is a little different than turbo diesel...
Last edited by nateairman; 11-04-2009 at 12:30 AM. Reason: previous expirence with a sports car.... truck is diesel
  #11 (permalink)
Old 11-04-2009, 01:35 PM
427 fordman 427 fordman is offline
427 fordman is gaining momentum as a positive member of FTE.
On my 97 I could never hear the turbo. Then I did the 6637 intake and a 3-4 inch downpipe with a 4" straight pipe exiting in front of the rear tire. It whistles loud at an idle and louder when you get on it. I love it. No other mods either(yet).
__________________
Darin I BLEED BLUE
1976 F250 hboy w/71box 390 "Ol'brown"
1997 F250 HD 7.3 10k 3-4" downpipe w/straightpipe 6637 intake ebpv gone
1966 Ford Fairlane drag car 514cu.
  #12 (permalink)
Old 11-04-2009, 02:00 PM
Fullcrew7.3's Avatar
Fullcrew7.3 Fullcrew7.3 is offline
Rice Rocket Eater
Fullcrew7.3 is gaining momentum as a positive member of FTE.
fordman is right on the ball. Those are the first 2 mods I did and had lots of whistle. better throttle response as well. The FPR (fuel pressure regulator) shim is another real cheap, real good mod. If you can afford to buy a BB, you can do this one.
__________________
Fullcrew7.3
Dave
1996 F350 CC 7.3L PSD DRW 3.55 gears ,cat delete, 4" exhaust, SC 1705, Stage 1 DIY sticks, Valair SMF, 203* thermostat, 3" DP, SD intercooler, 17* HPOP, 37/12.50/16.5's and some more stuff
Tags
1995 , 1997 , 73 , diesel , dodge , drewmgd73 , f250 , idi , make , noise , powerstroke , scream , turbo , upgrades , wanting , whistle , whistling
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
