More pics and more of my long winded usual BS...
Bearing press? :/
We dohn need no steekeen press when we gottuh 8 poun' single jack! :)
http://www.panix.com/~alvinj/file12/zf4.jpg
Man I'll tell you what, that hammer has worked out real nice.
It'll cut off frame rivets like it means it. ;)
Check out the two old Ford9inch axle-retainers being used for spacers.
Took the picture with the flash just to show those off. LOL :)
(shoulda used a flashlight)
The cross-pin is from a washing machine.
15/16" wood bit for the hole in the block of wood and works for either end.
I don't know about you, but my back can handle working on the floor way
better than standing or sitting at a work bench. YMMV on that. :)
(4x10 block of wood)
I see part numbers for all sorts of stuff I could "use" but can't find a seller.
http://www.panix.com/~alvinj/file12/zf5.jpg
Like the rubber plug for the bottom.
My T18 doesn't have huge gaping holes all over the bell housing and does
fine out here where it's dry, so figured this dangged ZF didn't neither.
http://www.panix.com/~alvinj/file12/zf6.jpg
That's a 3/4" rubber hose, WD-40ed up and hammered into place then cut
off from the inside with my pocket knife.
I'm going to drill a hole in the steel spacer plate on the engine or bottom
of the bell housing or something. All those holes and no drain at the very
lowest spot! :(
Still haven't worked out what I'm going to do with the slave cylinder holes.
Could use a seller of simple parts like springs. Ford has a suggestion for
upgraded "shift rail detent springs" and gives a part number but this old
"dent-sider" don't buy stuff from the dangged "obsolete-ers" anymore,
unless I absolutely have to! :/
Upgraded detent springs... E8TZ-7E218-A
10mm case plugs for the dentents... E7TZ-7L013-A
With shipping and all, from "Ford" the "inner lever boot" cost almost $30
and it's just the rubber part even tho their pictures show the metal part
attached. F4TZ-7277-A
There's a part left out of most ZF S5-42 exploded diagrams but Ford's
diagrams have it but they had to add a number for it between 38 and 39
so called it "38A". :)
Part number "7046" is all the farther I got with it. :/
"oil baffle"
"front bearing oil scoop"
"input shaft oil dam"
Are the names for it I could find.
One came in the $330 bearing and synchro ring kit.
Here's my "fix" for the springs...
http://www.panix.com/~alvinj/file12/zfS.jpg
Notice that one spring is turned so you can see the worn-spot on it?
All three springs from a certain synchronizer hub were like that.
(Reverse and 5th?)
Anyway they felt wimpy and all the synchro springs were slightly under
minimum length so I used hunks of spring from my Brownell's spring pack.
Just lucked out Brownell's springs have the opposite spiral huh? :)
Made "inserts" for all nine synchro springs, the three detent springs and
the reverse lockout spring too. That last one was just for the heck of it.
Not sure, but figure it to be, one problem with slamming the gears apart
was a damaged snap ring. 57mmx 2mm or 2+1/4" might work.
Front seal is a 35mm x50mm x8
Rear seal is a 50mm x65mm x8
Alvin in AZ
