I have the numbers 1694 80-457 on the bowl.
What do I have? Any help would be appreciated.
Thanks
__________________
If you give your work away for peanuts expect to attract more than your fair share of squirrels!!
______________________________________
79 F100 Short Bed, Step Side 2wd - 302, C4, AC, Tilt. -
Look on the front of the airhorn on the throttle cable side and a list number will be stamped in it. That number can be referenced at holley's web site as to what application it fits.
found it ... 80457 is a 4160 600cfm stock jetting is (f) 69, (r) Plate 134-39 with a 6.5 powervalve.
thanks
__________________
The 6.5 is what came from the factory on the carb.
Im putting it on a air gap manifold on a 302 .040 over with a 290 cam.. nothing special.
__________________
